电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » C代码编译不能通过!
C代码编译不能通过!
2010-12-20 20:41:59     打赏
今天把这个宝贝拿出来了,可是发现还是有问题
/* THIS SAMPLE CODE IS PROVIDED AS IS AND IS SUBJECT TO ALTERATIONS. FUJITSU */
/* MICROELECTRONICS ACCEPTS NO RESPONSIBILITY OR LIABILITY FOR ANY ERRORS OR */
/* ELIGIBILITY FOR ANY PURPOSES.                                             */
/*            (C) Fujitsu Microelectronics (Shanghai) Co., LTD.              */
/* Date:20080320   Version:1V0   Author:Levi       */
FUNCTION: Give a example for IO as a digital input or output
#include "mb95200.h"
FUNCTION: initial I/O Port as digital input or output
void Init (void)
 PDR0_P00 = 1;
 DDR0_P00 = 1;    // set P0_P00 output
 PDR0_P01 = 0;
 AIDRL_P01 = 1;    // disable AN1 input
 DDR0_P01 = 0;    // set P0_P01 input
 PDR6_P62 = 1;
 DDR6_P62 = 1;    // set P6_P62 output
 PDR6_P63 = 0;
 DDR6_P63 = 0;    // set P6_P63 input
FUNCTION: delay time;
/*void Delay(unsigned int i)
  unsigned int m,n;
  for(m=0;m<i;m++)
      for(n=0;n<6000;n++)
     asm("\tNOP");
FUNCTION: main loop
void main (void)
 Init ();
 while(1);
  PDR6_P62=1;(这句话不添加进去就编译没错,可只要一加进去就显示警告!是什么问题谁能帮我解决一下啊!)
错误信息是
Now Compile/Assemble...
--------------------Configuration: Digital_IO.prj - Debug--------------------
main.c
*** n:\¸»Ê¿mcu\program\test\digital_io\src\main.c(58) W1025C: statement not reached
Warning detected.
关键词: 代码     编译     不能     通过
2010-12-21 09:51:33     打赏
有点悲剧了,我太马虎了!
