电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » docker中安装mqtt服务端
共3条 1/1 1 跳转至页
docker中安装mqtt服务端
2017-11-16 16:18:17     打赏
MQTT(Message Queuing Telemetry Transport,消息队列遥测传输)是IBM开发的一个即时通讯协议,有可能成为物联网的重要组成部分。
首先创建实例
docker run -ti -h mqtt --name mqtt_1884 -p 21884:1884 ubuntu:14.04
然后更新
apt-get update
apt-get install libc-ares-dev uuid-dev wget make libssl-dev g++
wget http://mosquitto.org/files/source/mosquitto-1.4.14.tar.gz
tar zxfv mosquitto-1.4.14.tar.gz
cd mosquitto-1.4.14
make
make install
然后添加用户
adduser mosquitto
cp /etc/mosquitto/mosquitto.conf.example /etc/mosquitto/mosquitto.conf
vi /etc/mosquitto/mosquitto.conf
去掉端口的注释,改为1884
mosquitto -v -c /etc/mosquitto/mosquitto.conf
2017-11-16 16:19:35     打赏
测试,接收端:
import paho.mqtt.client as mqtt
def on_connect(client, userdata, flags, rc):
  client.subscribe("MikuQ.com/#")
def on_message(client, userdata, msg):
  print msg.payload.decode("utf-8")
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect("192.168.1.1", 21884, 50)
client.loop_forever()
2017-11-16 16:19:56     打赏
测试,发送端:
client.publish("MikuQ.com/android/command", "MQTT")
参考了酋猫的例子。
共3条 1/1 1 跳转至页
