电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Deglitching Techniques for High-Voltage
Deglitching Techniques for High-Voltage R-2R DACs
2012-04-12 18:25:00     打赏
关键词: Deglitching Techniques for High-Voltage R-2R DACs
In an R-2R DAC design with supply voltages exceeding ±5V, large voltage glitches (up to 1.5V) can occur during the DAC's major-carry transitions. These glitches can propagate through the output buffer amplifier and appear at output. The slewing of the level shifters that control the top (VREF+) and bottom (VREF-) single-pole double-throw switches (S0 to SN) causes the glitches
 Deglitching Techniques for High-Voltage R-2R DACs.pdf
关键词: Deglitching     Techniques     Hi
