电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 单片机外接晶振大小的选择依据
共5条 1/1 1 跳转至页
单片机外接晶振大小的选择依据
2013-05-25 22:36:43     打赏
之前都是参考别人的电路图来绘制自己的电路图,对于最小系统晶振的选择这一块没有深入的探究过,今天看到一段注解,由此想到了这个问题,特来请教请教:
1. If the system clock source selected by user fails to startup, the SystemInit()function will do nothing and HSI still used as system clock source. User can  add some code to deal with this issue inside the SetSysClock() function.
2. The default value of HSE crystal is set to 8 MHz (or 25 MHz, depedning on the product used), refer to "HSE_VALUE" define in "stm32f10x.h" file. When HSE is used as system clock source, directly or through PLL, and you are using different crystal you have to adapt the HSE value to your own configuration.
这个如何根据产品需要来确定呢?是不是选择和HSI大小一致的效果更好呢?
另外就是晶振的负载电容选取这一块有什么注意事项吗?还望大神们多多指点,在此谢过。
关键词: 晶振     负载电容
2013-05-25 22:42:36     打赏
The System clock configuration functions provided within this file assume that:
        - For Low, Medium and High density Value line devices an external 8MHz
          crystal is used to drive the System clock.
        - For Low, Medium and High density devices an external 8MHz crystal is
        - For Connectivity line devices an external 25MHz crystal is used to drive
          the System clock.
2013-05-26 13:23:27     打赏
这个需要综合考虑呢,还得以本为本啊,多谢楼主指点
2013-05-26 13:24:22     打赏
1、在一般RTC实时时钟的应用中,希望在系统主电源关闭之后,能用最小的消耗来维持RTC时钟的运行,当使用内部LSI为RTC时钟源时,可以节省一个外部LSE振荡器,但付出的代价是,需要更大的电流消耗和计时的不精确。
一般都选择使用外部32K晶振作为RTC的专供时钟,计时精准,功耗低。
2、现在市场上的32K晶振有两种,一种是12P负载电容晶振,一种是6P负载电容晶振,虽然6P的耗电低,但其价格高,一般选12P负载电容的32K晶振。
2013-05-26 19:09:51     打赏
共同学习,多多指教啊
共5条 1/1 1 跳转至页
