电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 谁遇见过这个错误啊,怎么改正啊
谁遇见过这个错误啊,怎么改正啊
2014-09-04 12:36:07     打赏
Building configuration: menu_test - Debug
Updating build tree...
Linking
Error[e104]: Failed to fit all segments into specified ranges. Problem
discovered in segment CODE. Unable to place 39 block(s) (0x1c32 byte(s)
total) in 0x1986 byte(s) of memory. The problem occurred while processing the
segment placement command "-P(CODE)CODE=E000-FF7F", where at the moment of
placement the available memory ranges were "CODE:e5fa-ff7f"
Error while running Linker
Total number of errors: 2
Total number of warnings: 0
2014-09-04 16:32:04     打赏
嗯,确实是,不过代码不能删,用笨方法写的菜单,选错片子型号了,不好意思
