电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » SOPC自定义外设(LED数码管扫描)的问题
2011-04-21 17:05:31     打赏
module Display(clk,data,addr,read_en,write_en,data_out,seg,lbit);
input clk;
input read_en,write_en;
input [7:0]data;
input [3:0]addr;
output [7:0] seg;
output [7:0] lbit;
output [7:0]data_out;
reg [7:0]data_in[7:0];
reg [7:0]seg;
reg [7:0]lbit;
reg[7:0]data_out;
reg [7:0]state;
parameter S0 = 1, S1 = 2, S2 = 4,S3 = 8, S4 = 16,S5 = 32, S6 = 64, S7 = 128;
reg [31:0]clk_div;
initial
begin
data_in[0]=249;
data_in[1]=164;
data_in[2]=255;
data_in[3]=255;
data_in[4]=255;
data_in[5]=255;
data_in[6]=255;
data_in[7]=255;
state=S0;
clk_div=0;
end
always @ (state) begin
      case (state)
         S0:begin
            lbit = 254;
                seg = data_in[0];
               end
         S1:begin
            lbit = 253;
                seg = data_in[1];
                end
         S2:begin
            lbit = 255-S2;
                seg = data_in[2];
                end
            S3:begin
            lbit = 255-S3;
                seg = data_in[3];
                end
         S4:begin
            lbit = 255-S4;
                seg = data_in[4];
                end
         S5:begin
            lbit = 255-S5;
                seg = data_in[5];
                end
            S6:begin
            lbit = 255-S6;
                seg = data_in[6];
                end
         S7:begin
            lbit = 255-S7;
                seg = data_in[7];
                end
         endcase
   end
 always @ (posedge clk ) begin
        if(clk_div>50_000)begin
        clk_div=0;
     case (state)
      S0:
         state <= S1;
        S1:
         state <= S2;
        S2:
        state <= S3;
        S3:
         state <= S4;
        S4:
         state <= S5;
        S5:
        state <= S6;
        S6:
         state <= S7;
        S7:
         state <= S0;
      endcase
        end
        else
        clk_div=clk_div+1;
         if(write_en)begin
        //write regs
        case (addr)
      0001:
         data_in[0] <= data;
        0010:
         data_in[1] <= data;
        0011:
         data_in[2] <= data;
        0100:
         data_in[3] <= data;
        0101:
         data_in[4] <= data;
        0110:
         data_in[5] <= data;
        0111:
         data_in[6] <= data;
        0100:
         data_in[7] <= data;
      default:
             data_in[0] <= data_in[0];
      endcase
        end
        if(read_en) begin
        case (addr)
      0001:
         data_out <= data_in[0];
        0010:
         data_out <= data_in[1];
        0011:
         data_out <= data_in[2];
        0100:
         data_out <= data_in[3];
        0101:
         data_out <= data_in[4];
        0110:
         data_out <= data_in[5];
        0111:
         data_out <= data_in[6];
        0100:
         data_out <= data_in[7];
      default:
      endcase
        end
        end
endmodule
这是硬件的源代码。其中第一二位默认显示“1”和“2”这是设置signals
静态地址对齐。
在软件利用这句话写的时候没有任何现象.IOWR(DISPLAY_0_BASE,0x30,5); //display(可以认为程序里就这一句话)
下面是debug时memory窗口
很奇怪,我在display.v里用了8个寄存器,它们的地址是怎么分配的呢?
为什么IOWR时memory没有任何改变?
恳请高手帮忙
关键词: 自定义     外设     数码     扫描     问题     state     beg
