电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » abel371082的进程贴(VHDL)
2012-11-05 23:29:00     打赏
个人比较喜欢VHDL,所有的代码都准备用VHDL来写。
实验一的程序如下:
关键词: abel371082     进程
2012-11-05 23:31:26     打赏
实验二的源码
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY LED IS
    PORT(
         CLK_IN         :IN STD_LOGIC;  -- the input for clk of 50M
         LED_CONTROL    :OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END LED;
ARCHITECTURE BEHAVE OF LED IS
SIGNAL CLK_25M          : STD_LOGIC;
SIGNAL CLK_NUM           : STD_LOGIC_VECTOR(24 DOWNTO 0);--
SIGNAL LED            : STD_LOGIC_VECTOR(7 DOWNTO 0);
BEGIN
    PROCESS(CLK_IN)   --the clk of 25M
    BEGIN
        IF CLK_IN'EVENT AND CLK_IN='1' THEN
            CLK_25M<=NOT CLK_25M;
        END IF;
    END PROCESS;
    PROCESS(CLK_25M)   --the clk of 25M
    BEGIN
        IF CLK_25M'EVENT AND CLK_25M='1' THEN
            CLK_NUM<=CLK_NUM+"0000000000000000000000001";
            IF CLK_NUM = "0000000000000000000000000" THEN
                LED<= NOT LED;
            END IF;
        END IF;
    END PROCESS;
    LED_CONTROL<=LED;
END;
