电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 液晶显示屏LCD1602初始化失败,哪位帮我分析分析。。
2021-05-07 22:43:51     打赏
上图是程序的运行结果,初步判断是液晶显示屏LCD1602初始化失败,哪位帮我分析分析源码?。。
//函数声明
void Read_Busy();        //忙检测函数
void Lcd1602_Write_Cmd(unsigned char cmd);        //写命令
void Lcd1602_Write_Data(unsigned char dat);        //写数据
void LcdSetCursor(unsigned char x,unsigned char y);        //坐标显示
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);        //显示字符
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str);        //显示字符串
void InitLcd1602();        //初始化
#include"lcd.h"
void Read_Busy()           //忙检测函数,判断bit7是0,允许执行;1禁止
    unsigned char sta;
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,释放总线
    }while(sta & 0x80);
/*void delay(uint n)
    uint x,y;
    for(x=n;x>0;x--)
    for(y=110;y>0;y--);
void Lcd1602_Write_Cmd(unsigned char cmd)     //写命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
         delay(5);
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //写数据
     Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
           delay(5);
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐标显示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
    else
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置显示一个字符
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
        X |= 0x80; //算出指令码
        Lcd1602_Write_Cmd(X); //发命令字
        Lcd1602_Write_Data(DData); //发数据
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //显示字符串
    LcdSetCursor(x,y);      //当前字符的坐标
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
        void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打开,5*8,8位数据
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
关键词: LCD1602     显示屏     液晶显示模块     LCM
