电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » RV1103使用v4l2-ctl命令录制视频,下完sensorsetting后卡
RV1103使用v4l2-ctl命令录制视频,下完sensorsetting后卡住
2024-09-05 15:02:30     打赏
使用v4l2-ctl --device=/dev/video11 --set-fmt-video=width=640,height=480,pixelformat=NV12 --stream-mmap --stream-to=video50.yuv --stream-count=60录制视频的时候,下完sensor setting就卡住了,有没有大佬看一下是什么问题啊
log如下,但是使用的不是sc3336 sensor,用的是gc030a
0
[ 1199.030309] stream_cif_mipi_id0: s_power 1, entity use_count 1
[ 1199.035727] rkisp_hw ffa00000.rkisp: set isp clk = 198000000Hz
[ 1199.035825] rkcif-mipi-lvds: sditf_reinit_mode, mode->rdbk_mode 0, mode->name rkisp-vir0, link_mode 1
[ 1199.037392] rkcif-mipi-lvds: stream[0] start streaming
[ 1199.037695] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream on, src_sd: fefec87c, sd_name:rockchip-csi2-dphy0
[ 1199.037728] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream ON
[ 1199.037820] rockchip-csi2-dphy0: dphy0, data_rate_mbps 506
[ 1199.037910] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1199.037968] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1199.038003] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 128
[ 1199.038216] WENJIE:: sc3336_write_reg success
[ 1199.038247] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x80
[ 1199.038272] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 128
[ 1199.038445] WENJIE:: sc3336_write_reg success
[ 1199.038473] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x80
[ 1199.038495] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 128
[ 1199.038656] WENJIE:: sc3336_write_reg success
[ 1199.038680] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x80
[ 1199.038702] WENJIE:: sc3336_write_reg reg = 0xf7,len = 1, val = 1
[ 1199.038865] WENJIE:: sc3336_write_reg success
[ 1199.038890] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xf7, regs[i].val = 0x1
[ 1199.038912] WENJIE:: sc3336_write_reg reg = 0xf8,len = 1, val = 5
[ 1199.039055] WENJIE:: sc3336_write_reg success
[ 1199.039080] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xf8, regs[i].val = 0x5
[ 1199.039103] WENJIE:: sc3336_write_reg reg = 0xf9,len = 1, val = 15
[ 1199.039245] WENJIE:: sc3336_write_reg success
[ 1199.039270] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xf9, regs[i].val = 0xf
[ 1199.039291] WENJIE:: sc3336_write_reg reg = 0xfa,len = 1, val = 0
[ 1199.039433] WENJIE:: sc3336_write_reg success
[ 1199.039458] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfa, regs[i].val = 0x0
[ 1199.039480] WENJIE:: sc3336_write_reg reg = 0xfc,len = 1, val = 15
[ 1199.042277] WENJIE:: sc3336_write_reg success
[ 1199.042302] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfc, regs[i].val = 0xf
[ 1199.042312] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 0
[ 1199.042447] WENJIE:: sc3336_write_reg success
[ 1199.042460] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x0
[ 1199.042469] WENJIE:: sc3336_write_reg reg = 0x3,len = 1, val = 1
[ 1199.042598] WENJIE:: sc3336_write_reg success
[ 1199.042609] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x3, regs[i].val = 0x1
[ 1199.042617] WENJIE:: sc3336_write_reg reg = 0x4,len = 1, val = 200
[ 1199.042746] WENJIE:: sc3336_write_reg success
[ 1199.042757] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x4, regs[i].val = 0xc8
[ 1199.042766] WENJIE:: sc3336_write_reg reg = 0x5,len = 1, val = 3
[ 1199.044153] WENJIE:: sc3336_write_reg success
[ 1199.044178] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x5, regs[i].val = 0x3
[ 1199.044187] WENJIE:: sc3336_write_reg reg = 0x6,len = 1, val = 123
[ 1199.044320] WENJIE:: sc3336_write_reg success
[ 1199.044334] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x6, regs[i].val = 0x7b
[ 1199.044342] WENJIE:: sc3336_write_reg reg = 0x7,len = 1, val = 0
[ 1199.044463] WENJIE:: sc3336_write_reg success
[ 1199.044475] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x7, regs[i].val = 0x0
[ 1199.044484] WENJIE:: sc3336_write_reg reg = 0x8,len = 1, val = 6
[ 1199.044605] WENJIE:: sc3336_write_reg success
[ 1199.044613] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x8, regs[i].val = 0x6
[ 1199.044621] WENJIE:: sc3336_write_reg reg = 0xa,len = 1, val = 0
[ 1199.044740] WENJIE:: sc3336_write_reg success
[ 1199.044752] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xa, regs[i].val = 0x0
[ 1199.044759] WENJIE:: sc3336_write_reg reg = 0xc,len = 1, val = 8
[ 1199.044880] WENJIE:: sc3336_write_reg success
[ 1199.044893] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xc, regs[i].val = 0x8
[ 1199.044901] WENJIE:: sc3336_write_reg reg = 0xd,len = 1, val = 1
[ 1199.045027] WENJIE:: sc3336_write_reg success
[ 1199.045036] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xd, regs[i].val = 0x1
[ 1199.045044] WENJIE:: sc3336_write_reg reg = 0xe,len = 1, val = 232
[ 1199.045163] WENJIE:: sc3336_write_reg success
[ 1199.045172] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xe, regs[i].val = 0xe8
[ 1199.045181] WENJIE:: sc3336_write_reg reg = 0xf,len = 1, val = 2
[ 1199.045300] WENJIE:: sc3336_write_reg success
[ 1199.045309] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xf, regs[i].val = 0x2
[ 1199.045316] WENJIE:: sc3336_write_reg reg = 0x10,len = 1, val = 136
[ 1199.045435] WENJIE:: sc3336_write_reg success
[ 1199.045445] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x10, regs[i].val = 0x88
[ 1199.045452] WENJIE:: sc3336_write_reg reg = 0x12,len = 1, val = 40
[ 1199.045572] WENJIE:: sc3336_write_reg success
[ 1199.045582] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x12, regs[i].val = 0x28
[ 1199.045590] WENJIE:: sc3336_write_reg reg = 0x17,len = 1, val = 84
[ 1199.045709] WENJIE:: sc3336_write_reg success
[ 1199.045718] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x17, regs[i].val = 0x54
[ 1199.045725] WENJIE:: sc3336_write_reg reg = 0x18,len = 1, val = 18
[ 1199.045844] WENJIE:: sc3336_write_reg success
[ 1199.045854] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x18, regs[i].val = 0x12
[ 1199.045862] WENJIE:: sc3336_write_reg reg = 0x19,len = 1, val = 7
[ 1199.045981] WENJIE:: sc3336_write_reg success
[ 1199.045996] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x19, regs[i].val = 0x7
[ 1199.046004] WENJIE:: sc3336_write_reg reg = 0x1a,len = 1, val = 27
[ 1199.046128] WENJIE:: sc3336_write_reg success
[ 1199.046137] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x1a, regs[i].val = 0x1b
[ 1199.046145] WENJIE:: sc3336_write_reg reg = 0x1d,len = 1, val = 72
[ 1199.049072] WENJIE:: sc3336_write_reg success
[ 1199.049093] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x1d, regs[i].val = 0x48
[ 1199.049102] WENJIE:: sc3336_write_reg reg = 0x1e,len = 1, val = 80
[ 1199.049293] WENJIE:: sc3336_write_reg success
[ 1199.049310] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x1e, regs[i].val = 0x50
[ 1199.049319] WENJIE:: sc3336_write_reg reg = 0x1f,len = 1, val = 128
[ 1199.049503] WENJIE:: sc3336_write_reg success
[ 1199.049551] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x1f, regs[i].val = 0x80
[ 1199.049559] WENJIE:: sc3336_write_reg reg = 0x23,len = 1, val = 1
[ 1199.049756] WENJIE:: sc3336_write_reg success
[ 1199.049774] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x23, regs[i].val = 0x1
[ 1199.049785] WENJIE:: sc3336_write_reg reg = 0x24,len = 1, val = 200
[ 1199.049970] WENJIE:: sc3336_write_reg success
[ 1199.049989] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x24, regs[i].val = 0xc8
[ 1199.049997] WENJIE:: sc3336_write_reg reg = 0x27,len = 1, val = 175
[ 1199.050177] WENJIE:: sc3336_write_reg success
[ 1199.050195] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x27, regs[i].val = 0xaf
[ 1199.050203] WENJIE:: sc3336_write_reg reg = 0x28,len = 1, val = 36
[ 1199.050420] WENJIE:: sc3336_write_reg success
[ 1199.050436] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x28, regs[i].val = 0x24
[ 1199.050446] WENJIE:: sc3336_write_reg reg = 0x29,len = 1, val = 26
[ 1199.050647] WENJIE:: sc3336_write_reg success
[ 1199.050665] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x29, regs[i].val = 0x1a
[ 1199.050674] WENJIE:: sc3336_write_reg reg = 0x2f,len = 1, val = 20
[ 1199.050856] WENJIE:: sc3336_write_reg success
[ 1199.050873] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x2f, regs[i].val = 0x14
[ 1199.050882] WENJIE:: sc3336_write_reg reg = 0x30,len = 1, val = 0
[ 1199.051057] WENJIE:: sc3336_write_reg success
[ 1199.051076] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x30, regs[i].val = 0x0
[ 1199.051084] WENJIE:: sc3336_write_reg reg = 0x31,len = 1, val = 4
[ 1199.051260] WENJIE:: sc3336_write_reg success
[ 1199.051278] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x31, regs[i].val = 0x4
[ 1199.051286] WENJIE:: sc3336_write_reg reg = 0x32,len = 1, val = 8
[ 1199.051451] WENJIE:: sc3336_write_reg success
[ 1199.051477] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x32, regs[i].val = 0x8
[ 1199.051487] WENJIE:: sc3336_write_reg reg = 0x33,len = 1, val = 12
[ 1199.051657] WENJIE:: sc3336_write_reg success
[ 1199.051673] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x33, regs[i].val = 0xc
[ 1199.051682] WENJIE:: sc3336_write_reg reg = 0x34,len = 1, val = 13
[ 1199.051934] WENJIE:: sc3336_write_reg success
[ 1199.051962] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x34, regs[i].val = 0xd
[ 1199.051972] WENJIE:: sc3336_write_reg reg = 0x35,len = 1, val = 14
[ 1199.052150] WENJIE:: sc3336_write_reg success
[ 1199.052166] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x35, regs[i].val = 0xe
[ 1199.052177] WENJIE:: sc3336_write_reg reg = 0x36,len = 1, val = 15
[ 1199.052354] WENJIE:: sc3336_write_reg success
[ 1199.052370] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x36, regs[i].val = 0xf
[ 1199.052379] WENJIE:: sc3336_write_reg reg = 0x72,len = 1, val = 152
[ 1199.052547] WENJIE:: sc3336_write_reg success
[ 1199.052565] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x72, regs[i].val = 0x98
[ 1199.052574] WENJIE:: sc3336_write_reg reg = 0x73,len = 1, val = 154
[ 1199.052748] WENJIE:: sc3336_write_reg success
[ 1199.052766] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x73, regs[i].val = 0x9a
[ 1199.052775] WENJIE:: sc3336_write_reg reg = 0x74,len = 1, val = 71
[ 1199.052961] WENJIE:: sc3336_write_reg success
[ 1199.052978] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x74, regs[i].val = 0x47
[ 1199.052986] WENJIE:: sc3336_write_reg reg = 0x76,len = 1, val = 130
[ 1199.053184] WENJIE:: sc3336_write_reg success
[ 1199.053203] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x76, regs[i].val = 0x82
[ 1199.053214] WENJIE:: sc3336_write_reg reg = 0x7a,len = 1, val = 203
[ 1199.053407] WENJIE:: sc3336_write_reg success
[ 1199.053425] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x7a, regs[i].val = 0xcb
[ 1199.053433] WENJIE:: sc3336_write_reg reg = 0xc2,len = 1, val = 12
[ 1199.053567] WENJIE:: sc3336_write_reg success
[ 1199.053584] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xc2, regs[i].val = 0xc
[ 1199.053592] WENJIE:: sc3336_write_reg reg = 0xce,len = 1, val = 3
[ 1199.053781] WENJIE:: sc3336_write_reg success
[ 1199.053799] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xce, regs[i].val = 0x3
[ 1199.053807] WENJIE:: sc3336_write_reg reg = 0xcf,len = 1, val = 72
[ 1199.053986] WENJIE:: sc3336_write_reg success
[ 1199.054004] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xcf, regs[i].val = 0x48
[ 1199.054013] WENJIE:: sc3336_write_reg reg = 0xd0,len = 1, val = 16
[ 1199.054191] WENJIE:: sc3336_write_reg success
[ 1199.054209] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xd0, regs[i].val = 0x10
[ 1199.054217] WENJIE:: sc3336_write_reg reg = 0xdc,len = 1, val = 117
[ 1199.054402] WENJIE:: sc3336_write_reg success
[ 1199.054418] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xdc, regs[i].val = 0x75
[ 1199.054426] WENJIE:: sc3336_write_reg reg = 0xeb,len = 1, val = 120
[ 1199.054598] WENJIE:: sc3336_write_reg success
[ 1199.054614] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xeb, regs[i].val = 0x78
[ 1199.054624] WENJIE:: sc3336_write_reg reg = 0x90,len = 1, val = 1
[ 1199.054771] WENJIE:: sc3336_write_reg success
[ 1199.054786] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x90, regs[i].val = 0x1
[ 1199.054794] WENJIE:: sc3336_write_reg reg = 0x92,len = 1, val = 1
[ 1199.055002] WENJIE:: sc3336_write_reg success
[ 1199.055017] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x92, regs[i].val = 0x1
[ 1199.055026] WENJIE:: sc3336_write_reg reg = 0x94,len = 1, val = 1
[ 1199.055277] WENJIE:: sc3336_write_reg success
[ 1199.055296] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x94, regs[i].val = 0x1
[ 1199.055305] WENJIE:: sc3336_write_reg reg = 0x95,len = 1, val = 1
[ 1199.055489] WENJIE:: sc3336_write_reg success
[ 1199.055506] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x95, regs[i].val = 0x1
[ 1199.055514] WENJIE:: sc3336_write_reg reg = 0x96,len = 1, val = 224
[ 1199.055691] WENJIE:: sc3336_write_reg success
[ 1199.055708] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x96, regs[i].val = 0xe0
[ 1199.055716] WENJIE:: sc3336_write_reg reg = 0x97,len = 1, val = 2
[ 1199.055875] WENJIE:: sc3336_write_reg success
[ 1199.055903] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x97, regs[i].val = 0x2
[ 1199.055911] WENJIE:: sc3336_write_reg reg = 0x98,len = 1, val = 128
[ 1199.056087] WENJIE:: sc3336_write_reg success
[ 1199.056103] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x98, regs[i].val = 0x80
[ 1199.056111] WENJIE:: sc3336_write_reg reg = 0xb0,len = 1, val = 70
[ 1199.056316] WENJIE:: sc3336_write_reg success
[ 1199.056332] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb0, regs[i].val = 0x46
[ 1199.056340] WENJIE:: sc3336_write_reg reg = 0xb1,len = 1, val = 1
[ 1199.056525] WENJIE:: sc3336_write_reg success
[ 1199.056544] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb1, regs[i].val = 0x1
[ 1199.056554] WENJIE:: sc3336_write_reg reg = 0xb2,len = 1, val = 0
[ 1199.056738] WENJIE:: sc3336_write_reg success
[ 1199.056755] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb2, regs[i].val = 0x0
[ 1199.056763] WENJIE:: sc3336_write_reg reg = 0xb3,len = 1, val = 64
[ 1199.056942] WENJIE:: sc3336_write_reg success
[ 1199.056957] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb3, regs[i].val = 0x40
[ 1199.056967] WENJIE:: sc3336_write_reg reg = 0xb4,len = 1, val = 64
[ 1199.057147] WENJIE:: sc3336_write_reg success
[ 1199.057164] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb4, regs[i].val = 0x40
[ 1199.057172] WENJIE:: sc3336_write_reg reg = 0xb5,len = 1, val = 64
[ 1199.057349] WENJIE:: sc3336_write_reg success
[ 1199.057366] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb5, regs[i].val = 0x40
[ 1199.057374] WENJIE:: sc3336_write_reg reg = 0xb6,len = 1, val = 0
[ 1199.057509] WENJIE:: sc3336_write_reg success
[ 1199.057522] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xb6, regs[i].val = 0x0
[ 1199.057531] WENJIE:: sc3336_write_reg reg = 0x40,len = 1, val = 38
[ 1199.057684] WENJIE:: sc3336_write_reg success
[ 1199.057700] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x40, regs[i].val = 0x26
[ 1199.057711] WENJIE:: sc3336_write_reg reg = 0x4e,len = 1, val = 0
[ 1199.057896] WENJIE:: sc3336_write_reg success
[ 1199.057913] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x4e, regs[i].val = 0x0
[ 1199.057921] WENJIE:: sc3336_write_reg reg = 0x4f,len = 1, val = 60
[ 1199.058106] WENJIE:: sc3336_write_reg success
[ 1199.058124] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x4f, regs[i].val = 0x3c
[ 1199.058133] WENJIE:: sc3336_write_reg reg = 0xe0,len = 1, val = 159
[ 1199.058351] WENJIE:: sc3336_write_reg success
[ 1199.058367] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xe0, regs[i].val = 0x9f
[ 1199.058378] WENJIE:: sc3336_write_reg reg = 0xe1,len = 1, val = 144
[ 1199.058574] WENJIE:: sc3336_write_reg success
[ 1199.058592] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xe1, regs[i].val = 0x90
[ 1199.058600] WENJIE:: sc3336_write_reg reg = 0xe4,len = 1, val = 15
[ 1199.058769] WENJIE:: sc3336_write_reg success
[ 1199.058794] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xe4, regs[i].val = 0xf
[ 1199.058803] WENJIE:: sc3336_write_reg reg = 0xe5,len = 1, val = 255
[ 1199.058974] WENJIE:: sc3336_write_reg success
[ 1199.058987] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xe5, regs[i].val = 0xff
[ 1199.058996] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 3
[ 1199.059178] WENJIE:: sc3336_write_reg success
[ 1199.059196] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x3
[ 1199.059206] WENJIE:: sc3336_write_reg reg = 0x1,len = 1, val = 3
[ 1199.059390] WENJIE:: sc3336_write_reg success
[ 1199.059408] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x1, regs[i].val = 0x3
[ 1199.059417] WENJIE:: sc3336_write_reg reg = 0x2,len = 1, val = 51
[ 1199.059633] WENJIE:: sc3336_write_reg success
[ 1199.059649] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x2, regs[i].val = 0x33
[ 1199.059658] WENJIE:: sc3336_write_reg reg = 0x3,len = 1, val = 150
[ 1199.059842] WENJIE:: sc3336_write_reg success
[ 1199.059859] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x3, regs[i].val = 0x96
[ 1199.059867] WENJIE:: sc3336_write_reg reg = 0x4,len = 1, val = 1
[ 1199.060045] WENJIE:: sc3336_write_reg success
[ 1199.060061] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x4, regs[i].val = 0x1
[ 1199.060070] WENJIE:: sc3336_write_reg reg = 0x5,len = 1, val = 0
[ 1199.060222] WENJIE:: sc3336_write_reg success
[ 1199.060238] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x5, regs[i].val = 0x0
[ 1199.060257] WENJIE:: sc3336_write_reg reg = 0x6,len = 1, val = 128
[ 1199.060406] WENJIE:: sc3336_write_reg success
[ 1199.060422] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x6, regs[i].val = 0x80
[ 1199.060431] WENJIE:: sc3336_write_reg reg = 0x10,len = 1, val = 144
[ 1199.060582] WENJIE:: sc3336_write_reg success
[ 1199.060598] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x10, regs[i].val = 0x90
[ 1199.060607] WENJIE:: sc3336_write_reg reg = 0x11,len = 1, val = 43
[ 1199.060776] WENJIE:: sc3336_write_reg success
[ 1199.060805] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x11, regs[i].val = 0x2b
[ 1199.060816] WENJIE:: sc3336_write_reg reg = 0x12,len = 1, val = 32
[ 1199.060988] WENJIE:: sc3336_write_reg success
[ 1199.061005] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x12, regs[i].val = 0x20
[ 1199.061015] WENJIE:: sc3336_write_reg reg = 0x13,len = 1, val = 3
[ 1199.061193] WENJIE:: sc3336_write_reg success
[ 1199.061208] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x13, regs[i].val = 0x3
[ 1199.061217] WENJIE:: sc3336_write_reg reg = 0x15,len = 1, val = 0
[ 1199.061388] WENJIE:: sc3336_write_reg success
[ 1199.061405] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x15, regs[i].val = 0x0
[ 1199.061415] WENJIE:: sc3336_write_reg reg = 0x21,len = 1, val = 16
[ 1199.061584] WENJIE:: sc3336_write_reg success
[ 1199.061601] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x21, regs[i].val = 0x10
[ 1199.061611] WENJIE:: sc3336_write_reg reg = 0x22,len = 1, val = 0
[ 1199.061763] WENJIE:: sc3336_write_reg success
[ 1199.061788] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x22, regs[i].val = 0x0
[ 1199.061797] WENJIE:: sc3336_write_reg reg = 0x23,len = 1, val = 48
[ 1199.061957] WENJIE:: sc3336_write_reg success
[ 1199.061974] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x23, regs[i].val = 0x30
[ 1199.061983] WENJIE:: sc3336_write_reg reg = 0x24,len = 1, val = 2
[ 1199.062161] WENJIE:: sc3336_write_reg success
[ 1199.062177] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x24, regs[i].val = 0x2
[ 1199.203159] WENJIE:: sc3336_write_reg reg = 0x25,len = 1, val = 18
[ 1199.203351] WENJIE:: sc3336_write_reg success
[ 1199.203380] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x25, regs[i].val = 0x12
[ 1199.203402] WENJIE:: sc3336_write_reg reg = 0x26,len = 1, val = 2
[ 1199.203547] WENJIE:: sc3336_write_reg success
[ 1199.203574] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x26, regs[i].val = 0x2
[ 1199.203596] WENJIE:: sc3336_write_reg reg = 0x29,len = 1, val = 1
[ 1199.203739] WENJIE:: sc3336_write_reg success
[ 1199.203766] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x29, regs[i].val = 0x1
[ 1199.203787] WENJIE:: sc3336_write_reg reg = 0x2a,len = 1, val = 10
[ 1199.203928] WENJIE:: sc3336_write_reg success
[ 1199.203953] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x2a, regs[i].val = 0xa
[ 1199.203973] WENJIE:: sc3336_write_reg reg = 0x2b,len = 1, val = 3
[ 1199.204119] WENJIE:: sc3336_write_reg success
[ 1199.204144] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x2b, regs[i].val = 0x3
[ 1199.204165] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 0
[ 1199.204306] WENJIE:: sc3336_write_reg success
[ 1199.204333] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x0
[ 1199.204353] WENJIE:: sc3336_write_reg reg = 0xf9,len = 1, val = 14
[ 1199.204496] WENJIE:: sc3336_write_reg success
[ 1199.204524] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xf9, regs[i].val = 0xe
[ 1199.204545] WENJIE:: sc3336_write_reg reg = 0xfc,len = 1, val = 14
[ 1199.204696] WENJIE:: sc3336_write_reg success
[ 1199.204721] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfc, regs[i].val = 0xe
[ 1199.204742] WENJIE:: sc3336_write_reg reg = 0xfe,len = 1, val = 0
[ 1199.204883] WENJIE:: sc3336_write_reg success
[ 1199.204907] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0xfe, regs[i].val = 0x0
[ 1199.353003] WENJIE:: sc3336_write_reg reg = 0x25,len = 1, val = 162
[ 1199.353196] WENJIE:: sc3336_write_reg success
[ 1199.353232] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x25, regs[i].val = 0xa2
[ 1199.353253] WENJIE:: sc3336_write_reg reg = 0x3f,len = 1, val = 26
[ 1199.353403] WENJIE:: sc3336_write_reg success
[ 1199.353432] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x3f, regs[i].val = 0x1a
[ 1199.503094] WENJIE:: sc3336_write_reg reg = 0x25,len = 1, val = 226
[ 1199.503282] WENJIE:: sc3336_write_reg success
[ 1199.503314] WENJIE:: sc3336_write_reg success ret = 0, regs[i].addr = 0x25, regs[i].val = 0xe2
[ 1199.503359] WENJIE:: sc3336_write_reg reg = 0x320e,len = 1, val = 6
[ 1199.503525] WENJIE:: sc3336_write_reg success
[ 1199.503555] WENJIE:: sc3336_write_reg reg = 0x320f,len = 1, val = 84
[ 1199.503697] WENJIE:: sc3336_write_reg success
[ 1199.503728] WENJIE:: sc3336_write_reg reg = 0x3e00,len = 1, val = 0
[ 1199.503886] WENJIE:: sc3336_write_reg success
[ 1199.503909] WENJIE:: sc3336_write_reg reg = 0x3e01,len = 1, val = 9
[ 1199.504052] WENJIE:: sc3336_write_reg success
[ 1199.504076] WENJIE:: sc3336_write_reg reg = 0x3e02,len = 1, val = 32
[ 1199.504218] WENJIE:: sc3336_write_reg success
[ 1199.504246] WENJIE:: sc3336_write_reg reg = 0x3e06,len = 1, val = 0
[ 1199.504398] WENJIE:: sc3336_write_reg success
[ 1199.504421] WENJIE:: sc3336_write_reg reg = 0x3e07,len = 1, val = 128
[ 1199.504565] WENJIE:: sc3336_write_reg success
[ 1199.504588] WENJIE:: sc3336_write_reg reg = 0x3e09,len = 1, val = 0
[ 1199.504732] WENJIE:: sc3336_write_reg success
[ 1199.504757] WENJIE:: sc3336_read_reg len = 1, reg_addr_be = 325
[ 1199.504780] WENJIE:: red i2c addr = 0x21, write i2c addr = 0x21
[ 1199.504958] WENJIE:: sc3336_read_reg ret = 2, ARRAY_SIZE(msgs) = 2,data_be = 0x0
[ 1199.504978] WENJIE:: sc3336_read_reg *val = 0
[ 1199.504999] WENJIE:: sc3336_write_reg reg = 0x4501,len = 1, val = 0
[ 1199.505144] WENJIE:: sc3336_write_reg success
[ 1199.505170] WENJIE:: sc3336_read_reg len = 1, reg_addr_be = 8498
[ 1199.505192] WENJIE:: red i2c addr = 0x21, write i2c addr = 0x21
[ 1199.505370] WENJIE:: sc3336_read_reg ret = 2, ARRAY_SIZE(msgs) = 2,data_be = 0x0
[ 1199.505390] WENJIE:: sc3336_read_reg *val = 0
[ 1199.505412] WENJIE:: sc3336_write_reg reg = 0x3221,len = 1, val = 0
[ 1199.505554] WENJIE:: sc3336_write_reg success
[ 1199.505577] WENJIE:: sc3336_read_reg len = 1, reg_addr_be = 8498
[ 1199.505598] WENJIE:: red i2c addr = 0x21, write i2c addr = 0x21
[ 1199.505777] WENJIE:: sc3336_read_reg ret = 2, ARRAY_SIZE(msgs) = 2,data_be = 0x0
[ 1199.505797] WENJIE:: sc3336_read_reg *val = 0
[ 1199.505818] WENJIE:: sc3336_write_reg reg = 0x3221,len = 1, val = 0
[ 1199.505961] WENJIE:: sc3336_write_reg success
[ 1199.505986] WENJIE:: sc3336_write_reg reg = 0x100,len = 1, val = 1
[ 1199.506136] WENJIE:: sc3336_write_reg success
关键词: RV1103     v4l2-ctl     录制     视频
