电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Package Thermal Resistance Values (Theta
Package Thermal Resistance Values (Theta JA, Theta JC) for Temperature Sensors a
2012-04-04 07:55:23     打赏
Package Thermal Resistance Values (Theta JA, Theta JC) for Temperature Sensors and 1-Wire Devices
关键词: Theta JA, Theta JC, theta-ja, theta-jc, self heating, thermal dissipation, heat dissipation, power dissipation, thermal resistance, junction to case, junction to ambient, temperature, sensor, temperature sensor, thermal
Abstract: Two common thermal-resistance values measured for IC packages are junction to ambient (Theta JA) and junction to case (Theta JC). These parameters are useful for calculating maximum power dissipation and self-heating, and for comparing package types. Theta JA and Theta JC values are presented here for select Maxim temperature sensors and 1-Wire® devices. Examples for calculating the values are given.
 Package Thermal Resistance Values (Theta JA, Theta JC) for Temperature Sensors and 1-Wire Devices.pdf
关键词: Package     Thermal     Resistanc
