电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 时钟上升沿下降沿同时采样仿真数据不对,求大神解救
2015-03-21 10:51:27     打赏
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE IEEE.std_logic_arith.ALL;
ENTITY SampleFallingRising IS
	PORT(-------------clock signal-----------------
		 clk_200m : IN std_logic;
		 -------------input signal-----------------
		 dq       : IN std_logic_vector(7 DOWNTO 0);
		 -------------output signal---------------
		 dq_out   : OUT std_logic_vector(15 DOWNTO 0)
END SampleFallingRising;
ARCHITECTURE behave OF SampleFallingRising IS
	SIGNAL clk_200mn :std_logic;
	SIGNAL dq_temp1,dq_temp2 : std_logic_vector(7 DOWNTO 0);
BEGIN
	clk_200mn<= NOT clk_200m;
	rising_sample :PROCESS(clk_200m)
	BEGIN
		IF(clk_200m'event AND clk_200m='1') THEN
			dq_temp1(7 DOWNTO 0)<=dq(7 DOWNTO 0);
		END IF;
	END PROCESS rising_sample;
	falling_sample :PROCESS(clk_200mn)
	BEGIN
		IF(clk_200mn'event AND clk_200mn='1') THEN
--			dq_out(15 DOWNTO 8)<=dq_temp(7 DOWNTO 0);
			dq_temp2(7 DOWNTO 0)<=dq(7 DOWNTO 0);
		END IF;
	END PROCESS falling_sample;
	concatenation :PROCESS(clk_200m)
	BEGIN
			dq_out<=dq_temp1&dq_temp2;
		END IF;
	END PROCESS concatenation;
END behave;
仿真图
