关键词: DAQ, data acquisition, windows-based, pc-based, ADC, analog to digital converter, ADCs, converters, RS232, AVR, resistor divider, resistive divider, signal conditioning, rs-232
Abstract: This application note describes the design of a PC-based, 14-bit data acquisition system. It takes a system approach, includes all the necessary building blocks: analog, digital, hardware, and software. It discusses each step, testing systems separately before integrating them, and detailing pitfalls learned along the way.
Practical Data Acquisition using a Windows¹-based Power Meter.pdf
