电子产品世界 » 论坛首页 » 休闲专区 » 我爱工作 » IC猎头(北京)Sr. Digital ASIC design engineer
2011-02-22 23:27:23     打赏
Job Description
The position is to lead one project in the field of communication system on the whole ASIC design flow from RTL to GDSII, and FPGA-based prototyping test, then to deliver quality design results. Work independently in different stages of the ASIC design flow. Cooperate closely with system/algorithm team and analog team.
Requirement
1. Master degree with 2+ years of experience of digital ASIC development in communication system physical layer.
2. Familiar with digital ASIC front-end design and related tools, including micro-architecture design, RTL design and coding, simulation.
3. Familiar with logic synthesis, DFT, static timing analysis, ATPG, and power analysis.
4. Experience in FPGA-based prototyping test is a plus.
5. Good understanding of wireless communication system and digital signal processing theory.
6. Has ability of independent debugging and self-learning.
7. Experience of audio or video SOC product development is a plus.
Email:aitbj@126.com
MSN:aitbj@126.com
关键词: 猎头     北京     Digital     design     engi
