电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 关于keil中STARTUP.A51的研究
2008-11-26 16:38:47     打赏
        让我们先来看看STARTUP.A51文件(默认设置)吧!根据源文件中的说明文字,我们很容易分析出STARTUP.A51文件的工作方式和作用!让我们把它先汉化一下看看!
         $NOMOD51;Ax51宏汇编器控制命令:禁止预定义的8051
        ; This file is part of the C51 Compiler package
        ; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
         ; STARTUP.A51: This code is executed after processor reset.
; STARTUP.A51: STARTUP.A51文件所生成的代码将在单片机复位后被执行!
        ; To translate this file use A51 with the following invocation:
; 将按照下面的命令行语句调用A51编译器进行编译产生目标文件
        ; A51 STARTUP.A51
        ; To link the modified STARTUP.OBJ file to your application use the following
        ; BL51 invocation:
; 将按照下面的命令行语句调用BL51连接器把STARTUP.OBJ定位连接到您的程序代码中
; BL51 <your object file list>, STARTUP.OBJ <controls>
        ; User-defined Power-On Initialization of Memory
 ; 自定义上电后需要初始化的储存区域
        ; With the following EQU statements the initialization of memory
         ; at processor reset can be defined:
; 使用下列EQU伪指令定义初始化的存储区域在单片机复位后定义生效
        ; the absolute start-address of IDATA memory is always 0
        IDATALEN EQU 80H                     ; the length of IDATA memory in bytes.
; IDATA(间接寻址区)其起始地址固定为0
;IDATALEN用于指定需要初始化的 IDATA区长度(以字节为单位)*
        XDATASTART EQU 0H                    ; the absolute start-address of XDATA memory
;XDATA (外部直接寻址区) XDATASTART用于指定需要初始化的XDATA区起始地址
        XDATALEN EQU 0H                         ; the length of XDATA memory in bytes.
;XDATALEN 用于指定需要初始化的XDATA区长度(以字节为单位)*
        PDATASTART EQU 0H                     ; the absolute start-address of PDATA memory
;PDATA(页寻址区)PDATASTART用于指定需要初始化的PDATA区起始地址
        PDATALEN EQU 0H                          ; the length of PDATA memory in bytes.
;PDATALEN用于指定需要初始化的;PDATA区长度(以字节为单位)*
        ; Notes: The IDATA space overlaps physically the DATA and BIT areas of the
        ; 8051 CPU. At minimum the memory space occupied from the C51
        ; run-time routines must be set to zero.
;注释:8051中 IDATA 区物理上已经包括了DATA区(直接寻址区)以及 BIT区(位寻址区)。C51(库)占用了最小化内存空间,运行时程序需要把它设为0
        ; Reentrant Stack Initilization
        ; 重入堆栈初始化
        ; The following EQU statements define the stack pointer for reentrant
        ; functions and initialized it:
 ; 下面的EQU语句定义重入函数的堆栈指针并初始化它
        ; Stack Space for reentrant functions in the SMALL model.
 ; SMALL模式下的重入函数的堆栈空间
        IBPSTACK EQU 0                     ; set to 1 if small reentrant is used.
;如果再SMALL模式下使用重入则设为1
        IBPSTACKTOP EQU 0FFH+1                     ; set top of stack to highest location+1.
;设置堆栈顶最高位置+1
        ; Stack Space for reentrant functions in the LARGE model.
; LARGE模式下的重入函数的堆栈空间
        XBPSTACK EQU 0                     ; set to 1 if large reentrant is used.
;如果再LARGE模式下使用重入则设为1
        XBPSTACKTOP EQU 0FFFFH+1             ; set top of stack to highest location+1.
;设置堆栈顶最高位置+1
        ; Stack Space for reentrant functions in the COMPACT model.
; COMPACT模式下的重入函数的堆栈空间
        PBPSTACK EQU 0                     ; set to 1 if compact reentrant is used.
;如果再COMPACT模式下使用重入则设为1
        PBPSTACKTOP EQU 0FFFFH+1                    ; set top of stack to highest location+1.
;设置堆栈顶最高位置+1
        ; Page Definition for Using the Compact Model with 64 KByte xdata RAM
; 使用COMPACT模式时为64KB的XDATA RAM定义页
        ; The following EQU statements define the xdata page used for pdata
        ; variables. The EQU PPAGE must conform with the PPAGE control used
        ; in the linker invocation.
 ; 下面的EQU语句定义PDATA变量的使用了XDATA页
        PPAGEENABLE EQU 0                     ; set to 1 if pdata object are used.
        PPAGE EQU 0                     ; define PPAGE number.
;定义页号;如果使用PDATA页则设为1
        PPAGE_SFR DATA 0A0H                     ; SFR that supplies uppermost address byte
;SFR的最高地址字节
        ; (most 8051 variants use P2 as uppermost address byte)
; (大多数8051变量要用P2的最高地址字节)
; Standard SFR Symbols ; 标准SFR符号
        ACC DATA 0E0H
        B DATA 0F0H
        SP DATA 81H
        DPL DATA 82H
        DPH DATA 83H
        NAME ?C_STARTUP
        ?C_C51STARTUP SEGMENT CODE
        ?STACK SEGMENT IDATA
                RSEG ?STACK
                DS 1
                EXTRN CODE (?C_START)
;外部代码(这个标号将代表用户程序的启始地址)
                PUBLIC ?C_STARTUP
;给外部使用的符号
                CSEG AT 0
;在code段的0地址处放以下代码(使用AT指令进行绝对地址的定位)
       ?C_STARTUP: LJMP STARTUP1
        RSEG ?C_C51STARTUP
        STARTUP1:
        IF IDATALEN <> 0
;如果长度大于1则初始化IDATA
                MOV R0,#IDATALEN - 1
                CLR A
        IDATALOOP: MOV @R0,A
                DJNZ R0,IDATALOOP
        ENDIF
        IF XDATALEN <> 0
;如果长度大于1则初始化XDATA
                MOV DPTR,#XDATASTART
                MOV R7,#LOW (XDATALEN)
        IF (LOW (XDATALEN)) <> 0
;预置初始化时的外循环次数到R6
                MOV R6,#(HIGH (XDATALEN)) +1
        ELSE
                MOV R6,#HIGH (XDATALEN)
        ENDIF
                CLR A
        XDATALOOP: MOVX @DPTR,A
                INC DPTR
                DJNZ R7,XDATALOOP
                DJNZ R6,XDATALOOP
        ENDIF
        IF PPAGEENABLE <> 0
                MOV PPAGE_SFR,#PPAGE
        ENDIF
        IF PDATALEN <> 0
;如果长度大于1则初始化PDATA
                MOV R0,#LOW (PDATASTART)
                MOV R7,#LOW (PDATALEN)
                CLR A
        PDATALOOP:
                MOVX @R0,A
                INC R0
                DJNZ R7,PDATALOOP
        ENDIF
        IF IBPSTACK <> 0
;SMALL模式下使用重入函数时要设置的堆栈
        EXTRN DATA (?C_IBP)
                MOV ?C_IBP,#LOW IBPSTACKTOP
        ENDIF
        IF XBPSTACK <> 0
;COMPACT模式下使用重入函数时要设置的堆栈
        EXTRN DATA (?C_XBP)
                MOV ?C_XBP,#HIGH XBPSTACKTOP
                MOV ?C_XBP+1,#LOW XBPSTACKTOP
        ENDIF
        IF PBPSTACK <> 0
;LARGE模式下使用重入函数时要设置的堆栈
        EXTRN DATA (?C_PBP)
                MOV ?C_PBP,#LOW PBPSTACKTOP
        ENDIF
                MOV SP,#?STACK-1
        ; This code is required if you use L51_BANK.A51 with Banking Mode 4
; 如果你的程序使用了Mode 4 程序分组技术(BANKING)请启用下面的程序代码; EXTRN CODE (?B_SWITCH0)
        ; CALL ?B_SWITCH0
        ; init bank mechanism to code bank 0
;程序从第一个块(bank0)开始执行
        LJMP ?C_START ;从这里跳到你的程序入口
        END
关键词: 关于     STARTUP.A51     研究     初始化     使用
