电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » candy
candy
2018-01-30 12:10:14     打赏
There are N children standing in a line. Each child is assigned a rating value.
You are giving candies to these children subjected to the following requirements:
  • Each child must have at least one candy.
  • Children with a higher rating get more candies than their neighbors.
What is the minimum candies you must give?
题意:N个孩子站成一排,每个孩子分配一个分值,给这些孩子派发糖果,
满足如下:
每个孩子至少一个,分值更高的孩子比他的相邻位的孩子获得更多的糖果
    求至少分发多少个糖果?
思路:
从左到右遍历,保证该方向上分数更大的获得的糖果更多;
从右到左遍历,保证这个方向上分数更大的获得的糖果跟多;
[cpp] view plain copy
  1. class Solution
  2. {
  3. public:
  4.     int candy(vector<int>& ratings)
  5.     {
  6.         int len = ratings.size();
  7.         if (len==1)
  8.         {
  9.             return 1;
  10.         }
  11.
  12.         int sum = 0;
  13.         vector<int> tmpVec(len, 1); //初始化每个孩子的糖果数设置为1
  14.
  15.         //从左扫描
  16.         for (int i=1; i<len; i++)
  17.         {
  18.             if (ratings[i]>ratings[i-1])
  19.             {
  20.                 tmpVec[i] = tmpVec[i - 1] + 1;
  21.             }
  22.         }
  23.
  24.         //从右向左
  25.         for (int i=len-2; i>=0; i--)
  26.         {
  27.             if (ratings[i]>ratings[i + 1] && tmpVec[i] <= tmpVec[i + 1])
  28.             {
  29.                 tmpVec[i] = tmpVec[i + 1] + 1;
  30.             }
  31.         }
  32.
  33.         for (int i=0; i<len; i++)
  34.         {
  35.             sum += tmpVec[i];
  36.         }
  37.
  38.         return sum;
  39.     }
  40. };
