电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 关于vector.c的问题
共4条 1/1 1 跳转至页
关于vector.c的问题
2011-06-17 15:23:55     打赏
/* THIS SAMPLE CODE IS PROVIDED AS IS AND IS SUBJECT TO ALTERATIONS. FUJITSU */
/* MICROELECTRONICS ACCEPTS NO RESPONSIBILITY OR LIABILITY FOR ANY ERRORS OR */
/* ELIGIBILITY FOR ANY PURPOSES.                                             */
/*            (C) Fujitsu Microelectronics (Shanghai) Co., LTD.              */
  VECTORS.C
  - Interrupt level (priority) setting
  - Interrupt vector definition
  29.09.04  1.00   HWe    V30L29
#include "mb95200.h"
   InitIrqLevels()
   This function  pre-sets all interrupt control registers. It can be used
   to set all interrupt priorities in static applications. If this file
   contains assignments to dedicated resources, verify  that the
   appropriate controller is used.
   NOTE: value 0xFF disables the interrupt and value 0 sets highest priority.
   NOTE: For all resource interrupts exists 3 Interrupt level registers (ILRx).
         Each register sets the level for 4 different resources (IRQx).
   NOTE: This list is prepared for the 8FX-emulation chip MB95FV100 'Horn'.
         Not all resources will be supported by all 8FX-devices
void InitIrqLevels(void)
    ILR0 = 0xFF;      //  IRQ0:  external interrupt ch0 | ch4
                      //  IRQ1:  external interrupt ch1 | ch5
                      //  IRQ2:  external interrupt ch2 | ch6
                      //  IRQ3:  external interrupt ch3 | ch7
    ILR1 = 0xFF;      //  IRQ4:  UART/SIO ch0
                      //  IRQ5:  8/16-bit timer ch0 (lower)
                      //  IRQ6:  8/16-bit timer ch0 (upper)
                      //  IRQ7:  LIN-UART (reception)
    ILR2 = 0xFF;      //  IRQ8:  LIN-UART (transmission)
                      //  IRQ9:  8/16-bit PPG ch1 (lower) | UART/SIO ch1
                      //  IRQ10: 8/16-bit PPG ch1 (upper) | I2C ch1
                      //  IRQ11: 16-bit reload timer ch0
    ILR3 = 0xFF;      //  IRQ12: 8/16-bit PPG ch0 (upper)
                      //  IRQ13: 8/16-bit PPG ch0 (lower)
                      //  IRQ14: 8/16-bit timer ch1 (upper)
                      //  IRQ15: 16-bit PPG ch0 + ch2
    ILR4 = 0xFF;      //  IRQ16: 16-bit reload timer ch1 | I2C ch0
                      //  IRQ17: 16-bit PPG ch1
                      //  IRQ18: 10-biat A/D-converter
                      //  IRQ19: Timebase timer
    ILR5 = 0xFF;      //  IRQ20: Watch timer / counter
                      //  IRQ21: external interrupt ch 8-11 <<<--- Level 01
                      //  IRQ22: 8/16-bit timer ch1 (lower) | external interrupt ch 12-15
                      //  IRQ23: Flash | Custom ch1
   Prototypes
   Add your own prototypes here. Each vector definition needs is proto-
   type. Either do it here or include a header file containing them.
__interrupt void DefaultIRQHandler (void);
   Vector definiton
   Use following statements to define vectors.
   All resource related vectors are predefined.
   Remaining software interrupts can be added hereas well.
#pragma intvect DefaultIRQHandler 0   //  IRQ0:  external interrupt ch4
#pragma intvect DefaultIRQHandler 1   //  IRQ1:  external interrupt ch5
#pragma intvect DefaultIRQHandler 2   //  IRQ2:  external interrupt ch2 | ch6
#pragma intvect DefaultIRQHandler 3   //  IRQ3:  external interrupt ch3 | ch7
#pragma intvect DefaultIRQHandler 4   //  IRQ4:  UART/SIO ch0
#pragma intvect DefaultIRQHandler 5   //  IRQ5:  8/16-bit timer ch0 (lower)
#pragma intvect DefaultIRQHandler 6   //  IRQ6:  8/16-bit timer ch0 (upper)
#pragma intvect DefaultIRQHandler 7   //  IRQ7:  LIN-UART (reception)
#pragma intvect DefaultIRQHandler 8   //  IRQ8:  LIN-UART (transmission)
#pragma intvect DefaultIRQHandler 9   //  IRQ9:  8/16-bit PPG ch1 (lower) | UART/SIO ch1
#pragma intvect DefaultIRQHandler 10  //  IRQ10: 8/16-bit PPG ch1 (upper) | I2C ch1
#pragma intvect DefaultIRQHandler 11  //  IRQ11: 16-bit reload timer ch0
#pragma intvect DefaultIRQHandler 12  //  IRQ12: 8/16-bit PPG ch0 (upper)
#pragma intvect DefaultIRQHandler 13  //  IRQ13: 8/16-bit PPG ch0 (lower)
#pragma intvect DefaultIRQHandler 14  //  IRQ14: 8/16-bit timer ch1 (upper)
#pragma intvect DefaultIRQHandler 15  //  IRQ15: 16-bit PPG ch0 + ch2
#pragma intvect DefaultIRQHandler 16  //  IRQ16: 16-bit reload timer ch1 | I2C ch0
#pragma intvect DefaultIRQHandler 17  //  IRQ17: 16-bit PPG ch1
#pragma intvect DefaultIRQHandler 18  //  IRQ18: 10-biat A/D-converter
#pragma intvect DefaultIRQHandler 19  //  IRQ19: Timebase timer
#pragma intvect DefaultIRQHandler 20  //  IRQ20: Watch timer / counter
#pragma intvect DefaultIRQHandler 21  //  IRQ21: external interrupt ch 8-11
#pragma intvect DefaultIRQHandler 22  //  IRQ22: 8/16-bit timer ch1 (lower)
#pragma intvect DefaultIRQHandler 23  //  IRQ23: Flash | Custom ch1
__interrupt
    __DI();             // disable interrupts(我想知道这句的定义在哪里?)
    while(1)
        __wait_nop();   // halt system
关键词: 关于     vector.c     问题     interrupt
2011-06-17 15:56:46     打赏
说实话不是太明白!我想知道它在什么地方定义的,还有它是怎么实现关闭所有中断的!谢谢!
2011-06-17 16:40:35     打赏
我怎么没找到了,你能告诉我在哪里吗?我自己看一下!谢谢!
2011-06-17 17:05:32     打赏
好的,知道了。谢谢!
共4条 1/1 1 跳转至页
