求大神指点,目前只调发送,基本配置和发送函数如下。
调用发送函数后,CAN0_TXBRP0寄存器的TRP0一直是1,数据始终未发出。
IFX_CONST IfxCan_Can_Pins can_pins[CAN_NUM] = {
{ IfxCan_TXD00_P20_8_OUT, IfxPort_OutputMode_pushPull, // Tx pin
IfxCan_RXD00B_P20_7_IN, IfxPort_InputMode_pullUp, // Rx pin
IfxPort_PadDriver_cmosAutomotiveSpeed4},
void can_init(int index) {
// create module configuration
IfxCan_Can_Config canConfig;
IfxCan_Can can;
IfxCan_NodeId can_node_num = 0;
IfxCan_Can_initModuleConfig( canConfig, MODULE_CAN0);
// initialize module
IfxCan_Can_initModule( can, canConfig);
can_node_num = index % 4;
// create node configuration
IfxCan_Can_initNodeConfig( g_drv_can[index].can_node_config, can);
// initialize Node 0 g_drv_can[index].can_node_config.nodeId = can_node_num;
g_drv_can[index].can_node_config.clockSource = IfxCan_ClockSource_both;
g_drv_can[index].can_node_config.frame.type = IfxCan_FrameType_transmitAndReceive;
g_drv_can[index].can_node_config.frame.mode = IfxCan_FrameMode_fdLong;
g_drv_can[index].can_node_config.txConfig.dedicatedTxBuffersNumber = 31;
g_drv_can[index].can_node_config.txConfig.txMode = IfxCan_TxMode_dedicatedBuffers;
g_drv_can[index].can_node_config.txConfig.txBufferDataFieldSize = IfxCan_DataFieldSize_8;
g_drv_can[index].can_node_config.messageRAM.txBuffersStartAddress = 0x400;
g_drv_can[index].can_node_config.messageRAM.baseAddress = MODULE_CAN0_RAM + NODE0_RAM_OFFSET;
g_drv_can[index].can_node_config.baudRate.baudrate = 500000;
g_drv_can[index].can_node_config.pins = can_pins[index];
g_drv_can[index].can_node_config.busLoopbackEnabled = FALSE;
g_drv_can[index].can_node_config.calculateBitTimingValues = TRUE;
IfxCan_Can_initNode( g_drv_can[index].can_node, g_drv_can[index].can_node_config);
void can_send(int index)
IfxCan_Can_initMessage( g_drv_can[index].tx_msg);
// change the relevent members of message structure
g_drv_can[index].tx_msg.bufferNumber = 0;
g_drv_can[index].tx_msg.dataLengthCode = IfxCan_DataLengthCode_8;
g_drv_can[index].tx_msg.frameMode = IfxCan_FrameMode_fdLong;
g_drv_can[index].tx_msg.messageIdLength = IfxCan_MessageIdLength_standard;
g_drv_can[index].tx_msg.messageId = CAN_MESSAGE_ID;
g_drv_can[index].txdata[0] = 0x78563412;
g_drv_can[index].txdata[1] = 0xf0debc9a;
// Transmit Data
IfxCan_Can_sendMessage( g_drv_can[index].can_node, g_drv_can[index].tx_msg, g_drv_can[index].txdata);
共1条
TC397CAN0TXBRP0寄存器的TRP0一直是1,数据始终未发出的原因?
关键词: TC397 CAN TXBRP0
共1条
