电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 二极管参数中英文对照表
二极管参数中英文对照表
2014-06-12 10:32:09     打赏
二极管参数中英文对照表
文字符号中文English
IF(AV)正向平均电流(整流管)mean foreard current (of diode)
IT(AV)通态平均电流mean on-state current
VRSM反向不重复峰值电压non-reetitive peak reverse voltage
VRRM反向重复峰值电压repetitive peak reverse voltage
VDSM断态不重复峰值电压non-repetitive peak off-state voltage
VDRM断态重复峰值电压repetitive peak off-state voltage
VFM正向峰值电压(整流管)peak forward voltage (of diode)
VTM通态峰值电压peak on-state voltage
Tjm最高等效结温maximum virtual junction temperature
F紧固力mounting force
IRRM反向重复峰值电流repetitive peak reverse current
IDRM断态重复峰值电流repetitive peak of-state current
VGT门极触发电压gate trigger voltage
IGT门极触发电流gate trigger current
Rjc结壳热阻junction-case thermal resistance
Qrr反向恢复电荷reverse recovery charge
ITM通态峰值电流peak on-state current
IFM正向峰值电流(整流管)peak forward current (of diode)
ITSM通态浪涌电流surge on-state current
dv/dt断态电压临界上升率critical rate of rise of off-state voltage
di/dt通态电流临界上升率critical rate of rise of on-state current
tgt门极控制开通时间gate controlled turn-on time
tq电路换向关断时间cricuit commutated turn-off time
IRMS通态方均根电流R.M.S. on-state current
(dv/dt)c换向电压临界上升率(双向晶闸管)critical rate of rise of commutating voltage(of bi-directional thyristor)
trr反向恢复时间(二极管的)reverse recovery time (of diode)
ton开通时间turn on time
ts存储时间storage time
tf下降时间fall time
