软件模拟IIC,在ACK应答的时候SDA返回1(NG)。
但是IIC通信协议基本满足,就是ACK应答返回NG。
请问问题可能出在哪?
以下是我的程序:
void StartIIC(void)
IIC_SCL = 1;
IIC_SDA = 1;
waitus(5);
IIC_SDA = 0; //开始通信条件建立
waitus(4);
IIC_SCL = 0;
Bool TxData(U8 data)
U8 i;
for(i = 0; i<8; i++)
if(data&0x80){
IIC_SDA = 1;
waitus(2);
else{
IIC_SDA = 0;
waitus(2); //中间函数调用3us,SCL低电平时间大于4.7us
IIC_SCL = 1;
waitus(2);
IIC_SCL = 0;
data<<=1;
IIC_SDA = 1; //MCU侧主动拉高
waitus(2);
IIC_SCL = 1;
PD_IIC_SDA = IN; //设为输入管脚
waitus(4);
if(IIC_SDA){ //如果为高电平
return Error;
else
共3条
英文PDF中其实有这么一句话,供大家一起参考:
The master(uP) puts a resistive HIGH level on the SDA line during the acknowledge clock pulse. The peripheral that acknowledges has to pull-down(LOW) the SDA line during the acknowledge clock pulse, so that the SDA line is stable LOW during this clock pulse.
我使用的是R8C 2C的片子。
共3条
