电子产品世界 » 论坛首页 » 企业专区 » Xilinx » 用上了ISE12哈哈(转)
用上了ISE12哈哈(转)
2010-05-13 10:15:39     打赏
用上了ISE12哈哈
这个版本安装时出了点小差错,后来才明白要先装一个补丁以支持英语和日语以外的系统路径 ;不过这就是Xilinx公司的不对了,明明出了问题不公布,还得自己去找
具体的解释在AR #35331 - ISE Design Suite 12 - Shortcuts and desktop icons are not created when language is set to anything other than English or Japanese
Description
My language localization is set to a language other than English or Japanese. After installation, my desktop icons and shortcuts were not created, and the following error occurs:
"Failed to create link xxx.lnk to xxx.xxx"
How can I create the shortcuts and desktop icons?
Solution
Localization settings of English and Japanese are the only supported languages. Any other language setting is not supported and can cause issues with other Xilinx ISE Design Suite tools.
To install the shortcuts and desktop icons, download the following patch and place it into your installed Xilinx directory. Xilinx recommends that you backup your "libwiclient.dll" file prior to dropping the new patch file so that you can revert back if needed. After applying the patch, run shortcutSetup.bat from the Xilinx ISE Design Suite in the common/bin/nt(64) location.
For the patch, download and unzip the file (see the readme file for more information).
Patch: ftp://ftp.xilinx.com/pub/swhelp/ise12_updates/ar35331.zip
关键词: 上了     ISE12     哈哈
