The makers of handheld medical, industrial and consumer devices use a wide variety of high resolution, small to medium sized color TFT LCD displays. The power supply designers for these displays must contend with shrinking board area, tight schedules, and variations in display types and feature requirements. The LTC3524 simplifi es the designer’s job by combining a versatile, easily programmed, TFT LCD bias supply and white LED backlight driver in a low profi le 4mm ×4mm QFN package.
Versatile TFT LCD Bias Supply and White LED Driver.pdf
