我正在RV1126上做视频/图像处理,目前单张图片处理时间太长,处理视频帧率达不到。有大佬了解这块板子上如何进行处理速度提升吗?
cmake编译rga的时候出现以下问题
我已经按照linux-rga里的README修改了buildroot.cmake里的以下配置
1. 指定TOOLCHAIN_HOME为交叉编译工具的路径
2. 指定CMAKE_C_COMPILER为gcc编译命令的路径
3. 指定CMAKE_CXX_COMPILER为g++编译命令的路径
请问这个问题有什么解决方法吗?
decatur@ubuntu:~/rv1126_rv1109_linux_release_20211022/external/linux-rga/build$ ../cmake-linux.sh
default to Release build for GCC builds
RGA is compiling with cmake
Generated version.h
set buildroot toolchain
-- The C compiler identification is GNU 6.3.1
-- The CXX compiler identification is GNU 6.3.1
-- Check for working C compiler:
/home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc
-- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler:
/home/decatur/rv1126_rv1109_linux_release_20211022/prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++
-- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at CMakeLists.txt:83 (install):
install TARGETS given no LIBRARY DESTINATION for shared library target
"rga".
-- Configuring incomplete, errors occurred!
See also "/home/decatur/rv1126_rv1109_linux_release_20211022/external/linux-rga/build/CMakeFiles/CMakeOutput.log".
make: *** 没有指明目标并且找不到 makefile。 停止。
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
