#include
#define uchar unsigned char
#define uint unsigned int
sbit a=P2^2; //138编码器
sbit b=P2^3; //138编码器
sbit c=P2^4; //138编码器
sbit scl=P2^1;
sbit sda=P2^0;
bit write=0;
uchar num1,num;
uchar code d[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay()
void start()
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop()
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
unsigned char writebyte (unsigned char dat)
unsigned char a=0,b=0;//最大255,一个机器周期为1us,最大延时255us。
for(a=0;a<8;a++)//要发送8位,从最高位开始
sda=dat>>7; //起始信号之后SCL=0,所以可以直接改变SDA信号
dat=dat<<1;
delay();
scl=1;
delay();//建立时间>4.7us
scl=0;
delay();//时间大于4us
sda=1;
delay();
scl=1;
while(sda)//等待应答,也就是等待从设备把SDA拉低
b++;
if(b>200) //如果超过2000us没有应答发送失败,或者为非应答,表示接收结束
scl=0;
delay();
return 0;
scl=0;
delay();
return 1;
uchar readbyte()
uchar i,k;
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;
delay();
scl=0;
delay();
return k;
void write_byte(uchar address,uchar date)
start();
writebyte(0xa0);
writebyte(address);
writebyte(date);
stop();
uchar read_byte(uchar address)
uchar date;
start();
writebyte(0xa0);
writebyte(address);
start();
writebyte(0xa1);
date=readbyte();
stop();
return date;
void display(uchar shi,uchar ge)
a=0;
b=0;
c=0;
P0=d[ge]; // 将数据送到P0口的数码管
P0=0;
a=1;
b=0;
c=0;
P0=d[shi];
P0=0;
void ahead()
sda=1;
delay();
scl=1;
delay();
void main()
ahead();
num=read_byte(2);
if(num>100)
num=0;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65336-50000)%256;
EA=1;
ET0=1;
TR0=1;
while(1)
display(num/10,num%10);
if(write==1)
write=0;
write_byte(2,num);
void t0()interrupt 1
num1++;
if(num1==20)
num1=0;
write=1;
num++;
if(num==100)
num=0;
无法进行掉电后数据的保护
共1条
单片机中模拟I2C总线来控制E2pROM芯片进行掉电保护?
关键词: 模拟 总线 E2pROM 掉电 保护
共1条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
