电子产品世界 » 论坛首页 » 高校专区 » 湖北理工TEA » A4 组 丁奇宁 汪克俊 李伟 光立方频谱
2016-04-15 23:51:50     打赏
目前计划在4.16~4.17:1.完成对音乐频谱原理及光立方电路理论的学习,2.耐心等待快递
4.25 灯架子已经焊好,傅里叶变换部分的程序和AD模块的程序正在着手研究。
AD转换部分目前遇到了一些问题
5.15 完成
附上傅里叶变换部分的程序代码
typedef unsigned char uchar;
typedef unsigned int  uint;
#define channel      0x01		  //设置AD通道为 P1.0
#define ADC_POWER   (1<<7) #define ADC_SPEEDHH (0x03<<5) #define ADC_START (1<<3) #define PADCH (1<<5) #define ADC_FLAG (1<<4) code char SIN_TAB[128]={0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102, 105,108,112,114,117,119,121,123,124,125,126,126,126,126,126, 125,124,123,121,119,117,114,112,108,105,102,98,94,89,85,80,75, 70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,-30,-36,-42, -48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,-105,-108,-112, -114,-117,-119,-121,-123,-124,-125,-126,-126,-126,-126,-126,-125, -124,-123,-121,-119,-117,-114,-112,-108,-105,-102,-98,-94,-89,-85, -80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,-12,-6}; //放大128倍后的cos整数表(128) code char COS_TAB[128]={127,126,126,125,124,123,121,119,117,114,112,108,105,102,98,94, 89,85,80,75,70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24, -30,-36,-42,-48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102, -105,-108,-112,-114,-117,-119,-121,-123,-124,-125,-126,-126,-126, -126,-126,-125,-124,-123,-121,-119,-117,-114,-112,-108,-105,-102, -98,-94,-89,-85,-80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18, -12,-6,0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102, 105,108,112,114,117,119,121,123,124,125,126,126}; //采样存储序列表 code char LIST_TAB[128] = {0,64,32,96,16,80,48,112,8,72,40,104,24,88,56,120,4,68,36,100,20,84,52,116, 12,76,44,108,28,92,60,124,2,66,34,98,18,82,50,114,10,74,42,106,26,90,58, 122,6,70,38,102,22,86,54,118,14,78,46,110,30,94,62,126,1,65,33,97,17,81,49, 113,9,73,41,105,25,89,57,121,5,69,37,101,21,85,53,117,13,77,45,109,29,93,61, 125,3,67,35,99,19,83,51,115,11,75,43,107,27,91,59,123,7,71,39,103,23,87,55, 119,15,79,47,111,31,95,63,127}; /*uint8 LED[32]={0x80,0xC0,0xE0,0xF0, 0xF8,0xFC,0xFE,0xFF, };*/ uchar i = 0,j = 0,k = 0; // uchar b = 0,p = 0;//anum; // int Temp_Real = 0,Temp_Imag = 0,temp = 0; //中间临时变量 uint TEMP1 = 0,maxa = 0; //中间临时变量 int xdata Fft_Real[128]; //FFT的实部 int xdata Fft_Image[128]; //FFT的虚部 //uchar xdata LED_TAB2[16]; //记录 漂浮物 是否需要 停顿一下 uchar xdata LED_TAB[16]; //记录红色柱状 //uchar xdata LED_TAB1[16]; //记录 漂浮点 void FFT() //基2fft { for(i=1; i<=7; i++) /* for(1) */ { b=1; b <<=(i-1); //碟式运算,用于计算隔多少行计算例如 第一极 1和2行计算 for(j=0; j<=b-1; j++) /* for (2) */ { p=1; p <<= (7-i); p = p*j; for(k=j; k<128; k=k+2*b) /* for (3) */ { Temp_Real=Fft_Real[k]; Temp_Imag=Fft_Image[k]; temp=Fft_Real[k+b]; Fft_Real[k]=Fft_Real[k]+((Fft_Real[k+b]*COS_TAB[p])>>7)+((Fft_Image[k+b]*SIN_TAB[p])>>7);
				Fft_Image[k]=Fft_Image[k]-((Fft_Real[k+b]*SIN_TAB[p])>>7)+((Fft_Image[k+b]*COS_TAB[p])>>7);
				Fft_Real[k+b]=Temp_Real-((Fft_Real[k+b]*COS_TAB[p])>>7)-((Fft_Image[k+b]*SIN_TAB[p])>>7);
				Fft_Image[k+b]=Temp_Imag+((temp*SIN_TAB[p])>>7)-((Fft_Image[k+b]*COS_TAB[p])>>7);          // 移位.防止溢出. 结果已经是本值的 1/64
				Fft_Real[k] >>= 1;
				Fft_Image[k] >>= 1;
				Fft_Real[k+b] >>= 1;
				Fft_Image[k+b] >>= 1;
	for(j=0;j<16;j++) //16分频 { TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求各频段幅值
		if(TEMP1<1) TEMP1=0; LED_TAB[j] = TEMP1; if(LED_TAB[j]>maxa) maxa = LED_TAB[j];   //maxa是本次转换的最大值
	if(maxa>16) //分级量化
		maxa /= 16;
		for(j=0;j<16;j++) LED_TAB[j] /= maxa; //LED_TAB[j] = 0; } } void delay2us(void) //2us延时 { unsigned char a=0,b=0; for(b=112;b>0;b--)
        for(a=113;a>0;a--);
/* void delayms(void)   //2us延时
/*     unsigned char a,b;
/*     for(b=222;b>0;b--)
/*         for(a=223;a>0;a--);
