电子产品世界 » 论坛首页 » 企业专区 » Renesas » 定时器外部中断红外通讯问题
共3条 1/1 1 跳转至页
定时器外部中断红外通讯问题
2012-09-18 21:13:09     打赏
用定时器做通讯时钟,外部触发中断做接收引脚,请教下列几个问题,第一是校验位,偶校验,但不清楚确认1个数的方法;第二是不知道发送时数值从哪里来;第三是觉得发送和接收的波特率和时钟频率不大对,不知怎么确认;第四是不知道0和1怎么判断的?请指导!
关键词: 定时器     外部     中断     红外     通讯     问题
2012-09-19 11:19:07     打赏
我是红外接收波特率1200bps,我定时器是按照这个时间中断读每位的数据吗?我发送应该是38khz,我数据从哪里来呢,定义一个字节,一位一位移动,那校验位要求怎么处理?下面是源代码,请帮忙看看。
void UartIRInit(void)
 /*----set INTP3-----------------------------------------------------------*/
 PIF3 = 0;
 PM3.1 = 1;
 EGP = 0x00; //EGP3=0
 EGN = 0x08; //EPN3=1
 PMK3 = 0;  //enable interrupt
 PPR3 = 1;  //low priority
 /*---set TMH1-------------------------------------------------------------*/
 TMHMD1 = 0;
 TMHMD1 = 0x30;//00110000
 CMP01 = 103; //8000000/64/104=1201.92
 TMMKH1 = 0; //enble interrupt
 TMPRH1 = 0; //high priority
 /*---set TMH0-------------------------------------------------------------*/
 TMHMD0 = 0;
 PM3.2 = 0;
 P3.2 = 0;
 CMP00 = 104;//8000000/(104+1) = 76.190K
 TMHMD0 = 0x01;//enable output
 TMMKH0 = 1; //disable interrupt
 /*--------byte set--------------------------------------------------------*/
 //RXIR=0;
 //TXIR
 UartIR.Monit500ms = 0;
 UartIR.Monit5s = 0;
 UartIR.Lapse30ms = 0;
 FUartIR_RStart = 0;
 FUartIR_REnd = 0;
 FUartIR_Treat = 0;
 FUartIR_Ting = 0;
__interrupt void IntP3(void)
 CMP01 = 51;
 TMHE1 = 1;
 PMK3 = 1;
 IRB = 0;//infrade buf
 IRBits = 0;
 IRParity = 0;
__interrupt void IntTMH1(void)
 TMHE1 = 0;
 CMP01 = 103;
 TMHE1 = 1;
 if (FUartIR_Ting == 1)
  if (IRBits < 9)  //data bit
   if ((IRB&0x01) == 0x0)
    TMHE0 = 1;
   else
    IRParity++;  //even parity
    TMHE0 = 0;
    P3.2 = 0;
   IRB >>= 1;
   IRBits++;
  else if (IRBits == 9)  //parity bit
   if (IRParity.0 == 0)
    TMHE0 = 1;//even 1 bits,even parity is 0
   else
    TMHE0 = 0;
    P3.2 = 0;
   IRBits++;
  else if (IRBits == 10)//stop bit
   TMHE0 = 0;
   P3.2 = 0;
   IRBits++;
  else if (IRBits == 11)
   TMHE1 = 0;//end the transmit
#ifndef __IR30MS
   if (UartIR.FENum != 0)
    UartIR.FENum--;
    IRB = 0xfe;
    IRBits = 1; //start bit
    IRParity = 0;
    CMP01 = 103;
    TMHE1 = 1;
    TMHE0 = 1;
   else if (UartIR.DataNum < (UartIR.Buf[9]+12))
    IRB = UartIR.Buf[UartIR.DataNum++];
    IRBits = 1;//start bit
    IRParity = 0;
    CMP01 = 103;
    TMHE1 = 1;
    TMHE0 = 1;//start bit
   else
    FUartIR_Ting = 0;
    FUartIR_RStart = 0;
    PIF3 = 0;
    PMK3 = 0;//enable P5 interrupt
    TMHE1 = 0;//stop TMH1
#endif
 /*-----receive state------------------------------------------------------*/
 else
  if (IRBits == 0) //the first judge is 0.416ms
   if (P3.1 == 1)//start bit is error
    PMK3 = 0;
    TMHE1 = 0;//end the receive
   else
    IRBits = 1;//++;
  else if (IRBits < 9)//data bits
   IRB >>= 1;
   if (P3.1 == 1)
    IRB |= 0x80;
    IRParity++;
   IRBits++;
   if (((P3.1==0)&&(IRParity.0==0)) ||
      ((P3.1==1)&&(IRParity.0==1))) //even check right
    IRBits++;
   else
    PMK3 = 0;
    TMHE1 = 0; //stop receive
    IRBits = 0;
  else//end bit
   PMK3 = 0;//enable receive last byte
   TMHE1 = 0;//because priority of TMH1 higher than P5
   if (P3.1 == 1)//stop bit
    UartIR.Monit5s = 0;
    if (FUartIR_RStart == 0)
     if (IRB == 0x68)
      FUartCom = 1;
      UartIR.Buf[0] = 0x68;
      UartIR.DataNum = 1;
      FUartIR_RStart = 1;
    else
     if (UartIR.DataNum < MAXNUM_UART)
      UartIR.Buf[UartIR.DataNum] = IRB;
      if (UartIR.DataNum == 7)
       if (IRB != 0x68)
        FUartIR_RStart = 0;
      else if (UartIR.DataNum >= (UartIR.Buf[9]+11))
       if (IRB == 0x16)
        PMK3 = 1;   //end the receive
        FUartIR_REnd = 1;
       FUartIR_RStart = 0;
      UartIR.DataNum++;
     else
      FUartIR_RStart = 0;
2012-09-20 14:23:01     打赏
我先说下第一个,发送数据肯定是一帧数据发送的,然后采用偶校验方式,那偶校验时我是不是发一个bit的0或1做为校验位,这个位我怎么判断该发送0还是1呢?
共3条 1/1 1 跳转至页
