电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 【Let's do第1期-DIY功率检测与控制系统】OLED屏幕显示信息
2025-05-26 21:05:27     打赏
1、简介
在得捷商城购买的这款OLED屏幕为单色屏,实际屏幕上方有部分区域是黄色显示,其余大部可显示蓝色像素。尺寸为0.96英寸,128*64像素。驱动IC为SSD1315,如果有SSD1306的屏幕驱动可以直接移植过来,因为这两个驱动是兼容的。
2、cubemx配置
使能I2C1硬件IIC外设,对应SCL引脚为PB8,SDA引脚为PB9
如果OLED显示出现花屏,可以将I2C通信速率调整为Standard模式
3、屏幕驱动移植
oledfont.h
#ifndef __OLEDFONTS_H
#define __OLEDFONTS_H
//常用ASCII表
//偏移量32
//ASCII字符集
//偏移量32
//大小:12*6
/************************************6*8的点阵************************************/
//12*12 ASCII字符集点阵
const unsigned char asc2_1206s[95][12]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*" ",0*/
{0x00,0x00,0x00,0x00,0x3F,0x40,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",1*/
{0x00,0x00,0x30,0x00,0x40,0x00,0x30,0x00,0x40,0x00,0x00,0x00},/*""",2*/
{0x09,0x00,0x0B,0xC0,0x3D,0x00,0x0B,0xC0,0x3D,0x00,0x09,0x00},/*"#",3*/
{0x18,0xC0,0x24,0x40,0x7F,0xE0,0x22,0x40,0x31,0x80,0x00,0x00},/*"$",4*/
{0x18,0x00,0x24,0xC0,0x1B,0x00,0x0D,0x80,0x32,0x40,0x01,0x80},/*"%",5*/
{0x03,0x80,0x1C,0x40,0x27,0x40,0x1C,0x80,0x07,0x40,0x00,0x40},/*"&",6*/
{0x10,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"'",7*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x80,0x20,0x40,0x40,0x20},/*"(",8*/
{0x00,0x00,0x40,0x20,0x20,0x40,0x1F,0x80,0x00,0x00,0x00,0x00},/*")",9*/
{0x09,0x00,0x06,0x00,0x1F,0x80,0x06,0x00,0x09,0x00,0x00,0x00},/*"*",10*/
{0x04,0x00,0x04,0x00,0x3F,0x80,0x04,0x00,0x04,0x00,0x00,0x00},/*"+",11*/
{0x00,0x10,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",12*/
{0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x00,0x00},/*"-",13*/
{0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*".",14*/
{0x00,0x20,0x01,0xC0,0x06,0x00,0x38,0x00,0x40,0x00,0x00,0x00},/*"/",15*/
{0x1F,0x80,0x20,0x40,0x20,0x40,0x20,0x40,0x1F,0x80,0x00,0x00},/*"0",16*/
{0x00,0x00,0x10,0x40,0x3F,0xC0,0x00,0x40,0x00,0x00,0x00,0x00},/*"1",17*/
{0x18,0xC0,0x21,0x40,0x22,0x40,0x24,0x40,0x18,0x40,0x00,0x00},/*"2",18*/
{0x10,0x80,0x20,0x40,0x24,0x40,0x24,0x40,0x1B,0x80,0x00,0x00},/*"3",19*/
{0x02,0x00,0x0D,0x00,0x11,0x00,0x3F,0xC0,0x01,0x40,0x00,0x00},/*"4",20*/
{0x3C,0x80,0x24,0x40,0x24,0x40,0x24,0x40,0x23,0x80,0x00,0x00},/*"5",21*/
{0x1F,0x80,0x24,0x40,0x24,0x40,0x34,0x40,0x03,0x80,0x00,0x00},/*"6",22*/
{0x30,0x00,0x20,0x00,0x27,0xC0,0x38,0x00,0x20,0x00,0x00,0x00},/*"7",23*/
{0x1B,0x80,0x24,0x40,0x24,0x40,0x24,0x40,0x1B,0x80,0x00,0x00},/*"8",24*/
{0x1C,0x00,0x22,0xC0,0x22,0x40,0x22,0x40,0x1F,0x80,0x00,0x00},/*"9",25*/
{0x00,0x00,0x00,0x00,0x08,0x40,0x00,0x00,0x00,0x00,0x00,0x00},/*":",26*/
{0x00,0x00,0x00,0x00,0x04,0x60,0x00,0x00,0x00,0x00,0x00,0x00},/*";",27*/
{0x00,0x00,0x04,0x00,0x0A,0x00,0x11,0x00,0x20,0x80,0x40,0x40},/*"<",28*/
{0x09,0x00,0x09,0x00,0x09,0x00,0x09,0x00,0x09,0x00,0x00,0x00},/*"=",29*/
{0x00,0x00,0x40,0x40,0x20,0x80,0x11,0x00,0x0A,0x00,0x04,0x00},/*">",30*/
{0x18,0x00,0x20,0x00,0x23,0x40,0x24,0x00,0x18,0x00,0x00,0x00},/*"?",31*/
{0x1F,0x80,0x20,0x40,0x27,0x40,0x29,0x40,0x1F,0x40,0x00,0x00},/*"@",32*/
{0x00,0x40,0x07,0xC0,0x39,0x00,0x0F,0x00,0x01,0xC0,0x00,0x40},/*"A",33*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x24,0x40,0x1B,0x80,0x00,0x00},/*"B",34*/
{0x1F,0x80,0x20,0x40,0x20,0x40,0x20,0x40,0x30,0x80,0x00,0x00},/*"C",35*/
{0x20,0x40,0x3F,0xC0,0x20,0x40,0x20,0x40,0x1F,0x80,0x00,0x00},/*"D",36*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x2E,0x40,0x30,0xC0,0x00,0x00},/*"E",37*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x2E,0x00,0x30,0x00,0x00,0x00},/*"F",38*/
{0x0F,0x00,0x10,0x80,0x20,0x40,0x22,0x40,0x33,0x80,0x02,0x00},/*"G",39*/
{0x20,0x40,0x3F,0xC0,0x04,0x00,0x04,0x00,0x3F,0xC0,0x20,0x40},/*"H",40*/
{0x20,0x40,0x20,0x40,0x3F,0xC0,0x20,0x40,0x20,0x40,0x00,0x00},/*"I",41*/
{0x00,0x60,0x20,0x20,0x20,0x20,0x3F,0xC0,0x20,0x00,0x20,0x00},/*"J",42*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x0B,0x00,0x30,0xC0,0x20,0x40},/*"K",43*/
{0x20,0x40,0x3F,0xC0,0x20,0x40,0x00,0x40,0x00,0x40,0x00,0xC0},/*"L",44*/
{0x3F,0xC0,0x3C,0x00,0x03,0xC0,0x3C,0x00,0x3F,0xC0,0x00,0x00},/*"M",45*/
{0x20,0x40,0x3F,0xC0,0x0C,0x40,0x23,0x00,0x3F,0xC0,0x20,0x00},/*"N",46*/
{0x1F,0x80,0x20,0x40,0x20,0x40,0x20,0x40,0x1F,0x80,0x00,0x00},/*"O",47*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x24,0x00,0x18,0x00,0x00,0x00},/*"P",48*/
{0x1F,0x80,0x21,0x40,0x21,0x40,0x20,0xE0,0x1F,0xA0,0x00,0x00},/*"Q",49*/
{0x20,0x40,0x3F,0xC0,0x24,0x40,0x26,0x00,0x19,0xC0,0x00,0x40},/*"R",50*/
{0x18,0xC0,0x24,0x40,0x24,0x40,0x22,0x40,0x31,0x80,0x00,0x00},/*"S",51*/
{0x30,0x00,0x20,0x40,0x3F,0xC0,0x20,0x40,0x30,0x00,0x00,0x00},/*"T",52*/
{0x20,0x00,0x3F,0x80,0x00,0x40,0x00,0x40,0x3F,0x80,0x20,0x00},/*"U",53*/
{0x20,0x00,0x3E,0x00,0x01,0xC0,0x07,0x00,0x38,0x00,0x20,0x00},/*"V",54*/
{0x38,0x00,0x07,0xC0,0x3C,0x00,0x07,0xC0,0x38,0x00,0x00,0x00},/*"W",55*/
{0x20,0x40,0x39,0xC0,0x06,0x00,0x39,0xC0,0x20,0x40,0x00,0x00},/*"X",56*/
{0x20,0x00,0x38,0x40,0x07,0xC0,0x38,0x40,0x20,0x00,0x00,0x00},/*"Y",57*/
{0x30,0x40,0x21,0xC0,0x26,0x40,0x38,0x40,0x20,0xC0,0x00,0x00},/*"Z",58*/
{0x00,0x00,0x00,0x00,0x7F,0xE0,0x40,0x20,0x40,0x20,0x00,0x00},/*"[",59*/
{0x00,0x00,0x70,0x00,0x0C,0x00,0x03,0x80,0x00,0x40,0x00,0x00},/*"\",60*/
{0x00,0x00,0x40,0x20,0x40,0x20,0x7F,0xE0,0x00,0x00,0x00,0x00},/*"]",61*/
{0x00,0x00,0x20,0x00,0x40,0x00,0x20,0x00,0x00,0x00,0x00,0x00},/*"^",62*/
{0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10},/*"_",63*/
{0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"`",64*/
{0x00,0x00,0x02,0x80,0x05,0x40,0x05,0x40,0x03,0xC0,0x00,0x40},/*"a",65*/
{0x20,0x00,0x3F,0xC0,0x04,0x40,0x04,0x40,0x03,0x80,0x00,0x00},/*"b",66*/
{0x00,0x00,0x03,0x80,0x04,0x40,0x04,0x40,0x06,0x40,0x00,0x00},/*"c",67*/
{0x00,0x00,0x03,0x80,0x04,0x40,0x24,0x40,0x3F,0xC0,0x00,0x40},/*"d",68*/
{0x00,0x00,0x03,0x80,0x05,0x40,0x05,0x40,0x03,0x40,0x00,0x00},/*"e",69*/
{0x00,0x00,0x04,0x40,0x1F,0xC0,0x24,0x40,0x24,0x40,0x20,0x00},/*"f",70*/
{0x00,0x00,0x02,0xE0,0x05,0x50,0x05,0x50,0x06,0x50,0x04,0x20},/*"g",71*/
{0x20,0x40,0x3F,0xC0,0x04,0x40,0x04,0x00,0x03,0xC0,0x00,0x40},/*"h",72*/
{0x00,0x00,0x04,0x40,0x27,0xC0,0x00,0x40,0x00,0x00,0x00,0x00},/*"i",73*/
{0x00,0x10,0x00,0x10,0x04,0x10,0x27,0xE0,0x00,0x00,0x00,0x00},/*"j",74*/
{0x20,0x40,0x3F,0xC0,0x01,0x40,0x07,0x00,0x04,0xC0,0x04,0x40},/*"k",75*/
{0x20,0x40,0x20,0x40,0x3F,0xC0,0x00,0x40,0x00,0x40,0x00,0x00},/*"l",76*/
{0x07,0xC0,0x04,0x00,0x07,0xC0,0x04,0x00,0x03,0xC0,0x00,0x00},/*"m",77*/
{0x04,0x40,0x07,0xC0,0x04,0x40,0x04,0x00,0x03,0xC0,0x00,0x40},/*"n",78*/
{0x00,0x00,0x03,0x80,0x04,0x40,0x04,0x40,0x03,0x80,0x00,0x00},/*"o",79*/
{0x04,0x10,0x07,0xF0,0x04,0x50,0x04,0x40,0x03,0x80,0x00,0x00},/*"p",80*/
{0x00,0x00,0x03,0x80,0x04,0x40,0x04,0x50,0x07,0xF0,0x00,0x10},/*"q",81*/
{0x04,0x40,0x07,0xC0,0x02,0x40,0x04,0x00,0x04,0x00,0x00,0x00},/*"r",82*/
{0x00,0x00,0x06,0x40,0x05,0x40,0x05,0x40,0x04,0xC0,0x00,0x00},/*"s",83*/
{0x00,0x00,0x04,0x00,0x1F,0x80,0x04,0x40,0x00,0x40,0x00,0x00},/*"t",84*/
{0x04,0x00,0x07,0x80,0x00,0x40,0x04,0x40,0x07,0xC0,0x00,0x40},/*"u",85*/
{0x04,0x00,0x07,0x00,0x04,0xC0,0x01,0x80,0x06,0x00,0x04,0x00},/*"v",86*/
{0x06,0x00,0x01,0xC0,0x07,0x00,0x01,0xC0,0x06,0x00,0x00,0x00},/*"w",87*/
{0x04,0x40,0x06,0xC0,0x01,0x00,0x06,0xC0,0x04,0x40,0x00,0x00},/*"x",88*/
{0x04,0x10,0x07,0x10,0x04,0xE0,0x01,0x80,0x06,0x00,0x04,0x00},/*"y",89*/
{0x00,0x00,0x04,0x40,0x05,0xC0,0x06,0x40,0x04,0x40,0x00,0x00},/*"z",90*/
{0x00,0x00,0x00,0x00,0x04,0x00,0x7B,0xE0,0x40,0x20,0x00,0x00},/*"{",91*/
{0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xF0,0x00,0x00,0x00,0x00},/*"|",92*/
{0x00,0x00,0x40,0x20,0x7B,0xE0,0x04,0x00,0x00,0x00,0x00,0x00},/*"}",93*/
{0x40,0x00,0x80,0x00,0x40,0x00,0x20,0x00,0x20,0x00,0x40,0x00},/*"~",94*/
//16*16 ASCII字符集点阵
const unsigned char asc2_1608s[95][16]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*" ",0*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xCC,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",1*/
{0x00,0x00,0x08,0x00,0x30,0x00,0x60,0x00,0x08,0x00,0x30,0x00,0x60,0x00,0x00,0x00},/*""",2*/
{0x02,0x20,0x03,0xFC,0x1E,0x20,0x02,0x20,0x03,0xFC,0x1E,0x20,0x02,0x20,0x00,0x00},/*"#",3*/
{0x00,0x00,0x0E,0x18,0x11,0x04,0x3F,0xFF,0x10,0x84,0x0C,0x78,0x00,0x00,0x00,0x00},/*"$",4*/
{0x0F,0x00,0x10,0x84,0x0F,0x38,0x00,0xC0,0x07,0x78,0x18,0x84,0x00,0x78,0x00,0x00},/*"%",5*/
{0x00,0x78,0x0F,0x84,0x10,0xC4,0x11,0x24,0x0E,0x98,0x00,0xE4,0x00,0x84,0x00,0x08},/*"&",6*/
{0x08,0x00,0x68,0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"'",7*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x18,0x18,0x20,0x04,0x40,0x02,0x00,0x00},/*"(",8*/
{0x00,0x00,0x40,0x02,0x20,0x04,0x18,0x18,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00},/*")",9*/
{0x02,0x40,0x02,0x40,0x01,0x80,0x0F,0xF0,0x01,0x80,0x02,0x40,0x02,0x40,0x00,0x00},/*"*",10*/
{0x00,0x80,0x00,0x80,0x00,0x80,0x0F,0xF8,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x00},/*"+",11*/
{0x00,0x01,0x00,0x0D,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",12*/
{0x00,0x00,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80},/*"-",13*/
{0x00,0x00,0x00,0x0C,0x00,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*".",14*/
{0x00,0x00,0x00,0x06,0x00,0x18,0x00,0x60,0x01,0x80,0x06,0x00,0x18,0x00,0x20,0x00},/*"/",15*/
{0x00,0x00,0x07,0xF0,0x08,0x08,0x10,0x04,0x10,0x04,0x08,0x08,0x07,0xF0,0x00,0x00},/*"0",16*/
{0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00},/*"1",17*/
{0x00,0x00,0x0E,0x0C,0x10,0x14,0x10,0x24,0x10,0x44,0x11,0x84,0x0E,0x0C,0x00,0x00},/*"2",18*/
{0x00,0x00,0x0C,0x18,0x10,0x04,0x11,0x04,0x11,0x04,0x12,0x88,0x0C,0x70,0x00,0x00},/*"3",19*/
{0x00,0x00,0x00,0xE0,0x03,0x20,0x04,0x24,0x08,0x24,0x1F,0xFC,0x00,0x24,0x00,0x00},/*"4",20*/
{0x00,0x00,0x1F,0x98,0x10,0x84,0x11,0x04,0x11,0x04,0x10,0x88,0x10,0x70,0x00,0x00},/*"5",21*/
{0x00,0x00,0x07,0xF0,0x08,0x88,0x11,0x04,0x11,0x04,0x18,0x88,0x00,0x70,0x00,0x00},/*"6",22*/
{0x00,0x00,0x1C,0x00,0x10,0x00,0x10,0xFC,0x13,0x00,0x1C,0x00,0x10,0x00,0x00,0x00},/*"7",23*/
{0x00,0x00,0x0E,0x38,0x11,0x44,0x10,0x84,0x10,0x84,0x11,0x44,0x0E,0x38,0x00,0x00},/*"8",24*/
{0x00,0x00,0x07,0x00,0x08,0x8C,0x10,0x44,0x10,0x44,0x08,0x88,0x07,0xF0,0x00,0x00},/*"9",25*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x0C,0x03,0x0C,0x00,0x00,0x00,0x00,0x00,0x00},/*":",26*/
{0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*";",27*/
{0x00,0x00,0x00,0x80,0x01,0x40,0x02,0x20,0x04,0x10,0x08,0x08,0x10,0x04,0x00,0x00},/*"<",28*/
{0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x00,0x00},/*"=",29*/
{0x00,0x00,0x10,0x04,0x08,0x08,0x04,0x10,0x02,0x20,0x01,0x40,0x00,0x80,0x00,0x00},/*">",30*/
{0x00,0x00,0x0E,0x00,0x12,0x00,0x10,0x0C,0x10,0x6C,0x10,0x80,0x0F,0x00,0x00,0x00},/*"?",31*/
{0x03,0xE0,0x0C,0x18,0x13,0xE4,0x14,0x24,0x17,0xC4,0x08,0x28,0x07,0xD0,0x00,0x00},/*"@",32*/
{0x00,0x04,0x00,0x3C,0x03,0xC4,0x1C,0x40,0x07,0x40,0x00,0xE4,0x00,0x1C,0x00,0x04},/*"A",33*/
{0x10,0x04,0x1F,0xFC,0x11,0x04,0x11,0x04,0x11,0x04,0x0E,0x88,0x00,0x70,0x00,0x00},/*"B",34*/
{0x03,0xE0,0x0C,0x18,0x10,0x04,0x10,0x04,0x10,0x04,0x10,0x08,0x1C,0x10,0x00,0x00},/*"C",35*/
{0x10,0x04,0x1F,0xFC,0x10,0x04,0x10,0x04,0x10,0x04,0x08,0x08,0x07,0xF0,0x00,0x00},/*"D",36*/
{0x10,0x04,0x1F,0xFC,0x11,0x04,0x11,0x04,0x17,0xC4,0x10,0x04,0x08,0x18,0x00,0x00},/*"E",37*/
{0x10,0x04,0x1F,0xFC,0x11,0x04,0x11,0x00,0x17,0xC0,0x10,0x00,0x08,0x00,0x00,0x00},/*"F",38*/
{0x03,0xE0,0x0C,0x18,0x10,0x04,0x10,0x04,0x10,0x44,0x1C,0x78,0x00,0x40,0x00,0x00},/*"G",39*/
{0x10,0x04,0x1F,0xFC,0x10,0x84,0x00,0x80,0x00,0x80,0x10,0x84,0x1F,0xFC,0x10,0x04},/*"H",40*/
{0x00,0x00,0x10,0x04,0x10,0x04,0x1F,0xFC,0x10,0x04,0x10,0x04,0x00,0x00,0x00,0x00},/*"I",41*/
{0x00,0x03,0x00,0x01,0x10,0x01,0x10,0x01,0x1F,0xFE,0x10,0x00,0x10,0x00,0x00,0x00},/*"J",42*/
{0x10,0x04,0x1F,0xFC,0x11,0x04,0x03,0x80,0x14,0x64,0x18,0x1C,0x10,0x04,0x00,0x00},/*"K",43*/
{0x10,0x04,0x1F,0xFC,0x10,0x04,0x00,0x04,0x00,0x04,0x00,0x04,0x00,0x0C,0x00,0x00},/*"L",44*/
{0x10,0x04,0x1F,0xFC,0x1F,0x00,0x00,0xFC,0x1F,0x00,0x1F,0xFC,0x10,0x04,0x00,0x00},/*"M",45*/
{0x10,0x04,0x1F,0xFC,0x0C,0x04,0x03,0x00,0x00,0xE0,0x10,0x18,0x1F,0xFC,0x10,0x00},/*"N",46*/
{0x07,0xF0,0x08,0x08,0x10,0x04,0x10,0x04,0x10,0x04,0x08,0x08,0x07,0xF0,0x00,0x00},/*"O",47*/
{0x10,0x04,0x1F,0xFC,0x10,0x84,0x10,0x80,0x10,0x80,0x10,0x80,0x0F,0x00,0x00,0x00},/*"P",48*/
{0x07,0xF0,0x08,0x18,0x10,0x24,0x10,0x24,0x10,0x1C,0x08,0x0A,0x07,0xF2,0x00,0x00},/*"Q",49*/
{0x10,0x04,0x1F,0xFC,0x11,0x04,0x11,0x00,0x11,0xC0,0x11,0x30,0x0E,0x0C,0x00,0x04},/*"R",50*/
{0x00,0x00,0x0E,0x1C,0x11,0x04,0x10,0x84,0x10,0x84,0x10,0x44,0x1C,0x38,0x00,0x00},/*"S",51*/
{0x18,0x00,0x10,0x00,0x10,0x04,0x1F,0xFC,0x10,0x04,0x10,0x00,0x18,0x00,0x00,0x00},/*"T",52*/
{0x10,0x00,0x1F,0xF8,0x10,0x04,0x00,0x04,0x00,0x04,0x10,0x04,0x1F,0xF8,0x10,0x00},/*"U",53*/
{0x10,0x00,0x1E,0x00,0x11,0xE0,0x00,0x1C,0x00,0x70,0x13,0x80,0x1C,0x00,0x10,0x00},/*"V",54*/
{0x1F,0xC0,0x10,0x3C,0x00,0xE0,0x1F,0x00,0x00,0xE0,0x10,0x3C,0x1F,0xC0,0x00,0x00},/*"W",55*/
{0x10,0x04,0x18,0x0C,0x16,0x34,0x01,0xC0,0x01,0xC0,0x16,0x34,0x18,0x0C,0x10,0x04},/*"X",56*/
{0x10,0x00,0x1C,0x00,0x13,0x04,0x00,0xFC,0x13,0x04,0x1C,0x00,0x10,0x00,0x00,0x00},/*"Y",57*/
{0x08,0x04,0x10,0x1C,0x10,0x64,0x10,0x84,0x13,0x04,0x1C,0x04,0x10,0x18,0x00,0x00},/*"Z",58*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFE,0x40,0x02,0x40,0x02,0x40,0x02,0x00,0x00},/*"[",59*/
{0x00,0x00,0x30,0x00,0x0C,0x00,0x03,0x80,0x00,0x60,0x00,0x1C,0x00,0x03,0x00,0x00},/*"\",60*/
{0x00,0x00,0x40,0x02,0x40,0x02,0x40,0x02,0x7F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00},/*"]",61*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x20,0x00,0x00,0x00},/*"^",62*/
{0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01},/*"_",63*/
{0x00,0x00,0x40,0x00,0x40,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"`",64*/
{0x00,0x00,0x00,0x98,0x01,0x24,0x01,0x44,0x01,0x44,0x01,0x44,0x00,0xFC,0x00,0x04},/*"a",65*/
{0x10,0x00,0x1F,0xFC,0x00,0x88,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x70,0x00,0x00},/*"b",66*/
{0x00,0x00,0x00,0x70,0x00,0x88,0x01,0x04,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x00},/*"c",67*/
{0x00,0x00,0x00,0x70,0x00,0x88,0x01,0x04,0x01,0x04,0x11,0x08,0x1F,0xFC,0x00,0x04},/*"d",68*/
{0x00,0x00,0x00,0xF8,0x01,0x44,0x01,0x44,0x01,0x44,0x01,0x44,0x00,0xC8,0x00,0x00},/*"e",69*/
{0x00,0x00,0x01,0x04,0x01,0x04,0x0F,0xFC,0x11,0x04,0x11,0x04,0x11,0x00,0x18,0x00},/*"f",70*/
{0x00,0x00,0x00,0xD6,0x01,0x29,0x01,0x29,0x01,0x29,0x01,0xC9,0x01,0x06,0x00,0x00},/*"g",71*/
{0x10,0x04,0x1F,0xFC,0x00,0x84,0x01,0x00,0x01,0x00,0x01,0x04,0x00,0xFC,0x00,0x04},/*"h",72*/
{0x00,0x00,0x01,0x04,0x19,0x04,0x19,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00},/*"i",73*/
{0x00,0x00,0x00,0x03,0x00,0x01,0x01,0x01,0x19,0x01,0x19,0xFE,0x00,0x00,0x00,0x00},/*"j",74*/
{0x10,0x04,0x1F,0xFC,0x00,0x24,0x00,0x40,0x01,0xB4,0x01,0x0C,0x01,0x04,0x00,0x00},/*"k",75*/
{0x00,0x00,0x10,0x04,0x10,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00},/*"l",76*/
{0x01,0x04,0x01,0xFC,0x01,0x04,0x01,0x00,0x01,0xFC,0x01,0x04,0x01,0x00,0x00,0xFC},/*"m",77*/
{0x01,0x04,0x01,0xFC,0x00,0x84,0x01,0x00,0x01,0x00,0x01,0x04,0x00,0xFC,0x00,0x04},/*"n",78*/
{0x00,0x00,0x00,0xF8,0x01,0x04,0x01,0x04,0x01,0x04,0x01,0x04,0x00,0xF8,0x00,0x00},/*"o",79*/
{0x01,0x01,0x01,0xFF,0x00,0x85,0x01,0x04,0x01,0x04,0x00,0x88,0x00,0x70,0x00,0x00},/*"p",80*/
{0x00,0x00,0x00,0x70,0x00,0x88,0x01,0x04,0x01,0x04,0x01,0x05,0x01,0xFF,0x00,0x01},/*"q",81*/
{0x01,0x04,0x01,0x04,0x01,0xFC,0x00,0x84,0x01,0x04,0x01,0x00,0x01,0x80,0x00,0x00},/*"r",82*/
{0x00,0x00,0x00,0xCC,0x01,0x24,0x01,0x24,0x01,0x24,0x01,0x24,0x01,0x98,0x00,0x00},/*"s",83*/
{0x00,0x00,0x01,0x00,0x01,0x00,0x07,0xF8,0x01,0x04,0x01,0x04,0x00,0x00,0x00,0x00},/*"t",84*/
{0x01,0x00,0x01,0xF8,0x00,0x04,0x00,0x04,0x00,0x04,0x01,0x08,0x01,0xFC,0x00,0x04},/*"u",85*/
{0x01,0x00,0x01,0x80,0x01,0x70,0x00,0x0C,0x00,0x10,0x01,0x60,0x01,0x80,0x01,0x00},/*"v",86*/
{0x01,0xF0,0x01,0x0C,0x00,0x30,0x01,0xC0,0x00,0x30,0x01,0x0C,0x01,0xF0,0x01,0x00},/*"w",87*/
{0x00,0x00,0x01,0x04,0x01,0x8C,0x00,0x74,0x01,0x70,0x01,0x8C,0x01,0x04,0x00,0x00},/*"x",88*/
{0x01,0x01,0x01,0x81,0x01,0x71,0x00,0x0E,0x00,0x18,0x01,0x60,0x01,0x80,0x01,0x00},/*"y",89*/
{0x00,0x00,0x01,0x84,0x01,0x0C,0x01,0x34,0x01,0x44,0x01,0x84,0x01,0x0C,0x00,0x00},/*"z",90*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x3E,0xFC,0x40,0x02,0x40,0x02},/*"{",91*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00},/*"|",92*/
{0x00,0x00,0x40,0x02,0x40,0x02,0x3E,0xFC,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"}",93*/
{0x00,0x00,0x60,0x00,0x80,0x00,0x80,0x00,0x40,0x00,0x40,0x00,0x20,0x00,0x20,0x00},/*"~",94*/
//24*24 ASICII字符集点阵
const unsigned char asc2_2412s[95][36]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*" ",0*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x80,0x38,0x0F,0xFE,0x38,0x0F,0x80,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",1*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x06,0x00,0x00,0x0C,0x00,0x00,0x38,0x00,0x00,0x31,0x00,0x00,0x06,0x00,0x00,0x0C,0x00,0x00,0x38,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00},/*""",2*/
{0x00,0x00,0x00,0x00,0x61,0x80,0x00,0x67,0xF8,0x07,0xF9,0x80,0x00,0x61,0x80,0x00,0x61,0x80,0x00,0x61,0x80,0x00,0x61,0x80,0x00,0x67,0xF8,0x07,0xF9,0x80,0x00,0x61,0x80,0x00,0x00,0x00},/*"#",3*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0xE0,0x03,0xE0,0xF0,0x06,0x30,0x08,0x04,0x18,0x08,0x1F,0xFF,0xFE,0x04,0x0E,0x08,0x07,0x87,0xF0,0x03,0x81,0xE0,0x00,0x00,0x00,0x00,0x00,0x00},/*"$",4*/
{0x01,0xF0,0x00,0x06,0x0C,0x00,0x04,0x04,0x08,0x06,0x0C,0x70,0x01,0xF9,0xC0,0x00,0x0E,0x00,0x00,0x3B,0xE0,0x00,0xEC,0x18,0x07,0x08,0x08,0x04,0x0C,0x18,0x00,0x03,0xE0,0x00,0x00,0x00},/*"%",5*/
{0x00,0x01,0xE0,0x00,0x07,0xF0,0x03,0xF8,0x18,0x04,0x1C,0x08,0x04,0x17,0x08,0x07,0xE1,0xD0,0x03,0xC0,0xE0,0x00,0x23,0xB0,0x00,0x3C,0x08,0x00,0x20,0x08,0x00,0x00,0x10,0x00,0x00,0x00},/*"&",6*/
{0x00,0x00,0x00,0x01,0x00,0x00,0x31,0x00,0x00,0x32,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"'",7*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x00,0x01,0xFF,0xC0,0x07,0x80,0xF0,0x0C,0x00,0x18,0x10,0x00,0x04,0x20,0x00,0x02,0x00,0x00,0x00},/*"(",8*/
{0x00,0x00,0x00,0x20,0x00,0x02,0x10,0x00,0x04,0x0C,0x00,0x18,0x07,0x80,0xF0,0x01,0xFF,0xC0,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*")",9*/
{0x00,0x00,0x00,0x00,0x42,0x00,0x00,0x66,0x00,0x00,0x66,0x00,0x00,0x3C,0x00,0x00,0x18,0x00,0x03,0xFF,0xC0,0x00,0x18,0x00,0x00,0x3C,0x00,0x00,0x66,0x00,0x00,0x66,0x00,0x00,0x42,0x00},/*"*",10*/
{0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x01,0xFF,0xC0,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00},/*"+",11*/
{0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x31,0x00,0x00,0x32,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",12*/
{0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x00,0x00},/*"-",13*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x00,0x00,0x38,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*".",14*/
{0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x1C,0x00,0x00,0x70,0x00,0x01,0x80,0x00,0x0E,0x00,0x00,0x38,0x00,0x00,0xC0,0x00,0x07,0x00,0x00,0x1C,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00},/*"/",15*/
{0x00,0x00,0x00,0x00,0x7F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x06,0x00,0x18,0x04,0x00,0x08,0x04,0x00,0x08,0x06,0x00,0x18,0x03,0x80,0x70,0x01,0xFF,0xE0,0x00,0x7F,0x80,0x00,0x00,0x00},/*"0",16*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x08,0x01,0x00,0x08,0x01,0x00,0x08,0x03,0xFF,0xF8,0x07,0xFF,0xF8,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00},/*"1",17*/
{0x00,0x00,0x00,0x01,0xC0,0x38,0x02,0xC0,0x58,0x04,0x00,0x98,0x04,0x01,0x18,0x04,0x02,0x18,0x04,0x04,0x18,0x06,0x1C,0x18,0x03,0xF8,0x18,0x01,0xE0,0xF8,0x00,0x00,0x00,0x00,0x00,0x00},/*"2",18*/
{0x00,0x00,0x00,0x01,0xC0,0xE0,0x03,0xC0,0xF0,0x04,0x00,0x08,0x04,0x08,0x08,0x04,0x08,0x08,0x06,0x18,0x08,0x03,0xF4,0x18,0x01,0xE7,0xF0,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00},/*"3",19*/
{0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x0D,0x00,0x00,0x11,0x00,0x00,0x61,0x00,0x00,0x81,0x08,0x03,0x01,0x08,0x07,0xFF,0xF8,0x0F,0xFF,0xF8,0x00,0x01,0x08,0x00,0x01,0x08,0x00,0x00,0x00},/*"4",20*/
{0x00,0x00,0x00,0x00,0x00,0xE0,0x07,0xFC,0xD0,0x06,0x08,0x08,0x06,0x10,0x08,0x06,0x10,0x08,0x06,0x10,0x08,0x06,0x18,0x38,0x06,0x0F,0xF0,0x06,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00},/*"5",21*/
{0x00,0x00,0x00,0x00,0x3F,0x80,0x01,0xFF,0xE0,0x03,0x84,0x30,0x02,0x08,0x18,0x04,0x10,0x08,0x04,0x10,0x08,0x04,0x10,0x08,0x07,0x18,0x10,0x03,0x0F,0xF0,0x00,0x07,0xC0,0x00,0x00,0x00},/*"6",22*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x00,0x07,0x00,0x00,0x06,0x00,0x00,0x06,0x00,0xF8,0x06,0x07,0xF8,0x06,0x18,0x00,0x06,0xE0,0x00,0x07,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x00},/*"7",23*/
{0x00,0x00,0x00,0x01,0xE1,0xE0,0x03,0xF7,0xF0,0x06,0x34,0x10,0x04,0x18,0x08,0x04,0x18,0x08,0x04,0x0C,0x08,0x04,0x0C,0x08,0x06,0x16,0x18,0x03,0xF3,0xF0,0x01,0xC1,0xE0,0x00,0x00,0x00},/*"8",24*/
{0x00,0x00,0x00,0x00,0xF8,0x00,0x03,0xFC,0x30,0x03,0x06,0x38,0x04,0x02,0x08,0x04,0x02,0x08,0x04,0x02,0x08,0x04,0x04,0x10,0x03,0x08,0xF0,0x01,0xFF,0xC0,0x00,0x7F,0x00,0x00,0x00,0x00},/*"9",25*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x38,0x00,0x70,0x38,0x00,0x70,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*":",26*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x1A,0x00,0x30,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*";",27*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x14,0x00,0x00,0x22,0x00,0x00,0x41,0x00,0x00,0x80,0x80,0x01,0x00,0x40,0x02,0x00,0x20,0x04,0x00,0x10,0x08,0x00,0x08,0x00,0x00,0x00},/*"<",28*/
{0x00,0x00,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x21,0x00,0x00,0x00,0x00},/*"=",29*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x08,0x04,0x00,0x10,0x02,0x00,0x20,0x01,0x00,0x40,0x00,0x80,0x80,0x00,0x41,0x00,0x00,0x22,0x00,0x00,0x14,0x00,0x00,0x08,0x00,0x00,0x00,0x00},/*">",30*/
{0x00,0x00,0x00,0x03,0xC0,0x00,0x04,0xC0,0x00,0x04,0x00,0x00,0x08,0x00,0x38,0x08,0x0F,0x38,0x08,0x08,0x38,0x08,0x10,0x00,0x0C,0x30,0x00,0x07,0xE0,0x00,0x03,0xC0,0x00,0x00,0x00,0x00},/*"?",31*/
{0x00,0x00,0x00,0x00,0x3F,0x80,0x00,0xFF,0xE0,0x03,0x80,0x70,0x02,0x0F,0x10,0x06,0x70,0x88,0x04,0xC0,0x88,0x04,0x83,0x08,0x04,0x7F,0x88,0x02,0xC0,0x90,0x03,0x01,0x20,0x00,0xFE,0x40},/*"@",32*/
{0x00,0x00,0x08,0x00,0x00,0x18,0x00,0x01,0xF8,0x00,0x3E,0x08,0x01,0xC2,0x00,0x07,0x02,0x00,0x07,0xE2,0x00,0x00,0xFE,0x00,0x00,0x1F,0xC8,0x00,0x01,0xF8,0x00,0x00,0x38,0x00,0x00,0x08},/*"A",33*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x08,0x08,0x04,0x08,0x08,0x04,0x08,0x08,0x04,0x08,0x08,0x06,0x18,0x08,0x03,0xF4,0x18,0x01,0xE7,0xF0,0x00,0x01,0xE0,0x00,0x00,0x00},/*"B",34*/
{0x00,0x00,0x00,0x00,0x3F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x02,0x00,0x18,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x10,0x06,0x00,0x20,0x07,0x80,0xC0,0x00,0x00,0x00},/*"C",35*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x18,0x02,0x00,0x10,0x03,0x80,0x70,0x01,0xFF,0xE0,0x00,0x7F,0x80,0x00,0x00,0x00},/*"D",36*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x08,0x08,0x04,0x08,0x08,0x04,0x08,0x08,0x04,0x08,0x08,0x04,0x3E,0x08,0x04,0x00,0x08,0x06,0x00,0x18,0x01,0x00,0x60,0x00,0x00,0x00},/*"E",37*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x08,0x08,0x04,0x08,0x00,0x04,0x08,0x00,0x04,0x08,0x00,0x04,0x3E,0x00,0x06,0x00,0x00,0x06,0x00,0x00,0x01,0x80,0x00,0x00,0x00,0x00},/*"F",38*/
{0x00,0x00,0x00,0x00,0x3F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x06,0x00,0x18,0x04,0x00,0x08,0x04,0x02,0x08,0x04,0x02,0x08,0x02,0x03,0xF0,0x07,0x83,0xF0,0x00,0x02,0x00,0x00,0x02,0x00},/*"G",39*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x08,0x08,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x04,0x08,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08},/*"H",40*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00},/*"I",41*/
{0x00,0x00,0x00,0x00,0x00,0x06,0x00,0x00,0x07,0x00,0x00,0x01,0x04,0x00,0x01,0x04,0x00,0x01,0x04,0x00,0x03,0x07,0xFF,0xFE,0x07,0xFF,0xFC,0x04,0x00,0x00,0x04,0x00,0x00,0x04,0x00,0x00},/*"J",42*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x0C,0x08,0x00,0x18,0x00,0x00,0x3E,0x00,0x04,0xC7,0x80,0x05,0x03,0xC8,0x06,0x00,0xF8,0x04,0x00,0x38,0x04,0x00,0x18,0x00,0x00,0x08},/*"K",43*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x18,0x00,0x00,0x60,0x00,0x00,0x00},/*"L",44*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0x80,0x08,0x07,0xFC,0x00,0x00,0x7F,0xC0,0x00,0x03,0xF8,0x00,0x07,0xC0,0x00,0x78,0x00,0x07,0x80,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08},/*"M",45*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0x00,0x08,0x03,0xC0,0x00,0x00,0xE0,0x00,0x00,0x38,0x00,0x00,0x1E,0x00,0x00,0x07,0x00,0x00,0x01,0xC0,0x04,0x00,0xF0,0x07,0xFF,0xF8,0x04,0x00,0x00},/*"N",46*/
{0x00,0x00,0x00,0x00,0x7F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x06,0x00,0x18,0x04,0x00,0x08,0x04,0x00,0x08,0x06,0x00,0x18,0x03,0x00,0x30,0x01,0xFF,0xE0,0x00,0x7F,0x80,0x00,0x00,0x00},/*"O",47*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x04,0x08,0x04,0x04,0x00,0x04,0x04,0x00,0x04,0x04,0x00,0x04,0x04,0x00,0x06,0x0C,0x00,0x03,0xF8,0x00,0x01,0xF0,0x00,0x00,0x00,0x00},/*"P",48*/
{0x00,0x00,0x00,0x00,0x7F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x06,0x00,0x88,0x04,0x00,0x88,0x04,0x00,0xC8,0x06,0x00,0x3C,0x03,0x00,0x3E,0x01,0xFF,0xE6,0x00,0x7F,0x84,0x00,0x00,0x00},/*"Q",49*/
{0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x08,0x08,0x04,0x08,0x00,0x04,0x0C,0x00,0x04,0x0F,0x00,0x04,0x0B,0xC0,0x06,0x10,0xF0,0x03,0xF0,0x38,0x01,0xE0,0x08,0x00,0x00,0x08},/*"R",50*/
{0x00,0x00,0x00,0x01,0xE0,0xF8,0x03,0xF0,0x30,0x06,0x30,0x10,0x04,0x18,0x08,0x04,0x18,0x08,0x04,0x0C,0x08,0x04,0x0C,0x08,0x02,0x06,0x18,0x02,0x07,0xF0,0x07,0x81,0xE0,0x00,0x00,0x00},/*"S",51*/
{0x01,0x80,0x00,0x06,0x00,0x00,0x04,0x00,0x00,0x04,0x00,0x00,0x04,0x00,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x04,0x00,0x08,0x04,0x00,0x00,0x04,0x00,0x00,0x06,0x00,0x00,0x01,0x80,0x00},/*"T",52*/
{0x04,0x00,0x00,0x07,0xFF,0xE0,0x07,0xFF,0xF0,0x04,0x00,0x18,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x04,0x00,0x10,0x07,0xFF,0xE0,0x04,0x00,0x00},/*"U",53*/
{0x04,0x00,0x00,0x06,0x00,0x00,0x07,0xE0,0x00,0x07,0xFE,0x00,0x04,0x1F,0xE0,0x00,0x01,0xF8,0x00,0x00,0x38,0x00,0x01,0xE0,0x04,0x3E,0x00,0x07,0xC0,0x00,0x06,0x00,0x00,0x04,0x00,0x00},/*"V",54*/
{0x04,0x00,0x00,0x07,0xE0,0x00,0x07,0xFF,0xC0,0x04,0x1F,0xF8,0x00,0x07,0xC0,0x07,0xF8,0x00,0x07,0xFF,0x80,0x04,0x3F,0xF8,0x00,0x07,0xC0,0x04,0xF8,0x00,0x07,0x00,0x00,0x04,0x00,0x00},/*"W",55*/
{0x00,0x00,0x00,0x04,0x00,0x08,0x06,0x00,0x18,0x07,0xC0,0x78,0x05,0xF1,0xC8,0x00,0x3E,0x00,0x00,0x1F,0x80,0x04,0x63,0xE8,0x07,0x80,0xF8,0x06,0x00,0x18,0x04,0x00,0x08,0x00,0x00,0x00},/*"X",56*/
{0x04,0x00,0x00,0x06,0x00,0x00,0x07,0x80,0x00,0x07,0xE0,0x08,0x04,0x7C,0x08,0x00,0x1F,0xF8,0x00,0x07,0xF8,0x00,0x18,0x08,0x04,0xE0,0x08,0x07,0x00,0x00,0x06,0x00,0x00,0x04,0x00,0x00},/*"Y",57*/
{0x00,0x00,0x00,0x01,0x00,0x08,0x06,0x00,0x38,0x04,0x00,0xF8,0x04,0x03,0xE8,0x04,0x0F,0x08,0x04,0x7C,0x08,0x05,0xF0,0x08,0x07,0xC0,0x08,0x07,0x00,0x18,0x04,0x00,0x60,0x00,0x00,0x00},/*"Z",58*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFE,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x00,0x00,0x00},/*"[",59*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x07,0x00,0x00,0x00,0xC0,0x00,0x00,0x38,0x00,0x00,0x06,0x00,0x00,0x01,0xC0,0x00,0x00,0x30,0x00,0x00,0x0E,0x00,0x00,0x01,0x00,0x00,0x00},/*"\",60*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x20,0x00,0x02,0x3F,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"]",61*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x10,0x00,0x00,0x30,0x00,0x00,0x20,0x00,0x00,0x30,0x00,0x00,0x10,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"^",62*/
{0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01,0x00,0x00,0x01},/*"_",63*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x20,0x00,0x00,0x10,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"`",64*/
{0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x19,0xF8,0x00,0x1B,0x18,0x00,0x22,0x08,0x00,0x26,0x08,0x00,0x24,0x08,0x00,0x24,0x10,0x00,0x3F,0xF8,0x00,0x1F,0xF8,0x00,0x00,0x08,0x00,0x00,0x18},/*"a",65*/
{0x00,0x00,0x00,0x04,0x00,0x00,0x07,0xFF,0xF8,0x0F,0xFF,0xF0,0x00,0x18,0x18,0x00,0x10,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x30,0x18,0x00,0x1F,0xF0,0x00,0x0F,0xC0,0x00,0x00,0x00},/*"b",66*/
{0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x1F,0xF0,0x00,0x18,0x30,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x3C,0x08,0x00,0x1C,0x10,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00},/*"c",67*/
{0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x1F,0xF0,0x00,0x38,0x18,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x04,0x10,0x10,0x07,0xFF,0xF8,0x0F,0xFF,0xF0,0x00,0x00,0x10,0x00,0x00,0x00},/*"d",68*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x1F,0xF0,0x00,0x12,0x30,0x00,0x22,0x18,0x00,0x22,0x08,0x00,0x22,0x08,0x00,0x32,0x08,0x00,0x1E,0x10,0x00,0x0E,0x20,0x00,0x00,0x00},/*"e",69*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x20,0x08,0x00,0x20,0x08,0x01,0xFF,0xF8,0x03,0xFF,0xF8,0x06,0x20,0x08,0x04,0x20,0x08,0x04,0x20,0x08,0x07,0x20,0x00,0x03,0x00,0x00,0x00,0x00,0x00},/*"f",70*/
{0x00,0x00,0x00,0x00,0x00,0x0E,0x00,0x0E,0x6E,0x00,0x1F,0xF3,0x00,0x31,0xB1,0x00,0x20,0xB1,0x00,0x20,0xB1,0x00,0x31,0x91,0x00,0x1F,0x13,0x00,0x2E,0x1E,0x00,0x20,0x0E,0x00,0x30,0x00},/*"g",71*/
{0x00,0x00,0x00,0x04,0x00,0x08,0x07,0xFF,0xF8,0x0F,0xFF,0xF8,0x00,0x10,0x08,0x00,0x20,0x00,0x00,0x20,0x00,0x00,0x20,0x08,0x00,0x3F,0xF8,0x00,0x1F,0xF8,0x00,0x00,0x08,0x00,0x00,0x00},/*"h",72*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x06,0x3F,0xF8,0x06,0x3F,0xF8,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00},/*"i",73*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x03,0x00,0x20,0x01,0x00,0x20,0x01,0x00,0x20,0x03,0x06,0x3F,0xFE,0x06,0x3F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"j",74*/
{0x00,0x00,0x00,0x04,0x00,0x08,0x07,0xFF,0xF8,0x0F,0xFF,0xF8,0x00,0x01,0x88,0x00,0x03,0x00,0x00,0x2F,0xC0,0x00,0x38,0xF8,0x00,0x20,0x38,0x00,0x20,0x08,0x00,0x00,0x08,0x00,0x00,0x00},/*"k",75*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x08,0x04,0x00,0x08,0x04,0x00,0x08,0x07,0xFF,0xF8,0x0F,0xFF,0xF8,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00},/*"l",76*/
{0x00,0x20,0x08,0x00,0x3F,0xF8,0x00,0x3F,0xF8,0x00,0x10,0x08,0x00,0x20,0x00,0x00,0x3F,0xF8,0x00,0x3F,0xF8,0x00,0x10,0x08,0x00,0x20,0x00,0x00,0x3F,0xF8,0x00,0x3F,0xF8,0x00,0x00,0x08},/*"m",77*/
{0x00,0x00,0x00,0x00,0x20,0x08,0x00,0x3F,0xF8,0x00,0x3F,0xF8,0x00,0x10,0x08,0x00,0x10,0x00,0x00,0x20,0x00,0x00,0x20,0x08,0x00,0x3F,0xF8,0x00,0x1F,0xF8,0x00,0x00,0x08,0x00,0x00,0x00},/*"n",78*/
{0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x0F,0xF0,0x00,0x18,0x30,0x00,0x30,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x30,0x08,0x00,0x18,0x30,0x00,0x0F,0xF0,0x00,0x07,0xC0,0x00,0x00,0x00},/*"o",79*/
{0x00,0x00,0x00,0x00,0x20,0x01,0x00,0x3F,0xFF,0x00,0x3F,0xFF,0x00,0x10,0x11,0x00,0x20,0x09,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x30,0x38,0x00,0x1F,0xF0,0x00,0x0F,0xC0,0x00,0x00,0x00},/*"p",80*/
{0x00,0x00,0x00,0x00,0x07,0xC0,0x00,0x1F,0xF0,0x00,0x38,0x18,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x09,0x00,0x10,0x11,0x00,0x1F,0xFF,0x00,0x3F,0xFF,0x00,0x00,0x01,0x00,0x00,0x00},/*"q",81*/
{0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x3F,0xF8,0x00,0x3F,0xF8,0x00,0x08,0x08,0x00,0x10,0x08,0x00,0x20,0x08,0x00,0x20,0x00,0x00,0x30,0x00,0x00,0x30,0x00,0x00,0x00,0x00},/*"r",82*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0C,0x78,0x00,0x1E,0x18,0x00,0x33,0x08,0x00,0x23,0x08,0x00,0x21,0x08,0x00,0x21,0x88,0x00,0x21,0x98,0x00,0x30,0xF0,0x00,0x38,0x60,0x00,0x00,0x00},/*"s",83*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x20,0x00,0x00,0x20,0x00,0x00,0xFF,0xF0,0x03,0xFF,0xF8,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00},/*"t",84*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x3F,0xF0,0x00,0x7F,0xF8,0x00,0x00,0x18,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x20,0x10,0x00,0x3F,0xF8,0x00,0x7F,0xF0,0x00,0x00,0x10,0x00,0x00,0x00},/*"u",85*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x30,0x00,0x00,0x3C,0x00,0x00,0x3F,0x80,0x00,0x23,0xF0,0x00,0x00,0x78,0x00,0x00,0x70,0x00,0x23,0x80,0x00,0x3C,0x00,0x00,0x30,0x00,0x00,0x20,0x00},/*"v",86*/
{0x00,0x20,0x00,0x00,0x3C,0x00,0x00,0x3F,0xE0,0x00,0x23,0xF8,0x00,0x00,0xE0,0x00,0x27,0x00,0x00,0x3E,0x00,0x00,0x3F,0xE0,0x00,0x21,0xF8,0x00,0x01,0xE0,0x00,0x3E,0x00,0x00,0x20,0x00},/*"w",87*/
{0x00,0x00,0x00,0x00,0x20,0x08,0x00,0x20,0x08,0x00,0x38,0x38,0x00,0x3E,0x68,0x00,0x27,0x80,0x00,0x03,0xC8,0x00,0x2C,0xF8,0x00,0x38,0x38,0x00,0x20,0x18,0x00,0x20,0x08,0x00,0x00,0x00},/*"x",88*/
{0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x30,0x03,0x00,0x3C,0x01,0x00,0x3F,0x83,0x00,0x23,0xEC,0x00,0x00,0x70,0x00,0x23,0x80,0x00,0x3C,0x00,0x00,0x20,0x00,0x00,0x20,0x00,0x00,0x00,0x00},/*"y",89*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x08,0x00,0x20,0x38,0x00,0x20,0xF8,0x00,0x23,0xE8,0x00,0x2F,0x88,0x00,0x3E,0x08,0x00,0x38,0x08,0x00,0x20,0x18,0x00,0x00,0x70,0x00,0x00,0x00},/*"z",90*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x14,0x00,0x1F,0xF7,0xFC,0x30,0x00,0x06,0x20,0x00,0x02,0x00,0x00,0x00,0x00,0x00,0x00},/*"{",91*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"|",92*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x02,0x30,0x00,0x06,0x1F,0xF7,0xFC,0x00,0x14,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"}",93*/
{0x00,0x00,0x00,0x18,0x00,0x00,0x60,0x00,0x00,0x40,0x00,0x00,0x40,0x00,0x00,0x20,0x00,0x00,0x10,0x00,0x00,0x08,0x00,0x00,0x04,0x00,0x00,0x04,0x00,0x00,0x0C,0x00,0x00,0x10,0x00,0x00},/*"~",94*/
unsigned char Hzk1s[100][16]={
{0x08,0x08,0x08,0xF8,0x08,0x08,0x08,0x10,0x10,0xFF,0x10,0x10,0x10,0xF0,0x00,0x00},
{0x10,0x30,0x10,0x1F,0x08,0x88,0x48,0x30,0x0E,0x01,0x40,0x80,0x40,0x3F,0x00,0x00},/*"功",0*/
{0x00,0x14,0xA4,0x44,0x24,0x34,0xAD,0x66,0x24,0x94,0x04,0x44,0xA4,0x14,0x00,0x00},
{0x08,0x09,0x08,0x08,0x09,0x09,0x09,0xFD,0x09,0x09,0x0B,0x08,0x08,0x09,0x08,0x00},/*"率",1*/
{0x00,0x00,0x7E,0x00,0x00,0xFF,0x00,0x40,0x30,0x0F,0x04,0x14,0x64,0x04,0x00,0x00},
{0x40,0x40,0x7E,0x42,0x42,0x7E,0x42,0x42,0x42,0x7E,0x42,0x42,0x7E,0x40,0x40,0x00},/*"监",2*/
{0x10,0x60,0x02,0x8C,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0xFF,0x00,0x00},
{0x04,0x04,0x7E,0x01,0x80,0x47,0x30,0x0F,0x10,0x27,0x00,0x47,0x80,0x7F,0x00,0x00},/*"测",3*/
{0x00,0x00,0xE0,0x9F,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x88,0x08,0x00,0x00},
{0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x48,0x80,0x40,0x3F,0x00,0x00,0x00},/*"与",4*/
{0x10,0x10,0x10,0xFF,0x90,0x20,0x98,0x48,0x28,0x09,0x0E,0x28,0x48,0xA8,0x18,0x00},
{0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x40,0x00},/*"控",5*/
{0x40,0x50,0x4E,0x48,0x48,0xFF,0x48,0x48,0x48,0x40,0xF8,0x00,0x00,0xFF,0x00,0x00},
{0x00,0x00,0x3E,0x02,0x02,0xFF,0x12,0x22,0x1E,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00},/*"制",6*/
{0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00},
{0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},/*"电",7*/
{0x10,0x60,0x02,0x8C,0x00,0x44,0x64,0x54,0x4D,0x46,0x44,0x54,0x64,0xC4,0x04,0x00},
{0x04,0x04,0x7E,0x01,0x80,0x40,0x3E,0x00,0x00,0xFE,0x00,0x00,0x7E,0x80,0xE0,0x00},/*"流",8*/
{0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},/*"电",9*/
{0x00,0x00,0xFE,0x02,0x82,0x82,0x82,0x82,0xFA,0x82,0x82,0x82,0x82,0x82,0x02,0x00},
{0x80,0x60,0x1F,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x44,0x58,0x40,0x40,0x00},/*"压",10*/
{0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},/*"电",11*/
{0x04,0x04,0x7E,0x01,0x80,0x40,0x3E,0x00,0x00,0xFE,0x00,0x00,0x7E,0x80,0xE0,0x00},/*"流",12*/
{0x00,0xF8,0x01,0x22,0xA0,0xA2,0xA2,0x22,0xFE,0x22,0xAA,0x32,0x02,0xFE,0x00,0x00},
{0x00,0xFF,0x00,0x10,0x13,0x0A,0x4B,0x20,0x17,0x0C,0x13,0x38,0x80,0xFF,0x00,0x00},/*"阈",13*/
{0x00,0x80,0x60,0xF8,0x07,0x04,0xE4,0xA4,0xA4,0xBF,0xA4,0xA4,0xE4,0x04,0x00,0x00},
{0x01,0x00,0x00,0xFF,0x40,0x40,0x7F,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x40,0x40,0x00},/*"值",14*/
{0x40,0x40,0x42,0xCC,0x00,0x08,0x48,0x88,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x00},
{0x00,0x40,0x20,0x1F,0x20,0x40,0x40,0x41,0x40,0x48,0x50,0x4F,0x40,0x40,0x40,0x00},/*"过",15*/
{0x04,0x04,0x7E,0x01,0x80,0x40,0x3E,0x00,0x00,0xFE,0x00,0x00,0x7E,0x80,0xE0,0x00},/*"流",16*/
{0x00,0x08,0x30,0x00,0xFF,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x22,0x2C,0x20,0x00},
{0x04,0x04,0x02,0x01,0xFF,0x80,0x40,0x30,0x0E,0x01,0x06,0x18,0x20,0x40,0x80,0x00},/*"状",17*/
{0x00,0x04,0x84,0x84,0x44,0x24,0x54,0x8F,0x14,0x24,0x44,0x84,0x84,0x04,0x00,0x00},
{0x41,0x39,0x00,0x00,0x3C,0x40,0x40,0x42,0x4C,0x40,0x40,0x70,0x04,0x09,0x31,0x00},/*"态",18*/
{0x00,0x02,0x02,0xC2,0x02,0x02,0x02,0xFE,0x82,0x82,0x82,0x82,0x82,0x02,0x00,0x00},
{0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00},/*"正",19*/
{0x20,0x18,0x08,0xEA,0xAC,0xA8,0xA8,0xAF,0xA8,0xA8,0xAC,0xEA,0x08,0x28,0x18,0x00},
{0x00,0x00,0x3E,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x12,0x22,0x1E,0x00,0x00,0x00},/*"常",20*/
{0x00,0x00,0x7E,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x92,0x9E,0x80,0xE0,0x00,0x00},
{0x08,0x88,0x48,0x28,0x1E,0x08,0x08,0x08,0x08,0x08,0xFE,0x08,0x08,0x08,0x08,0x00},/*"异",21*/
{0x00,0x00,0x3E,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x12,0x22,0x1E,0x00,0x00,0x00},/*"常",22*/
{0x00,0x10,0x88,0xC4,0x33,0x00,0xBE,0xAA,0xAA,0xAA,0xAA,0xAA,0xBE,0x80,0x00,0x00},
{0x02,0x01,0x00,0xFF,0x00,0x02,0x0A,0x12,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x00},/*"得",23*/
{0x10,0x10,0xFF,0x10,0x90,0x44,0x54,0x54,0x54,0xFF,0x54,0x54,0xF4,0x44,0x44,0x00},
{0x42,0x82,0x7F,0x01,0x80,0x60,0x1D,0x21,0x41,0x7F,0x49,0x49,0x49,0x48,0x40,0x00},/*"捷",24*/
{0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00},/*"电",25*/
{0x80,0x82,0x82,0x82,0x82,0x82,0x82,0xE2,0xA2,0x92,0x8A,0x86,0x82,0x80,0x80,0x00},
{0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"子",26*/
unsigned char Hzk2s[3][72]={
{0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0xFC,0x84,0x80,0x80,0x80,0x80,0x80,0x80,0xC0,0xC0,0x00,0x00,0x00},
{0x00,0x00,0x00,0xFF,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x7F,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},	/*"中",0*/
unsigned char Hzk3s[4][128]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0xFF,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFF,0xFF,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFF,0x03,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x1F,0x1F,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFF,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x1F,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"中",0*/
unsigned char Hzk4s[8][512]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0xF8,0xF0,0xF0,0x70,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFE,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0xFF,0xFF,0xFF,0xFF,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0xFF,0xFF,0xFF,0xFF,0x07,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0xFF,0xFF,0xFF,0xFF,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"中",0*/
#endif
ssd1306_fonts.h
#ifndef __SSD1306_FONTS_H__
#define __SSD1306_FONTS_H__
#include "ssd1306.h"
#ifdef SSD1306_INCLUDE_FONT_6x8
extern const SSD1306_Font_t Font_6x8;
#endif
#ifdef SSD1306_INCLUDE_FONT_7x10
extern const SSD1306_Font_t Font_7x10;
#endif
#ifdef SSD1306_INCLUDE_FONT_11x18
extern const SSD1306_Font_t Font_11x18;
#endif
#ifdef SSD1306_INCLUDE_FONT_16x26
extern const SSD1306_Font_t Font_16x26;
#endif
#ifdef SSD1306_INCLUDE_FONT_16x24
extern const SSD1306_Font_t Font_16x24;
#endif
#ifdef SSD1306_INCLUDE_FONT_16x15
/** Generated Roboto Thin 15
 * @copyright Google https://github.com/googlefonts/roboto
 * @license This font is licensed under the Apache License, Version 2.0.
extern const SSD1306_Font_t Font_16x15;
extern const uint8_t image_a[];
extern const uint8_t image_b[];
extern const uint8_t image_c[];
extern const uint8_t image_d[];
#endif
#endif // __SSD1306_FONTS_H__
ssd1306_conf.h
#ifndef __SSD1306_CONF_H__
#define __SSD1306_CONF_H__
// Choose a microcontroller family
//#define STM32F0
//#define STM32F1
#define STM32F4
//#define STM32L0
//#define STM32L1
//#define STM32L4
//#define STM32F3
//#define STM32H7
//#define STM32F7
//#define STM32G0
// Choose a bus
#define SSD1306_USE_I2C
//#define SSD1306_USE_SPI
// I2C Configuration
#define SSD1306_I2C_PORT        hi2c1
#define SSD1306_I2C_ADDR        (0x3C << 1)
// SPI Configuration
//#define SSD1306_SPI_PORT        hspi1
//#define SSD1306_CS_Port         OLED_CS_GPIO_Port
//#define SSD1306_CS_Pin          OLED_CS_Pin
//#define SSD1306_DC_Port         OLED_DC_GPIO_Port
//#define SSD1306_DC_Pin          OLED_DC_Pin
//#define SSD1306_Reset_Port      OLED_Res_GPIO_Port
//#define SSD1306_Reset_Pin       OLED_Res_Pin
// Mirror the screen if needed
// #define SSD1306_MIRROR_VERT
// #define SSD1306_MIRROR_HORIZ
// Set inverse color if needed
// # define SSD1306_INVERSE_COLOR
// Include only needed fonts
#define SSD1306_INCLUDE_FONT_6x8
#define SSD1306_INCLUDE_FONT_7x10
#define SSD1306_INCLUDE_FONT_11x18
#define SSD1306_INCLUDE_FONT_16x26
#define SSD1306_INCLUDE_FONT_16x24
#define SSD1306_INCLUDE_FONT_16x15
// The width of the screen can be set using this
// define. The default value is 128.
// #define SSD1306_WIDTH           64
// If your screen horizontal axis does not start
// in column 0 you can use this define to
// adjust the horizontal offset
// #define SSD1306_X_OFFSET
// The height can be changed as well if necessary.
// It can be 32, 64 or 128. The default value is 64.
// #define SSD1306_HEIGHT          64
#endif /* __SSD1306_CONF_H__ */
ssd1306.h
#ifndef __SSD1306_H__
#define __SSD1306_H__
#include <stddef.h>
#include <stdint.h>
//#include <_ansi.h>
//_BEGIN_STD_C
#include "ssd1306_conf.h"
//#include "bmp.h"
#if defined(STM32WB)
#include "stm32wbxx_hal.h"
#elif defined(STM32F0)
#include "stm32f0xx_hal.h"
#elif defined(STM32F1)
#include "stm32f1xx_hal.h"
#elif defined(STM32F4)
#include "stm32f4xx_hal.h"
#include "stm32f4xx_hal_gpio.h"
#elif defined(STM32L0)
#include "stm32l0xx_hal.h"
#elif defined(STM32L1)
#include "stm32l1xx_hal.h"
#elif defined(STM32L4)
#include "stm32l4xx_hal.h"
#elif defined(STM32L5)
#include "stm32l5xx_hal.h"
#elif defined(STM32F3)
#include "stm32f3xx_hal.h"
#elif defined(STM32H7)
#include "stm32h7xx_hal.h"
#elif defined(STM32F7)
#include "stm32f7xx_hal.h"
#elif defined(STM32G0)
#include "stm32g0xx_hal.h"
#elif defined(STM32G4)
#include "stm32g4xx_hal.h"
#else
#error "SSD1306 library was tested only on STM32F0, STM32F1, STM32F3, STM32F4, STM32F7, STM32L0, STM32L1, STM32L4, STM32H7, STM32G0, STM32G4, STM32WB MCU families. Please modify ssd1306.h if you know what you are doing. Also please send a pull request if it turns out the library works on other MCU's as well!"
#endif
#ifdef SSD1306_X_OFFSET
#define SSD1306_X_OFFSET_LOWER (SSD1306_X_OFFSET & 0x0F)
#define SSD1306_X_OFFSET_UPPER ((SSD1306_X_OFFSET >> 4) & 0x07)
#else
#define SSD1306_X_OFFSET_LOWER 0
#define SSD1306_X_OFFSET_UPPER 0
#endif
/* vvv I2C config vvv */
#ifndef SSD1306_I2C_PORT
#endif
#ifndef SSD1306_I2C_ADDR
#endif
/* ^^^ I2C config ^^^ */
/* vvv SPI config vvv */
#ifndef SSD1306_SPI_PORT
#endif
#ifndef SSD1306_CS_Port
#define SSD1306_CS_Port         GPIOB
#endif
#ifndef SSD1306_CS_Pin
#define SSD1306_CS_Pin          GPIO_PIN_12
#endif
#ifndef SSD1306_DC_Port
#define SSD1306_DC_Port         GPIOB
#endif
#ifndef SSD1306_DC_Pin
#define SSD1306_DC_Pin          GPIO_PIN_14
#endif
#ifndef SSD1306_Reset_Port
#define SSD1306_Reset_Port      GPIOA
#endif
#ifndef SSD1306_Reset_Pin
#define SSD1306_Reset_Pin       GPIO_PIN_8
#endif
/* ^^^ SPI config ^^^ */
#if defined(SSD1306_USE_I2C)
extern I2C_HandleTypeDef SSD1306_I2C_PORT;
#elif defined(SSD1306_USE_SPI)
extern SPI_HandleTypeDef SSD1306_SPI_PORT;
#else
#error "You should define SSD1306_USE_SPI or SSD1306_USE_I2C macro!"
#endif
// SSD1306 OLED height in pixels
#ifndef SSD1306_HEIGHT
#endif
// SSD1306 width in pixels
#ifndef SSD1306_WIDTH
#define SSD1306_WIDTH           128
#endif
#ifndef SSD1306_BUFFER_SIZE
#define SSD1306_BUFFER_SIZE   SSD1306_WIDTH * SSD1306_HEIGHT / 8
#endif
// Enumeration for screen colors
typedef enum {
    Black = 0x00, // Black color, no pixel
    White = 0x01  // Pixel is set. Color depends on OLED
} SSD1306_COLOR;
typedef enum {
    SSD1306_OK = 0x00,
    SSD1306_ERR = 0x01  // Generic error.
} SSD1306_Error_t;
// Struct to store transformations
typedef struct {
    uint16_t CurrentX;
    uint16_t CurrentY;
    uint8_t Initialized;
    uint8_t DisplayOn;
} SSD1306_t;
typedef struct {
    uint8_t x;
    uint8_t y;
} SSD1306_VERTEX;
/** Font */
typedef struct {
	const uint8_t width;                /**< Font width in pixels */
	const uint8_t height;               /**< Font height in pixels */
	const uint16_t *const data;         /**< Pointer to font data array */
    const uint8_t *const char_width;    /**< Proportional character width in pixels (NULL for monospaced) */
} SSD1306_Font_t;
// Procedure definitions
void ssd1306_Init(void);
void ssd1306_Fill(SSD1306_COLOR color);
void ssd1306_UpdateScreen(void);
void ssd1306_DrawPixel(uint8_t x, uint8_t y, SSD1306_COLOR color);
char ssd1306_WriteChar(char ch, SSD1306_Font_t Font, SSD1306_COLOR color);
char ssd1306_WriteString(char* str, SSD1306_Font_t Font, SSD1306_COLOR color);
void ssd1306_SetCursor(uint8_t x, uint8_t y);
void ssd1306_Line(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color);
void ssd1306_DrawArc(uint8_t x, uint8_t y, uint8_t radius, uint16_t start_angle, uint16_t sweep, SSD1306_COLOR color);
void ssd1306_DrawArcWithRadiusLine(uint8_t x, uint8_t y, uint8_t radius, uint16_t start_angle, uint16_t sweep, SSD1306_COLOR color);
void ssd1306_DrawCircle(uint8_t par_x, uint8_t par_y, uint8_t par_r, SSD1306_COLOR color);
void ssd1306_FillCircle(uint8_t par_x,uint8_t par_y,uint8_t par_r,SSD1306_COLOR par_color);
void ssd1306_Polyline(const SSD1306_VERTEX *par_vertex, uint16_t par_size, SSD1306_COLOR color);
void ssd1306_DrawRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color);
void ssd1306_FillRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color);
void OLED_ShowChinese(uint8_t x,uint8_t y,uint8_t num,uint8_t size1);
void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t size1);
void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t size1);
void OLED_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t size1);
 * @brief Invert color of pixels in rectangle (include border)
 * @param x1 X Coordinate of top left corner
 * @param y1 Y Coordinate of top left corner
 * @param x2 X Coordinate of bottom right corner
 * @param y2 Y Coordinate of bottom right corner
 * @return SSD1306_Error_t status
SSD1306_Error_t ssd1306_InvertRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2);
void ssd1306_DrawBitmap(uint8_t x, uint8_t y, const unsigned char* bitmap, uint8_t w, uint8_t h, SSD1306_COLOR color);
void ssd1306_DrawBitmap2(uint8_t x, uint8_t y, const unsigned char* bitmap, uint8_t w, uint8_t h, SSD1306_COLOR color);
 * @brief Sets the contrast of the display.
 * @param[in] value contrast to set.
 * @note Contrast increases as the value increases.
 * @note RESET = 7Fh.
void ssd1306_SetContrast(const uint8_t value);
 * @brief Set Display ON/OFF.
 * @param[in] on 0 for OFF, any for ON.
void ssd1306_SetDisplayOn(const uint8_t on);
 * @brief Reads DisplayOn state.
 * @return  0: OFF.
 *          1: ON.
uint8_t ssd1306_GetDisplayOn();
// Low-level procedures
void ssd1306_Reset(void);
void ssd1306_WriteCommand(uint8_t byte);
void ssd1306_WriteData(uint8_t* buffer, size_t buff_size);
SSD1306_Error_t ssd1306_FillBuffer(uint8_t* buf, uint32_t len);
//_END_STD_C
#endif // __SSD1306_H__
ssd1306.c
#include <math.h>
#include <stdlib.h>
#include <string.h>  // For memcpy
#include "delay.h"
#include "oledfont.h"
void ssd1306_Reset(void) {
    /* for I2C - do nothing */
// Send a byte to the command register
void ssd1306_WriteCommand(uint8_t byte) {
#ifdef HW_IIC
	HAL_I2C_Mem_Write(&SSD1306_I2C_PORT, SSD1306_I2C_ADDR, 0x00, 1, &byte, 1, HAL_MAX_DELAY);//0X00 cmd
	delay_us(5);
#else
//	IIC_Start();
//	IIC_Send_Data(SSD1306_I2C_ADDR);
//	IIC_Wait_Ack();
//	IIC_Send_Data(0x00);
//	IIC_Wait_Ack();
//	IIC_Send_Data(byte);
//	IIC_Wait_Ack();
//	IIC_Stop();
//	delay_ms(5);
#endif
// Send data
void ssd1306_WriteData(uint8_t* buffer, size_t buff_size) {
#ifdef HW_IIC
	HAL_I2C_Mem_Write(&SSD1306_I2C_PORT, SSD1306_I2C_ADDR, 0x40, 1, buffer, buff_size, HAL_MAX_DELAY);//0x40 data
	delay_us(5);
#else
//	for(uint32_t i=0;i<buff_size;i++){
//		IIC_Start();
//		IIC_Wait_Ack();
//		IIC_Send_Data(0x40);
//		IIC_Wait_Ack();
//		IIC_Send_Data(buffer[i]);
//		IIC_Wait_Ack();
//		IIC_Stop();
////		delay_ms(5);
#endif
    // CS = High (not selected)
    HAL_GPIO_WritePin(SSD1306_CS_Port, SSD1306_CS_Pin, GPIO_PIN_SET);
    // Reset the OLED
    HAL_GPIO_WritePin(SSD1306_Reset_Port, SSD1306_Reset_Pin, GPIO_PIN_RESET);
    delay_ms(10);
    HAL_GPIO_WritePin(SSD1306_Reset_Port, SSD1306_Reset_Pin, GPIO_PIN_SET);
    delay_ms(10);
    HAL_GPIO_WritePin(SSD1306_CS_Port, SSD1306_CS_Pin, GPIO_PIN_RESET); // select OLED
    HAL_GPIO_WritePin(SSD1306_DC_Port, SSD1306_DC_Pin, GPIO_PIN_RESET); // command
    HAL_SPI_Transmit(&SSD1306_SPI_PORT, (uint8_t *) &byte, 1, HAL_MAX_DELAY);
    HAL_GPIO_WritePin(SSD1306_CS_Port, SSD1306_CS_Pin, GPIO_PIN_SET); // un-select OLED
// Send data
    HAL_GPIO_WritePin(SSD1306_DC_Port, SSD1306_DC_Pin, GPIO_PIN_SET); // data
    HAL_SPI_Transmit(&SSD1306_SPI_PORT, buffer, buff_size, HAL_MAX_DELAY);
#else
#error "You should define SSD1306_USE_SPI or SSD1306_USE_I2C macro"
#endif
// Screenbuffer
static uint8_t SSD1306_Buffer[SSD1306_BUFFER_SIZE];
// Screen object
static SSD1306_t SSD1306;
/* Fills the Screenbuffer with values from a given buffer of a fixed length */
SSD1306_Error_t ssd1306_FillBuffer(uint8_t* buf, uint32_t len) {
    SSD1306_Error_t ret = SSD1306_ERR;
    if (len <= SSD1306_BUFFER_SIZE) {
        memcpy(SSD1306_Buffer,buf,len);
        ret = SSD1306_OK;
    return ret;
/* Initialize the oled screen */
void ssd1306_Init(void) {
    // Reset OLED
    ssd1306_Reset();
    // Wait for the screen to boot
    delay_ms(100);
    // Init OLED
    ssd1306_SetDisplayOn(0); //display off
    ssd1306_WriteCommand(0x20); //Set Memory Addressing Mode
    ssd1306_WriteCommand(0x00); // 00b,Horizontal Addressing Mode; 01b,Vertical Addressing Mode;
                                // 10b,Page Addressing Mode (RESET); 11b,Invalid
    ssd1306_WriteCommand(0xB0); //Set Page Start Address for Page Addressing Mode,0-7
#ifdef SSD1306_MIRROR_VERT
    ssd1306_WriteCommand(0xC0); // Mirror vertically
#else
    ssd1306_WriteCommand(0xC8); //Set COM Output Scan Direction
#endif
    ssd1306_WriteCommand(0x00); //---set low column address
    ssd1306_WriteCommand(0x10); //---set high column address
    ssd1306_WriteCommand(0x40); //--set start line address - CHECK
    ssd1306_SetContrast(0xFF);
#ifdef SSD1306_MIRROR_HORIZ
    ssd1306_WriteCommand(0xA0); // Mirror horizontally
#else
    ssd1306_WriteCommand(0xA1); //--set segment re-map 0 to 127 - CHECK
#endif
#ifdef SSD1306_INVERSE_COLOR
    ssd1306_WriteCommand(0xA7); //--set inverse color
#else
    ssd1306_WriteCommand(0xA6); //--set normal color
#endif
// Set multiplex ratio.
#if (SSD1306_HEIGHT == 128)
    // Found in the Luma Python lib for SH1106.
    ssd1306_WriteCommand(0xFF);
#else
    ssd1306_WriteCommand(0xA8); //--set multiplex ratio(1 to 64) - CHECK
#endif
#if (SSD1306_HEIGHT == 32)
    ssd1306_WriteCommand(0x1F); //
#elif (SSD1306_HEIGHT == 64)
    ssd1306_WriteCommand(0x3F); //
#elif (SSD1306_HEIGHT == 128)
    ssd1306_WriteCommand(0x3F); // Seems to work for 128px high displays too.
#else
#error "Only 32, 64, or 128 lines of height are supported!"
#endif
    ssd1306_WriteCommand(0xA4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
    ssd1306_WriteCommand(0xD3); //-set display offset - CHECK
    ssd1306_WriteCommand(0x00); //-not offset
    ssd1306_WriteCommand(0xD5); //--set display clock divide ratio/oscillator frequency
    ssd1306_WriteCommand(0xF0); //--set divide ratio
    ssd1306_WriteCommand(0xD9); //--set pre-charge period
    ssd1306_WriteCommand(0x22); //
    ssd1306_WriteCommand(0xDA); //--set com pins hardware configuration - CHECK
    ssd1306_WriteCommand(0x02);
    ssd1306_WriteCommand(0x12);
#else
#endif
    ssd1306_WriteCommand(0xDB); //--set vcomh
    ssd1306_WriteCommand(0x20); //0x20,0.77xVcc
    ssd1306_WriteCommand(0x8D); //--set DC-DC enable
    ssd1306_WriteCommand(0x14); //
    ssd1306_SetDisplayOn(1); //--turn on SSD1306 panel
    // Clear screen
    ssd1306_Fill(Black);
    // Flush buffer to screen
    ssd1306_UpdateScreen();
    // Set default values for screen object
    SSD1306.CurrentX = 0;
    SSD1306.CurrentY = 0;
    SSD1306.Initialized = 1;
/* Fill the whole screen with the given color */
void ssd1306_Fill(SSD1306_COLOR color) {
    memset(SSD1306_Buffer, (color == Black) ? 0x00 : 0xFF, sizeof(SSD1306_Buffer));
/* Write the screenbuffer with changed to the screen */
void ssd1306_UpdateScreen(void) {
    // Write data to each page of RAM. Number of pages
    // depends on the screen height:
    //  * 32px   ==  4 pages
    //  * 64px   ==  8 pages
    //  * 128px  ==  16 pages
    for(uint8_t i = 0; i < SSD1306_HEIGHT/8; i++) {
        ssd1306_WriteCommand(0xB0 + i); // Set the current RAM page address.
        ssd1306_WriteCommand(0x00 + SSD1306_X_OFFSET_LOWER);
        ssd1306_WriteCommand(0x10 + SSD1306_X_OFFSET_UPPER);
        ssd1306_WriteData(&SSD1306_Buffer[SSD1306_WIDTH*i],SSD1306_WIDTH);
 * Draw one pixel in the screenbuffer
 * X => X Coordinate
 * Y => Y Coordinate
 * color => Pixel color
void ssd1306_DrawPixel(uint8_t x, uint8_t y, SSD1306_COLOR color) {
    if(x >= SSD1306_WIDTH || y >= SSD1306_HEIGHT) {
        // Don't write outside the buffer
        return;
    // Draw in the right color
    if(color == White) {
        SSD1306_Buffer[x + (y / 8) * SSD1306_WIDTH] |= 1 << (y % 8);
    } else {
        SSD1306_Buffer[x + (y / 8) * SSD1306_WIDTH] &= ~(1 << (y % 8));
 * Draw 1 char to the screen buffer
 * ch       => char om weg te schrijven
 * Font     => Font waarmee we gaan schrijven
 * color    => Black or White
char ssd1306_WriteChar(char ch, SSD1306_Font_t Font, SSD1306_COLOR color) {
    uint32_t i, b, j;
    // Check if character is valid
    if (ch < 32 || ch > 126)
        return 0;
    // Check remaining space on current line
    if (SSD1306_WIDTH < (SSD1306.CurrentX + Font.width) ||
        SSD1306_HEIGHT < (SSD1306.CurrentY + Font.height))
        // Not enough space on current line
        return 0;
    // Use the font to write
    for(i = 0; i < Font.height; i++) {
        b = Font.data[(ch - 32) * Font.height + i];
        for(j = 0; j < Font.width; j++) {
            if((b << j) & 0x8000)  {
                ssd1306_DrawPixel(SSD1306.CurrentX + j, (SSD1306.CurrentY + i), (SSD1306_COLOR) color);
            } else {
                ssd1306_DrawPixel(SSD1306.CurrentX + j, (SSD1306.CurrentY + i), (SSD1306_COLOR)!color);
    // The current space is now taken
    SSD1306.CurrentX += Font.char_width ? Font.char_width[ch - 32] : Font.width;
    // Return written char for validation
    return ch;
/* Write full string to screenbuffer */
char ssd1306_WriteString(char* str, SSD1306_Font_t Font, SSD1306_COLOR color) {
    while (*str) {
        if (ssd1306_WriteChar(*str, Font, color) != *str) {
            // Char could not be written
            return *str;
        str++;
    // Everything ok
    return *str;
/* Position the cursor */
void ssd1306_SetCursor(uint8_t x, uint8_t y) {
    SSD1306.CurrentX = x;
    SSD1306.CurrentY = y;
/* Draw line by Bresenhem's algorithm */
void ssd1306_Line(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color) {
    int32_t deltaX = abs(x2 - x1);
    int32_t deltaY = abs(y2 - y1);
    int32_t signX = ((x1 < x2) ? 1 : -1);
    int32_t signY = ((y1 < y2) ? 1 : -1);
    int32_t error = deltaX - deltaY;
    int32_t error2;
    ssd1306_DrawPixel(x2, y2, color);
    while((x1 != x2) || (y1 != y2)) {
        ssd1306_DrawPixel(x1, y1, color);
        error2 = error * 2;
        if(error2 > -deltaY) {
            error -= deltaY;
            x1 += signX;
        if(error2 < deltaX) {
            error += deltaX;
            y1 += signY;
    return;
/* Draw polyline */
void ssd1306_Polyline(const SSD1306_VERTEX *par_vertex, uint16_t par_size, SSD1306_COLOR color) {
    uint16_t i;
    if(par_vertex == NULL) {
        return;
    for(i = 1; i < par_size; i++) {
        ssd1306_Line(par_vertex[i - 1].x, par_vertex[i - 1].y, par_vertex[i].x, par_vertex[i].y, color);
    return;
/* Convert Degrees to Radians */
static float ssd1306_DegToRad(float par_deg) {
    return par_deg * (3.14f / 180.0f);
/* Normalize degree to [0;360] */
static uint16_t ssd1306_NormalizeTo0_360(uint16_t par_deg) {
    uint16_t loc_angle;
    if(par_deg <= 360) {
        loc_angle = par_deg;
    } else {
        loc_angle = par_deg % 360;
        loc_angle = (loc_angle ? loc_angle : 360);
    return loc_angle;
 * DrawArc. Draw angle is beginning from 4 quart of trigonometric circle (3pi/2)
 * start_angle in degree
 * sweep in degree
void ssd1306_DrawArc(uint8_t x, uint8_t y, uint8_t radius, uint16_t start_angle, uint16_t sweep, SSD1306_COLOR color) {
    static const uint8_t CIRCLE_APPROXIMATION_SEGMENTS = 36;
    float approx_degree;
    uint32_t approx_segments;
    uint8_t xp1,xp2;
    uint8_t yp1,yp2;
    uint32_t count;
    uint32_t loc_sweep;
    float rad;
    loc_sweep = ssd1306_NormalizeTo0_360(sweep);
    count = (ssd1306_NormalizeTo0_360(start_angle) * CIRCLE_APPROXIMATION_SEGMENTS) / 360;
    approx_segments = (loc_sweep * CIRCLE_APPROXIMATION_SEGMENTS) / 360;
    approx_degree = loc_sweep / (float)approx_segments;
    while(count < approx_segments)
        rad = ssd1306_DegToRad(count*approx_degree);
        xp1 = x + (int8_t)(sinf(rad)*radius);
        yp1 = y + (int8_t)(cosf(rad)*radius);
        count++;
        if(count != approx_segments) {
        } else {
            rad = ssd1306_DegToRad(loc_sweep);
        xp2 = x + (int8_t)(sinf(rad)*radius);
        yp2 = y + (int8_t)(cosf(rad)*radius);
        ssd1306_Line(xp1,yp1,xp2,yp2,color);
    return;
 * Draw arc with radius line
 * Angle is beginning from 4 quart of trigonometric circle (3pi/2)
 * start_angle: start angle in degree
 * sweep: finish angle in degree
void ssd1306_DrawArcWithRadiusLine(uint8_t x, uint8_t y, uint8_t radius, uint16_t start_angle, uint16_t sweep, SSD1306_COLOR color) {
    const uint32_t CIRCLE_APPROXIMATION_SEGMENTS = 36;
    uint8_t xp1;
    uint8_t xp2 = 0;
    uint8_t yp1;
    uint8_t yp2 = 0;
    uint32_t count;
    uint32_t loc_sweep;
    float rad;
    uint8_t first_point_x = x + (int8_t)(sinf(rad)*radius);
    uint8_t first_point_y = y + (int8_t)(cosf(rad)*radius);
    while (count < approx_segments) {
        count++;
        if (count != approx_segments) {
        } else {
    // Radius line
    ssd1306_Line(x,y,first_point_x,first_point_y,color);
    ssd1306_Line(x,y,xp2,yp2,color);
    return;
/* Draw circle by Bresenhem's algorithm */
void ssd1306_DrawCircle(uint8_t par_x,uint8_t par_y,uint8_t par_r,SSD1306_COLOR par_color) {
    int32_t x = -par_r;
    int32_t y = 0;
    int32_t err = 2 - 2 * par_r;
    int32_t e2;
    if (par_x >= SSD1306_WIDTH || par_y >= SSD1306_HEIGHT) {
        return;
    do {
        ssd1306_DrawPixel(par_x - x, par_y + y, par_color);
        ssd1306_DrawPixel(par_x + x, par_y + y, par_color);
        ssd1306_DrawPixel(par_x + x, par_y - y, par_color);
        ssd1306_DrawPixel(par_x - x, par_y - y, par_color);
        e2 = err;
        if (e2 <= y) {
            y++;
            err = err + (y * 2 + 1);
            if(-x == y && e2 <= x) {
                e2 = 0;
        if (e2 > x) {
            x++;
            err = err + (x * 2 + 1);
    } while (x <= 0);
    return;
/* Draw filled circle. Pixel positions calculated using Bresenham's algorithm */
void ssd1306_FillCircle(uint8_t par_x,uint8_t par_y,uint8_t par_r,SSD1306_COLOR par_color) {
    int32_t x = -par_r;
    int32_t y = 0;
    int32_t e2;
        return;
    do {
        for (uint8_t _y = (par_y + y); _y >= (par_y - y); _y--) {
            for (uint8_t _x = (par_x - x); _x >= (par_x + x); _x--) {
                ssd1306_DrawPixel(_x, _y, par_color);
        e2 = err;
        if (e2 <= y) {
            y++;
            if (-x == y && e2 <= x) {
                e2 = 0;
        if (e2 > x) {
            x++;
    } while (x <= 0);
    return;
/* Draw a rectangle */
void ssd1306_DrawRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color) {
    ssd1306_Line(x1,y1,x2,y1,color);
    ssd1306_Line(x2,y1,x2,y2,color);
    ssd1306_Line(x2,y2,x1,y2,color);
    ssd1306_Line(x1,y2,x1,y1,color);
    return;
/* Draw a filled rectangle */
void ssd1306_FillRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2, SSD1306_COLOR color) {
    uint8_t x_start = ((x1<=x2) ? x1 : x2);
    uint8_t x_end   = ((x1<=x2) ? x2 : x1);
    uint8_t y_start = ((y1<=y2) ? y1 : y2);
    uint8_t y_end   = ((y1<=y2) ? y2 : y1);
    for (uint8_t y= y_start; (y<= y_end)&&(y<SSD1306_HEIGHT); y++) {
        for (uint8_t x= x_start; (x<= x_end)&&(x<SSD1306_WIDTH); x++) {
            ssd1306_DrawPixel(x, y, color);
    return;
SSD1306_Error_t ssd1306_InvertRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2) {
  if ((x2 >= SSD1306_WIDTH) || (y2 >= SSD1306_HEIGHT)) {
    return SSD1306_ERR;
  if ((x1 > x2) || (y1 > y2)) {
    return SSD1306_ERR;
  uint32_t i;
  if ((y1 / 8) != (y2 / 8)) {
    /* if rectangle doesn't lie on one 8px row */
    for (uint32_t x = x1; x <= x2; x++) {
      i = x + (y1 / 8) * SSD1306_WIDTH;
      SSD1306_Buffer[i] ^= 0xFF << (y1 % 8);
      i += SSD1306_WIDTH;
      for (; i < x + (y2 / 8) * SSD1306_WIDTH; i += SSD1306_WIDTH) {
        SSD1306_Buffer[i] ^= 0xFF;
      SSD1306_Buffer[i] ^= 0xFF >> (7 - (y2 % 8));
  } else {
    /* if rectangle lies on one 8px row */
    const uint8_t mask = (0xFF << (y1 % 8)) & (0xFF >> (7 - (y2 % 8)));
    for (i = x1 + (y1 / 8) * SSD1306_WIDTH;
         i <= (uint32_t)x2 + (y2 / 8) * SSD1306_WIDTH; i++) {
      SSD1306_Buffer[i] ^= mask;
  return SSD1306_OK;
/* Draw a bitmap */
void ssd1306_DrawBitmap(uint8_t x, uint8_t y, const unsigned char* bitmap, uint8_t w, uint8_t h, SSD1306_COLOR color) {
    int16_t byteWidth = (w + 7) / 8; // Bitmap scanline pad = whole byte
    uint8_t byte = 0;
    if (x >= SSD1306_WIDTH || y >= SSD1306_HEIGHT) {
        return;
    for (uint8_t j = 0; j < h; j++, y++) {
        for (uint8_t i = 0; i < w; i++) {
            if (i & 7) {
                byte <<= 1;
            } else {
                byte = (*(const unsigned char *)(&bitmap[j * byteWidth + i / 8]));
            if (byte & 0x80) {
                ssd1306_DrawPixel(x + i, y, color);
    return;
void ssd1306_DrawBitmap2(uint8_t x, uint8_t y, const unsigned char* bitmap, uint8_t w, uint8_t h, SSD1306_COLOR color) {
    uint8_t byte = 0;
        return;
            if (i & 7) {
                byte <<= 1;
            } else {
            if ((byte & 0x80)==0) {
    return;
void ssd1306_SetContrast(const uint8_t value) {
    const uint8_t kSetContrastControlRegister = 0x81;
    ssd1306_WriteCommand(kSetContrastControlRegister);
    ssd1306_WriteCommand(value);
void ssd1306_SetDisplayOn(const uint8_t on) {
    uint8_t value;
    if (on) {
        value = 0xAF;   // Display on
        SSD1306.DisplayOn = 1;
    } else {
        value = 0xAE;   // Display off
        SSD1306.DisplayOn = 0;
uint8_t ssd1306_GetDisplayOn() {
    return SSD1306.DisplayOn;
	uint8_t i,m,n=0,temp,chr1;
	uint8_t x0=x,y0=y;
	uint8_t size3=size1/8;
	while(size3--)
		chr1=num*size1/8+n;
		n++;
			for(i=0;i<size1;i++)
				if(size1==16)
						{temp=Hzk1s[chr1][i];}//调用16*16字体
				else if(size1==24)
						{temp=Hzk2s[chr1][i];}//调用24*24字体
				else if(size1==32)
						{temp=Hzk3s[chr1][i];}//调用32*32字体
				else if(size1==64)
						{temp=Hzk4s[chr1][i];}//调用64*64字体
				else return;
						for(m=0;m<8;m++)
								if(temp&0x01)ssd1306_DrawPixel(x,y,White);
								else ssd1306_DrawPixel(x,y,Black);
								temp>>=1;
								y++;
							x++;
							if((x-x0)==size1)
							{x=x0;y0=y0+8;}
							y=y0;
//在指定位置显示一个字符,包括部分字符
//x:0~127
//y:0~63
//size:选择字体 12/16/24
//取模方式 逐列式
	uint8_t i,m,temp,size2,chr1;
	uint8_t y0=y;
	size2=(size1/8+((size1%8)?1:0))*(size1/2);  //得到字体一个字符对应点阵集所占的字节数
	chr1=chr-' ';  //计算偏移后的值
	for(i=0;i<size2;i++)
		if(size1==12)
        {temp=asc2_1206s[chr1][i];} //调用1206字体
		else if(size1==16)
        {temp=asc2_1608s[chr1][i];} //调用1608字体
		else if(size1==24)
        {temp=asc2_2412s[chr1][i];} //调用2412字体
		else return;
				for(m=0;m<8;m++)           //写入数据
					if(temp&0x80)ssd1306_DrawPixel(x,y,White);
					temp<<=1;
					y++;
					if((y-y0)==size1)
						y=y0;
						x++;
						break;
//显示字符串
//x,y:起点坐标
//size1:字体大小
//*chr:字符串起始地址
	while((*chr>=' ')&&(*chr<='~'))//判断是不是非法字符!
		OLED_ShowChar(x,y,*chr,size1);
		x+=size1/2;
		if(x>128-size1)  //换行
			x=0;
			y+=2;
		chr++;
uint32_t OLED_Pow(uint8_t m,uint8_t n)
	uint32_t result=1;
	while(n--)
	  result*=m;
	return result;
////显示2个数字
////x,y :起点坐标
////len :数字的位数
////size:字体大小
	uint8_t t,temp;
	for(t=0;t<len;t++)
		temp=(num/OLED_Pow(10,len-t-1))%10;
			if(temp==0)
				OLED_ShowChar(x+(size1/2)*t,y,'0',size1);
			else
			  OLED_ShowChar(x+(size1/2)*t,y,temp+'0',size1);
ssd1306_tests.h
#ifndef __SSD1306_TEST_H__
#define __SSD1306_TEST_H__
//_BEGIN_STD_C
void ssd1306_TestBorder(void);
void ssd1306_TestFonts1(void);
void ssd1306_TestFonts2(void);
void ssd1306_TestFPS(void);
void ssd1306_TestAll(void);
void ssd1306_TestLine(void);
void ssd1306_TestRectangle(void);
void ssd1306_TestRectangleFill(void);
void ssd1306_TestRectangleInvert(void);
void ssd1306_TestCircle(void);
void ssd1306_TestArc(void);
void ssd1306_TestPolyline(void);
void ssd1306_TestDrawBitmap(void);
//_END_STD_C
#endif // __SSD1306_TEST_H__
ssd1306_tests.c
#include <string.h>
#include <stdio.h>
#include "ssd1306_tests.h"
#include "ssd1306_fonts.h"
#include "main.h"
// Table generated by LCD Assistant
// http://en.radzio.dxp.pl/bitmap_converter/
const unsigned char garfield_128x64 [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xF8, 0x7F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xCF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFB, 0xE3, 0xFF, 0xF3, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0xF3, 0xFF, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x00, 0x1F, 0xD9, 0xFC, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0x00, 0x0F, 0x00, 0x1E, 0x0C, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0C, 0x0C, 0x0E, 0x1F, 0xF8, 0x03, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0x87, 0xF0, 0x07, 0x00, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x18, 0x3B, 0x80, 0x18, 0x00, 0x30, 0xC3, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x60, 0x00, 0x18, 0xC3, 0x01, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3F, 0xFC, 0x01, 0x80, 0x00, 0x0F, 0xC3, 0x8F, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xF0, 0x03, 0x00, 0x00, 0x0C, 0x07, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0F, 0xE0, 0x0C, 0x00, 0x00, 0x0C, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x38, 0xC0, 0x18, 0x00, 0x00, 0x08, 0x0F, 0xFF, 0xF0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x71, 0x80, 0x30, 0x00, 0x00, 0x08, 0x0F, 0xFC, 0xFC, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xF7, 0x00, 0x60, 0x00, 0x00, 0x18, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x60, 0x00, 0x00, 0x18, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0xC0, 0x00, 0x00, 0x30, 0xFF, 0x1F, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x83, 0xE0, 0xC0, 0x00, 0x00, 0x60, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0x03, 0x1F, 0xFF, 0xFF, 0xFF, 0xC0, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0E, 0x01, 0x00, 0xE7, 0xC0, 0x03, 0x80, 0x00, 0x0F, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0x01, 0x80, 0xE0, 0x00, 0x06, 0x00, 0x00, 0xFF, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0x83, 0x7F, 0xF0, 0x00, 0x38, 0x00, 0x26, 0xFF, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0xDC, 0x18, 0x1F, 0x87, 0xE0, 0x00, 0x26, 0xEF, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0xB8, 0x0E, 0x18, 0x00, 0x30, 0x00, 0x04, 0xCF, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0x30, 0x0F, 0xC0, 0x00, 0x18, 0x00, 0x00, 0x8F, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0x30, 0x38, 0x70, 0x00, 0x18, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0x18, 0x00, 0x1F, 0x00, 0x18, 0x3B, 0x80, 0x0E, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x8E, 0x00, 0x03, 0x80, 0x70, 0x1F, 0xF8, 0x1C, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x03, 0xE0, 0x1F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x7F, 0x86, 0x00, 0x3F, 0x1F, 0x07, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0F, 0xC3, 0x00, 0x00, 0x3F, 0x01, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x80, 0x00, 0x3F, 0xC7, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x73, 0xE0, 0x07, 0xFF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x07, 0xC0, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x3E, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0xA4, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x16, 0x01, 0xC0, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x1E, 0x01, 0xC0, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x0C, 0x01, 0x80, 0x3F, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x04, 0x01, 0xF3, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x0C, 0x01, 0xEF, 0xF7, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x00, 0x18, 0x00, 0x07, 0xF0, 0x60, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x00, 0x18, 0x00, 0x07, 0x80, 0x70, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x30, 0x00, 0x06, 0x04, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x38, 0x00, 0x00, 0x00, 0x60, 0x00, 0x0C, 0x1C, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x1F, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x01, 0x80, 0x00, 0x01, 0xFD, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0xFD, 0xF0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x07, 0x00, 0x00, 0x01, 0xC1, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x07, 0x00, 0x00, 0x03, 0x81, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0C, 0x00, 0x00, 0x07, 0x00, 0x00, 0x07, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x39, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x01, 0xF0, 0x01, 0xE3, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xE0, 0x00, 0x00, 0x1F, 0x03, 0x8D, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x00, 0x03, 0xFC, 0x3D, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x03, 0xC0, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xC0, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xF1, 0xC0, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xE0, 0xC0, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xE0, 0xC0, 0x3F, 0x9E, 0x00, 0x00, 0x00, 0x00, 0x00
const unsigned char github_logo_64x64[] = {
0x00, 0x00, 0x00, 0x1F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0x80, 0x00, 0x00,
0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0xFC, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x00,
0x00, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00,
0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x03, 0xFE, 0x3F, 0xFF, 0xFF, 0xFC, 0x7F, 0xC0,
0x07, 0xFE, 0x07, 0xFF, 0xFF, 0xE0, 0x7F, 0xE0, 0x07, 0xFE, 0x01, 0xF8, 0x1F, 0xC0, 0x3F, 0xE0,
0x0F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF0, 0x0F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF0,
0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF8, 0x1F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xF8,
0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFC, 0x3F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFC,
0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFC, 0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE,
0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFE,
0x7F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFE, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF,
0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF,
0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF,
0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF,
0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xFF, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE,
0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFE,
0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFE, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFC,
0x3F, 0xFF, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFC, 0x3F, 0xFF, 0xC0, 0x00, 0x00, 0x01, 0xFF, 0xFC,
0x1F, 0x9F, 0xE0, 0x00, 0x00, 0x07, 0xFF, 0xF8, 0x1F, 0x87, 0xFC, 0x00, 0x00, 0x3F, 0xFF, 0xF8,
0x0F, 0xC3, 0xFF, 0xC0, 0x01, 0xFF, 0xFF, 0xF0, 0x0F, 0xE1, 0xFF, 0x80, 0x01, 0xFF, 0xFF, 0xF0,
0x07, 0xF1, 0xFF, 0x80, 0x00, 0xFF, 0xFF, 0xE0, 0x07, 0xF0, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0xE0,
0x03, 0xF8, 0x3F, 0x00, 0x00, 0xFF, 0xFF, 0xC0, 0x01, 0xF8, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x80,
0x00, 0xFC, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x00,
0x00, 0x7F, 0x00, 0x00, 0x00, 0xFF, 0xFE, 0x00, 0x00, 0x3F, 0xFF, 0x00, 0x00, 0xFF, 0xFC, 0x00,
0x00, 0x0F, 0xFF, 0x00, 0x00, 0xFF, 0xF0, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0xFF, 0xE0, 0x00,
0x00, 0x03, 0xFF, 0x00, 0x00, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x00, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x3F, 0x00, 0x00, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0xF0, 0x00, 0x00,
void ssd1306_TestBorder() {
    uint8_t x = 0;
    uint8_t y = 0;
    do {
        ssd1306_DrawPixel(x, y, Black);
        if((y == 0) && (x < (SSD1306_WIDTH-1)))
            x++;
        else if((x == (SSD1306_WIDTH-1)) && (y < (SSD1306_HEIGHT-1)))
            y++;
        else if((y == (SSD1306_HEIGHT-1)) && (x > 0))
            x--;
        else
            y--;
        ssd1306_DrawPixel(x, y, White);
        delay_ms(5);
    } while(x > 0 || y > 0);
    delay_ms(1000);
void ssd1306_TestFonts1() {
    uint8_t y = 0;
    ssd1306_SetCursor(2, y);
    ssd1306_WriteString("Font 16x26", Font_16x26, White);
    y += 26;
    #endif
    ssd1306_WriteString("Font 11x18", Font_11x18, White);
    y += 18;
    #endif
    ssd1306_WriteString("Font 7x10", Font_7x10, White);
    y += 10;
    #endif
    ssd1306_WriteString("Font 6x8", Font_6x8, White);
    #endif
 * This test shows how an 128x64 px OLED can replace a 0802 LCD.
void ssd1306_TestFonts2() {
    uint8_t x1, y1, x2, y2;
    ssd1306_SetCursor(0, 4);
    ssd1306_WriteString("18.092.5", Font_16x24, White);
    ssd1306_SetCursor(0, 4+24+8);
    ssd1306_WriteString("RIT+1000", Font_16x24, White);
    // underline
    x1 = 6*16;
    y1 = 4+24+8+24;
    x2 = x1+16;
    y2 = y1+2;
    ssd1306_FillRectangle(x1, y1, x2, y2, White);
#endif
 * Test of proportional (non-monospaced) font.
void ssd1306_TestFonts3() {
    ssd1306_SetCursor(4, 4);
    ssd1306_WriteString("Proportional", Font_16x15, White);
    ssd1306_SetCursor(4, 24);
    ssd1306_WriteString("text... Sweet!", Font_16x15, White);
    ssd1306_SetCursor(4, 44);
    ssd1306_WriteString("3.1415  04:20", Font_16x15, White);
#elif defined(SSD1306_INCLUDE_FONT_11x18)
    ssd1306_WriteString("Skip test", Font_11x18, White);
    ssd1306_WriteString("Font not", Font_11x18, White);
    ssd1306_WriteString("included!", Font_11x18, White);
#endif
void ssd1306_TestFPS() {
    ssd1306_Fill(White);
    uint32_t start = HAL_GetTick();
    uint32_t end = start;
    int fps = 0;
    char message[] = "ABCDEFGHIJK";
    ssd1306_SetCursor(2,0);
    ssd1306_WriteString("Testing...", Font_11x18, Black);
    ssd1306_SetCursor(2, 18*2);
    ssd1306_WriteString("0123456789A", Font_11x18, Black);
    do {
        ssd1306_SetCursor(2, 18);
        ssd1306_WriteString(message, Font_11x18, Black);
        char ch = message[0];
        memmove(message, message+1, sizeof(message)-2);
        message[sizeof(message)-2] = ch;
        fps++;
        end = HAL_GetTick();
    } while((end - start) < 5000);
    delay_ms(5000);
    char buff[64];
    fps = (float)fps / ((end - start) / 1000.0);
    snprintf(buff, sizeof(buff), "~%d FPS", fps);
    ssd1306_SetCursor(2, 2);
    ssd1306_WriteString(buff, Font_11x18, Black);
void ssd1306_TestLine() {
  ssd1306_Line(1,1,SSD1306_WIDTH - 1,SSD1306_HEIGHT - 1,White);
  ssd1306_Line(SSD1306_WIDTH - 1,1,1,SSD1306_HEIGHT - 1,White);
  return;
void ssd1306_TestRectangle() {
  uint32_t delta;
  for(delta = 0; delta < 5; delta ++) {
    ssd1306_DrawRectangle(1 + (5*delta),1 + (5*delta) ,SSD1306_WIDTH-1 - (5*delta),SSD1306_HEIGHT-1 - (5*delta),White);
  return;
void ssd1306_TestRectangleFill() {
  ssd1306_FillRectangle(31, 1, 65, 35, White);
  ssd1306_FillRectangle(10, 45, 70, 60, White);
  ssd1306_FillRectangle(75, 10, 100, 45, White);
  ssd1306_FillRectangle(55, 30, 80, 55, Black);
void ssd1306_TestRectangleInvert() {
  ssd1306_SetCursor(2, 0);
  ssd1306_WriteString("Black", Font_11x18, White);
  ssd1306_SetCursor(2, 20);
  ssd1306_WriteString("on", Font_11x18, White);
  ssd1306_SetCursor(2, 40);
  ssd1306_WriteString("White", Font_11x18, White);
  ssd1306_SetCursor(66, 0);
  ssd1306_SetCursor(66, 20);
  ssd1306_SetCursor(66, 40);
#else
  ssd1306_FillCircle(32, 32, 20, White);
  ssd1306_FillCircle(96, 32, 20, White);
#endif
  ssd1306_InvertRectangle(0,0,63,63);
  /* Test rectangle lies on one 8px page */
  ssd1306_InvertRectangle(2,58,125,60);
void ssd1306_TestCircle() {
  uint32_t delta;
    ssd1306_DrawCircle(20*delta+30, 15, 10, White);
    ssd1306_FillCircle(23*delta+15, 40, 10, White);
  return;
void ssd1306_TestArc() {
  ssd1306_DrawArc(30, 30, 30, 20, 270, White);
  ssd1306_DrawArcWithRadiusLine(80, 55, 10, 30, 270, White);
  return;
void ssd1306_TestPolyline() {
  SSD1306_VERTEX loc_vertex[] =
      {35,40},
      {40,20},
      {45,28},
      {50,10},
      {45,16},
      {50,10},
      {53,16}
  ssd1306_Polyline(loc_vertex,sizeof(loc_vertex)/sizeof(loc_vertex[0]),White);
  return;
void ssd1306_TestDrawBitmap()
    ssd1306_DrawBitmap(0,0,garfield_128x64,128,64,Black);
    delay_ms(3000);
    ssd1306_DrawBitmap(32,0,github_logo_64x64,64,64,White);
    delay_ms(3000);
    ssd1306_DrawBitmap(32,0,github_logo_64x64,64,64,Black);
void ssd1306_TestAll() {
    ssd1306_Init();
    ssd1306_TestFPS();
    delay_ms(3000);
    ssd1306_TestBorder();
    ssd1306_TestFonts1();
    delay_ms(3000);
    ssd1306_TestFonts2();
    delay_ms(3000);
    ssd1306_TestFonts3();
    delay_ms(3000);
    ssd1306_TestRectangle();
    ssd1306_TestLine();
    delay_ms(3000);
    ssd1306_TestRectangleFill();
    delay_ms(3000);
    ssd1306_TestRectangleInvert();
    delay_ms(3000);
    ssd1306_TestPolyline();
    delay_ms(3000);
    ssd1306_TestArc();
    delay_ms(3000);
    ssd1306_TestCircle();
    delay_ms(3000);
    ssd1306_TestDrawBitmap();
    delay_ms(3000);
ssd1306_fonts.c
const uint8_t image_a[]= { // 54x54 BW pixels.
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff,
    0xff, 0xfc, 0xff, 0xff, 0xf8, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0x80,
    0x00, 0x07, 0xff, 0xfc, 0xff, 0xfe, 0x00, 0x00, 0x01, 0xff, 0xfc, 0xff,
    0xfc, 0x00, 0x00, 0x00, 0xff, 0xfc, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x3f,
    0xfc, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x1f, 0xfc, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x07, 0xfc, 0xff, 0x80, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xfe, 0x00,
    0x00, 0x00, 0x00, 0x03, 0xfc, 0xfe, 0x00, 0x00, 0x00, 0x60, 0x01, 0xfc,
    0xfc, 0x00, 0x00, 0x00, 0xf0, 0x00, 0xfc, 0xf8, 0x00, 0x00, 0x01, 0xf0,
    0x00, 0x7c, 0xf8, 0x00, 0x00, 0x03, 0xe0, 0x00, 0x7c, 0xf0, 0x00, 0x00,
    0x07, 0xc0, 0x00, 0x3c, 0xf0, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x3c, 0xe0,
    0x00, 0x00, 0x1f, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x00, 0x3e, 0x00, 0x00,
    0x1c, 0xe0, 0x00, 0x00, 0x7c, 0x00, 0x00, 0x1c, 0xc0, 0x00, 0x00, 0xf8,
    0x00, 0x00, 0x0c, 0xc0, 0x00, 0x01, 0xf0, 0x00, 0x00, 0x0c, 0xc0, 0x00,
    0x03, 0xe0, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x0c,
    0xc0, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x1f, 0x00, 0x00,
    0x00, 0x04, 0xc0, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x3e,
    0x00, 0x00, 0x00, 0x04, 0xc0, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x0c, 0xc0,
    0x00, 0x0f, 0x80, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x07, 0xc0, 0x00, 0x00,
    0x0c, 0xc0, 0x00, 0x03, 0xe0, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x01, 0xf0,
    0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0xf8, 0x00, 0x00, 0x0c, 0xe0, 0x00,
    0x00, 0x7c, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x1c,
    0xe0, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x1c, 0xf0, 0x00, 0x00, 0x0f, 0x80,
    0x00, 0x3c, 0xf0, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x3c, 0xf8, 0x00, 0x00,
    0x03, 0xe0, 0x00, 0x7c, 0xfc, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x7c, 0xfc,
    0x00, 0x00, 0x00, 0xf0, 0x00, 0xfc, 0xfe, 0x00, 0x00, 0x00, 0x60, 0x01,
    0xfc, 0xff, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x03, 0xfc, 0xff, 0x80, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0xff, 0xe0,
    0x00, 0x00, 0x00, 0x1f, 0xfc, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x3f, 0xfc,
    0xff, 0xf8, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0xff, 0xfe, 0x00, 0x00, 0x01,
    0xff, 0xfc, 0xff, 0xff, 0x80, 0x00, 0x07, 0xff, 0xfc, 0xff, 0xff, 0xf0,
    0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xdf, 0xff, 0xff, 0xfc, 0xff,
const uint8_t image_b[]= { // 54x54 BW pixels.
    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xaf, 0xff,
    0xff, 0xfc, 0xff, 0xff, 0xf0, 0x00, 0x3f, 0xff, 0xfc, 0xff, 0xff, 0x80,
    0xf8, 0x00, 0x00, 0x00, 0x7f, 0xfc, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x3f,
    0xfc, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x1f, 0xfc, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x07, 0xfc, 0xff, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xfe, 0x00,
    0x00, 0x00, 0x00, 0x03, 0xfc, 0xfe, 0x00, 0x18, 0x00, 0x00, 0x01, 0xfc,
    0xfc, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xfc, 0xf8, 0x00, 0x3e, 0x00, 0x00,
    0x00, 0x7c, 0xf8, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x7c, 0xf0, 0x00, 0x0f,
    0x80, 0x00, 0x00, 0x3c, 0xf0, 0x00, 0x07, 0xc0, 0x00, 0x00, 0x3c, 0xe0,
    0x00, 0x03, 0xe0, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x01, 0xf0, 0x00, 0x00,
    0x1c, 0xc0, 0x00, 0x00, 0xf8, 0x00, 0x00, 0x1c, 0xc0, 0x00, 0x00, 0x7c,
    0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x0c, 0xc0, 0x00,
    0x00, 0x1f, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x0c,
    0xc0, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x0c, 0x80, 0x00, 0x00, 0x03, 0xe0,
    0x00, 0x0c, 0xc0, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x0c, 0xc0, 0x00, 0x00,
    0x01, 0xf0, 0x00, 0x0c, 0x80, 0x00, 0x00, 0x03, 0xe0, 0x00, 0x0c, 0xc0,
    0x00, 0x00, 0x07, 0xc0, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x0f, 0x80, 0x00,
    0x0c, 0xc0, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x3e,
    0x00, 0x00, 0x0c, 0xc0, 0x00, 0x00, 0x7c, 0x00, 0x00, 0x1c, 0xe0, 0x00,
    0x00, 0xf8, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x01, 0xf0, 0x00, 0x00, 0x1c,
    0xe0, 0x00, 0x03, 0xe0, 0x00, 0x00, 0x3c, 0xf0, 0x00, 0x07, 0xc0, 0x00,
    0x00, 0x3c, 0xf0, 0x00, 0x0f, 0x80, 0x00, 0x00, 0x3c, 0xf8, 0x00, 0x1f,
    0x00, 0x00, 0x00, 0x7c, 0xfc, 0x00, 0x3e, 0x00, 0x00, 0x00, 0xfc, 0xfc,
    0x00, 0x3c, 0x00, 0x00, 0x00, 0xfc, 0xfe, 0x00, 0x18, 0x00, 0x00, 0x01,
    0x00, 0x07, 0xfc, 0xff, 0x80, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0xff, 0xe0,
    0xff, 0xfc, 0x00, 0x00, 0x00, 0xff, 0xfc, 0xff, 0xfe, 0x00, 0x00, 0x03,
    0xff, 0xfc, 0xff, 0xff, 0xc0, 0x00, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xf8,
    0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xff,
const uint8_t image_c[]= {
    0xff, 0xfc, 0xff, 0xff, 0xf0, 0x00, 0x7f, 0xff, 0xfc, 0xff, 0xff, 0x80,
    0xf8, 0x00, 0x00, 0x00, 0xff, 0xfc, 0xff, 0xf0, 0x00, 0x00, 0x00, 0x3f,
    0x00, 0x0f, 0xfc, 0xff, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xff, 0x00,
    0x00, 0x00, 0x00, 0x03, 0xfc, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01, 0xfc,
    0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xf8, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x7c, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7c, 0xf0, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x3c, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xe0,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xe0, 0x00, 0x00, 0x30, 0x00, 0x00,
    0x1c, 0xe0, 0x00, 0x00, 0x78, 0x00, 0x00, 0x1c, 0xc0, 0x00, 0x00, 0xfc,
    0x00, 0x00, 0x1c, 0xc0, 0x00, 0x01, 0xfe, 0x00, 0x00, 0x0c, 0xc0, 0x00,
    0x03, 0xff, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x07, 0xcf, 0x80, 0x00, 0x0c,
    0xc0, 0x00, 0x0f, 0x87, 0xc0, 0x00, 0x0c, 0x80, 0x00, 0x1f, 0x03, 0xe0,
    0x00, 0x0c, 0x80, 0x00, 0x3e, 0x01, 0xf0, 0x00, 0x0c, 0xc0, 0x00, 0x7c,
    0x00, 0xf8, 0x00, 0x0c, 0xc0, 0x00, 0xf8, 0x00, 0x7c, 0x00, 0x0c, 0x80,
    0x01, 0xf0, 0x00, 0x3e, 0x00, 0x0c, 0xc0, 0x03, 0xe0, 0x00, 0x1f, 0x00,
    0x0c, 0xc0, 0x07, 0xc0, 0x00, 0x0f, 0x80, 0x0c, 0xc0, 0x0f, 0x80, 0x00,
    0x07, 0xc0, 0x0c, 0xc0, 0x1f, 0x00, 0x00, 0x03, 0xe0, 0x1c, 0xe0, 0x1e,
    0x00, 0x00, 0x01, 0xe0, 0x1c, 0xe0, 0x0c, 0x00, 0x00, 0x00, 0xc0, 0x1c,
    0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xf0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x3c, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3c, 0xf8, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x7c, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xfc,
    0x00, 0x00, 0x00, 0x00, 0x00, 0xfc, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x01,
    0xfc, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xff, 0x80, 0x00, 0x00,
    0xff, 0xf8, 0x00, 0x00, 0x00, 0xff, 0xfc, 0xff, 0xfe, 0x00, 0x00, 0x01,
    0xff, 0xfc, 0xff, 0xff, 0x80, 0x00, 0x0f, 0xff, 0xfc, 0xff, 0xff, 0xf0,
const uint8_t image_d[]= {
	    0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0xff, 0xff, 0xff, 0xdf, 0xff,
    0xfc, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0xff, 0x80, 0x00, 0x00,
    0x00, 0x07, 0xfc, 0xff, 0x00, 0x00, 0x00, 0x00, 0x03, 0xfc, 0xff, 0x00,
    0x00, 0x00, 0x00, 0x3c, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0xe0,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0xe0, 0x0c, 0x00, 0x00, 0x00, 0xc0,
    0x1c, 0xe0, 0x1e, 0x00, 0x00, 0x01, 0xe0, 0x1c, 0xc0, 0x1f, 0x00, 0x00,
    0x03, 0xe0, 0x0c, 0xc0, 0x0f, 0x80, 0x00, 0x07, 0xc0, 0x0c, 0xc0, 0x07,
    0xc0, 0x00, 0x0f, 0x80, 0x0c, 0xc0, 0x03, 0xe0, 0x00, 0x1f, 0x00, 0x0c,
    0xc0, 0x01, 0xf0, 0x00, 0x3e, 0x00, 0x0c, 0xc0, 0x00, 0xf8, 0x00, 0x7c,
    0x00, 0x04, 0xc0, 0x00, 0x7c, 0x00, 0xf8, 0x00, 0x04, 0xc0, 0x00, 0x3e,
    0x01, 0xf0, 0x00, 0x0c, 0xc0, 0x00, 0x1f, 0x03, 0xe0, 0x00, 0x0c, 0xc0,
    0x00, 0x0f, 0x87, 0xc0, 0x00, 0x04, 0xc0, 0x00, 0x07, 0xcf, 0x80, 0x00,
    0x0c, 0xc0, 0x00, 0x03, 0xff, 0x00, 0x00, 0x0c, 0xc0, 0x00, 0x01, 0xfe,
    0x00, 0x00, 0x0c, 0xe0, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x0c, 0xe0, 0x00,
    0x00, 0x78, 0x00, 0x00, 0x1c, 0xe0, 0x00, 0x00, 0x30, 0x00, 0x00, 0x1c,
    0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0xf0, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x7c, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7c, 0xfc,
    0x00, 0x07, 0xfc, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x0f, 0xfc, 0xff, 0xe0,
    0xff, 0xfc, 0x00, 0x00, 0x00, 0xff, 0xfc, 0xff, 0xff, 0x00, 0x00, 0x01,
static const uint16_t Font7x10 [] = {
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // sp
0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x1000, 0x0000, 0x0000,  // !
0x2800, 0x2800, 0x2800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // "
0x2400, 0x2400, 0x7C00, 0x2400, 0x4800, 0x7C00, 0x4800, 0x4800, 0x0000, 0x0000,  // #
0x3800, 0x5400, 0x5000, 0x3800, 0x1400, 0x5400, 0x5400, 0x3800, 0x1000, 0x0000,  // $
0x2000, 0x5400, 0x5800, 0x3000, 0x2800, 0x5400, 0x1400, 0x0800, 0x0000, 0x0000,  // %
0x1000, 0x2800, 0x2800, 0x1000, 0x3400, 0x4800, 0x4800, 0x3400, 0x0000, 0x0000,  // &
0x1000, 0x1000, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // '
0x0800, 0x1000, 0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x1000, 0x0800,  // (
0x2000, 0x1000, 0x0800, 0x0800, 0x0800, 0x0800, 0x0800, 0x0800, 0x1000, 0x2000,  // )
0x1000, 0x3800, 0x1000, 0x2800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // *
0x0000, 0x0000, 0x1000, 0x1000, 0x7C00, 0x1000, 0x1000, 0x0000, 0x0000, 0x0000,  // +
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1000, 0x1000, 0x1000,  // ,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3800, 0x0000, 0x0000, 0x0000, 0x0000,  // -
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1000, 0x0000, 0x0000,  // .
0x0800, 0x0800, 0x1000, 0x1000, 0x1000, 0x1000, 0x2000, 0x2000, 0x0000, 0x0000,  // /
0x3800, 0x4400, 0x4400, 0x5400, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // 0
0x1000, 0x3000, 0x5000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // 1
0x3800, 0x4400, 0x4400, 0x0400, 0x0800, 0x1000, 0x2000, 0x7C00, 0x0000, 0x0000,  // 2
0x3800, 0x4400, 0x0400, 0x1800, 0x0400, 0x0400, 0x4400, 0x3800, 0x0000, 0x0000,  // 3
0x0800, 0x1800, 0x2800, 0x2800, 0x4800, 0x7C00, 0x0800, 0x0800, 0x0000, 0x0000,  // 4
0x7C00, 0x4000, 0x4000, 0x7800, 0x0400, 0x0400, 0x4400, 0x3800, 0x0000, 0x0000,  // 5
0x3800, 0x4400, 0x4000, 0x7800, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // 6
0x7C00, 0x0400, 0x0800, 0x1000, 0x1000, 0x2000, 0x2000, 0x2000, 0x0000, 0x0000,  // 7
0x3800, 0x4400, 0x4400, 0x3800, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // 8
0x3800, 0x4400, 0x4400, 0x4400, 0x3C00, 0x0400, 0x4400, 0x3800, 0x0000, 0x0000,  // 9
0x0000, 0x0000, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1000, 0x0000, 0x0000,  // :
0x0000, 0x0000, 0x0000, 0x1000, 0x0000, 0x0000, 0x0000, 0x1000, 0x1000, 0x1000,  // ;
0x0000, 0x0000, 0x0C00, 0x3000, 0x4000, 0x3000, 0x0C00, 0x0000, 0x0000, 0x0000,  // <
0x0000, 0x0000, 0x0000, 0x7C00, 0x0000, 0x7C00, 0x0000, 0x0000, 0x0000, 0x0000,  // =
0x0000, 0x0000, 0x6000, 0x1800, 0x0400, 0x1800, 0x6000, 0x0000, 0x0000, 0x0000,  // >
0x3800, 0x4400, 0x0400, 0x0800, 0x1000, 0x1000, 0x0000, 0x1000, 0x0000, 0x0000,  // ?
0x3800, 0x4400, 0x4C00, 0x5400, 0x5C00, 0x4000, 0x4000, 0x3800, 0x0000, 0x0000,  // @
0x1000, 0x2800, 0x2800, 0x2800, 0x2800, 0x7C00, 0x4400, 0x4400, 0x0000, 0x0000,  // A
0x7800, 0x4400, 0x4400, 0x7800, 0x4400, 0x4400, 0x4400, 0x7800, 0x0000, 0x0000,  // B
0x3800, 0x4400, 0x4000, 0x4000, 0x4000, 0x4000, 0x4400, 0x3800, 0x0000, 0x0000,  // C
0x7000, 0x4800, 0x4400, 0x4400, 0x4400, 0x4400, 0x4800, 0x7000, 0x0000, 0x0000,  // D
0x7C00, 0x4000, 0x4000, 0x7C00, 0x4000, 0x4000, 0x4000, 0x7C00, 0x0000, 0x0000,  // E
0x7C00, 0x4000, 0x4000, 0x7800, 0x4000, 0x4000, 0x4000, 0x4000, 0x0000, 0x0000,  // F
0x3800, 0x4400, 0x4000, 0x4000, 0x5C00, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // G
0x4400, 0x4400, 0x4400, 0x7C00, 0x4400, 0x4400, 0x4400, 0x4400, 0x0000, 0x0000,  // H
0x3800, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x3800, 0x0000, 0x0000,  // I
0x0400, 0x0400, 0x0400, 0x0400, 0x0400, 0x0400, 0x4400, 0x3800, 0x0000, 0x0000,  // J
0x4400, 0x4800, 0x5000, 0x6000, 0x5000, 0x4800, 0x4800, 0x4400, 0x0000, 0x0000,  // K
0x4000, 0x4000, 0x4000, 0x4000, 0x4000, 0x4000, 0x4000, 0x7C00, 0x0000, 0x0000,  // L
0x4400, 0x6C00, 0x6C00, 0x5400, 0x4400, 0x4400, 0x4400, 0x4400, 0x0000, 0x0000,  // M
0x4400, 0x6400, 0x6400, 0x5400, 0x5400, 0x4C00, 0x4C00, 0x4400, 0x0000, 0x0000,  // N
0x3800, 0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // O
0x7800, 0x4400, 0x4400, 0x4400, 0x7800, 0x4000, 0x4000, 0x4000, 0x0000, 0x0000,  // P
0x3800, 0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x5400, 0x3800, 0x0400, 0x0000,  // Q
0x7800, 0x4400, 0x4400, 0x4400, 0x7800, 0x4800, 0x4800, 0x4400, 0x0000, 0x0000,  // R
0x3800, 0x4400, 0x4000, 0x3000, 0x0800, 0x0400, 0x4400, 0x3800, 0x0000, 0x0000,  // S
0x7C00, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // T
0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // U
0x4400, 0x4400, 0x4400, 0x2800, 0x2800, 0x2800, 0x1000, 0x1000, 0x0000, 0x0000,  // V
0x4400, 0x4400, 0x5400, 0x5400, 0x5400, 0x6C00, 0x2800, 0x2800, 0x0000, 0x0000,  // W
0x4400, 0x2800, 0x2800, 0x1000, 0x1000, 0x2800, 0x2800, 0x4400, 0x0000, 0x0000,  // X
0x4400, 0x4400, 0x2800, 0x2800, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // Y
0x7C00, 0x0400, 0x0800, 0x1000, 0x1000, 0x2000, 0x4000, 0x7C00, 0x0000, 0x0000,  // Z
0x1800, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1800,  // [
0x2000, 0x2000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0800, 0x0800, 0x0000, 0x0000,  /* \ */
0x3000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x3000,  // ]
0x1000, 0x2800, 0x2800, 0x4400, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // ^
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE00,  // _
0x2000, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // `
0x0000, 0x0000, 0x3800, 0x4400, 0x3C00, 0x4400, 0x4C00, 0x3400, 0x0000, 0x0000,  // a
0x4000, 0x4000, 0x5800, 0x6400, 0x4400, 0x4400, 0x6400, 0x5800, 0x0000, 0x0000,  // b
0x0000, 0x0000, 0x3800, 0x4400, 0x4000, 0x4000, 0x4400, 0x3800, 0x0000, 0x0000,  // c
0x0400, 0x0400, 0x3400, 0x4C00, 0x4400, 0x4400, 0x4C00, 0x3400, 0x0000, 0x0000,  // d
0x0000, 0x0000, 0x3800, 0x4400, 0x7C00, 0x4000, 0x4400, 0x3800, 0x0000, 0x0000,  // e
0x0C00, 0x1000, 0x7C00, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // f
0x0000, 0x0000, 0x3400, 0x4C00, 0x4400, 0x4400, 0x4C00, 0x3400, 0x0400, 0x7800,  // g
0x4000, 0x4000, 0x5800, 0x6400, 0x4400, 0x4400, 0x4400, 0x4400, 0x0000, 0x0000,  // h
0x1000, 0x0000, 0x7000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // i
0x1000, 0x0000, 0x7000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0xE000,  // j
0x4000, 0x4000, 0x4800, 0x5000, 0x6000, 0x5000, 0x4800, 0x4400, 0x0000, 0x0000,  // k
0x7000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x0000, 0x0000,  // l
0x0000, 0x0000, 0x7800, 0x5400, 0x5400, 0x5400, 0x5400, 0x5400, 0x0000, 0x0000,  // m
0x0000, 0x0000, 0x5800, 0x6400, 0x4400, 0x4400, 0x4400, 0x4400, 0x0000, 0x0000,  // n
0x0000, 0x0000, 0x3800, 0x4400, 0x4400, 0x4400, 0x4400, 0x3800, 0x0000, 0x0000,  // o
0x0000, 0x0000, 0x5800, 0x6400, 0x4400, 0x4400, 0x6400, 0x5800, 0x4000, 0x4000,  // p
0x0000, 0x0000, 0x3400, 0x4C00, 0x4400, 0x4400, 0x4C00, 0x3400, 0x0400, 0x0400,  // q
0x0000, 0x0000, 0x5800, 0x6400, 0x4000, 0x4000, 0x4000, 0x4000, 0x0000, 0x0000,  // r
0x0000, 0x0000, 0x3800, 0x4400, 0x3000, 0x0800, 0x4400, 0x3800, 0x0000, 0x0000,  // s
0x2000, 0x2000, 0x7800, 0x2000, 0x2000, 0x2000, 0x2000, 0x1800, 0x0000, 0x0000,  // t
0x0000, 0x0000, 0x4400, 0x4400, 0x4400, 0x4400, 0x4C00, 0x3400, 0x0000, 0x0000,  // u
0x0000, 0x0000, 0x4400, 0x4400, 0x2800, 0x2800, 0x2800, 0x1000, 0x0000, 0x0000,  // v
0x0000, 0x0000, 0x5400, 0x5400, 0x5400, 0x6C00, 0x2800, 0x2800, 0x0000, 0x0000,  // w
0x0000, 0x0000, 0x4400, 0x2800, 0x1000, 0x1000, 0x2800, 0x4400, 0x0000, 0x0000,  // x
0x0000, 0x0000, 0x4400, 0x4400, 0x2800, 0x2800, 0x1000, 0x1000, 0x1000, 0x6000,  // y
0x0000, 0x0000, 0x7C00, 0x0800, 0x1000, 0x2000, 0x4000, 0x7C00, 0x0000, 0x0000,  // z
0x1800, 0x1000, 0x1000, 0x1000, 0x2000, 0x2000, 0x1000, 0x1000, 0x1000, 0x1800,  // {
0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000, 0x1000,  // |
0x3000, 0x1000, 0x1000, 0x1000, 0x0800, 0x0800, 0x1000, 0x1000, 0x1000, 0x3000,  // }
0x0000, 0x0000, 0x0000, 0x7400, 0x4C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // ~
#endif
static const uint16_t Font11x18 [] = {
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // sp
0x0000, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // !
0x0000, 0x1B00, 0x1B00, 0x1B00, 0x1B00, 0x1B00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // "
0x0000, 0x1980, 0x1980, 0x1980, 0x1980, 0x7FC0, 0x7FC0, 0x1980, 0x3300, 0x7FC0, 0x7FC0, 0x3300, 0x3300, 0x3300, 0x3300, 0x0000, 0x0000, 0x0000,   // #
0x0000, 0x1E00, 0x3F00, 0x7580, 0x6580, 0x7400, 0x3C00, 0x1E00, 0x0700, 0x0580, 0x6580, 0x6580, 0x7580, 0x3F00, 0x1E00, 0x0400, 0x0400, 0x0000,   // $
0x0000, 0x7000, 0xD800, 0xD840, 0xD8C0, 0xD980, 0x7300, 0x0600, 0x0C00, 0x1B80, 0x36C0, 0x66C0, 0x46C0, 0x06C0, 0x0380, 0x0000, 0x0000, 0x0000,   // %
0x0000, 0x1E00, 0x3F00, 0x3300, 0x3300, 0x3300, 0x1E00, 0x0C00, 0x3CC0, 0x66C0, 0x6380, 0x6180, 0x6380, 0x3EC0, 0x1C80, 0x0000, 0x0000, 0x0000,   // &
0x0000, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // '
0x0080, 0x0100, 0x0300, 0x0600, 0x0600, 0x0400, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0400, 0x0600, 0x0600, 0x0300, 0x0100, 0x0080,   // (
0x2000, 0x1000, 0x1800, 0x0C00, 0x0C00, 0x0400, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0400, 0x0C00, 0x0C00, 0x1800, 0x1000, 0x2000,   // )
0x0000, 0x0C00, 0x2D00, 0x3F00, 0x1E00, 0x3300, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // *
0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0xFFC0, 0xFFC0, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // +
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0400, 0x0400, 0x0800,   // ,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1E00, 0x1E00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // -
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // .
0x0000, 0x0300, 0x0300, 0x0300, 0x0600, 0x0600, 0x0600, 0x0600, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x1800, 0x1800, 0x1800, 0x0000, 0x0000, 0x0000,   // /
0x0000, 0x1E00, 0x3F00, 0x3300, 0x6180, 0x6180, 0x6180, 0x6D80, 0x6D80, 0x6180, 0x6180, 0x6180, 0x3300, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 0
0x0000, 0x0600, 0x0E00, 0x1E00, 0x3600, 0x2600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0000, 0x0000, 0x0000,   // 1
0x0000, 0x1E00, 0x3F00, 0x7380, 0x6180, 0x6180, 0x0180, 0x0300, 0x0600, 0x0C00, 0x1800, 0x3000, 0x6000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x0000,   // 2
0x0000, 0x1C00, 0x3E00, 0x6300, 0x6300, 0x0300, 0x0E00, 0x0E00, 0x0300, 0x0180, 0x0180, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 3
0x0000, 0x0600, 0x0E00, 0x0E00, 0x1E00, 0x1E00, 0x1600, 0x3600, 0x3600, 0x6600, 0x7F80, 0x7F80, 0x0600, 0x0600, 0x0600, 0x0000, 0x0000, 0x0000,   // 4
0x0000, 0x7F00, 0x7F00, 0x6000, 0x6000, 0x6000, 0x6E00, 0x7F00, 0x6380, 0x0180, 0x0180, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 5
0x0000, 0x1E00, 0x3F00, 0x3380, 0x6180, 0x6000, 0x6E00, 0x7F00, 0x7380, 0x6180, 0x6180, 0x6180, 0x3380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 6
0x0000, 0x7F80, 0x7F80, 0x0180, 0x0300, 0x0300, 0x0600, 0x0600, 0x0C00, 0x0C00, 0x0C00, 0x0800, 0x1800, 0x1800, 0x1800, 0x0000, 0x0000, 0x0000,   // 7
0x0000, 0x1E00, 0x3F00, 0x6380, 0x6180, 0x6180, 0x2100, 0x1E00, 0x3F00, 0x6180, 0x6180, 0x6180, 0x6180, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 8
0x0000, 0x1E00, 0x3F00, 0x7300, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F80, 0x1D80, 0x0180, 0x6180, 0x7300, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // 9
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // :
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0C00, 0x0C00, 0x0400, 0x0400, 0x0800,   // ;
0x0000, 0x0000, 0x0000, 0x0000, 0x0080, 0x0380, 0x0E00, 0x3800, 0x6000, 0x3800, 0x0E00, 0x0380, 0x0080, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // <
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // =
0x0000, 0x0000, 0x0000, 0x0000, 0x4000, 0x7000, 0x1C00, 0x0700, 0x0180, 0x0700, 0x1C00, 0x7000, 0x4000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // >
0x0000, 0x1F00, 0x3F80, 0x71C0, 0x60C0, 0x00C0, 0x01C0, 0x0380, 0x0700, 0x0E00, 0x0C00, 0x0C00, 0x0000, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // ?
0x0000, 0x1E00, 0x3F00, 0x3180, 0x7180, 0x6380, 0x6F80, 0x6D80, 0x6D80, 0x6F80, 0x6780, 0x6000, 0x3200, 0x3E00, 0x1C00, 0x0000, 0x0000, 0x0000,   // @
0x0000, 0x0E00, 0x0E00, 0x1B00, 0x1B00, 0x1B00, 0x1B00, 0x3180, 0x3180, 0x3F80, 0x3F80, 0x3180, 0x60C0, 0x60C0, 0x60C0, 0x0000, 0x0000, 0x0000,   // A
0x0000, 0x7C00, 0x7E00, 0x6300, 0x6300, 0x6300, 0x6300, 0x7E00, 0x7E00, 0x6300, 0x6180, 0x6180, 0x6380, 0x7F00, 0x7E00, 0x0000, 0x0000, 0x0000,   // B
0x0000, 0x1E00, 0x3F00, 0x3180, 0x6180, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6180, 0x3180, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // C
0x0000, 0x7C00, 0x7F00, 0x6300, 0x6380, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6300, 0x6300, 0x7E00, 0x7C00, 0x0000, 0x0000, 0x0000,   // D
0x0000, 0x7F80, 0x7F80, 0x6000, 0x6000, 0x6000, 0x6000, 0x7F00, 0x7F00, 0x6000, 0x6000, 0x6000, 0x6000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x0000,   // E
0x0000, 0x7F80, 0x7F80, 0x6000, 0x6000, 0x6000, 0x6000, 0x7F00, 0x7F00, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x0000, 0x0000, 0x0000,   // F
0x0000, 0x1E00, 0x3F00, 0x3180, 0x6180, 0x6000, 0x6000, 0x6000, 0x6380, 0x6380, 0x6180, 0x6180, 0x3180, 0x3F80, 0x1E00, 0x0000, 0x0000, 0x0000,   // G
0x0000, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x7F80, 0x7F80, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x0000, 0x0000, 0x0000,   // H
0x0000, 0x3F00, 0x3F00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x3F00, 0x3F00, 0x0000, 0x0000, 0x0000,   // I
0x0000, 0x0180, 0x0180, 0x0180, 0x0180, 0x0180, 0x0180, 0x0180, 0x0180, 0x0180, 0x6180, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // J
0x0000, 0x60C0, 0x6180, 0x6300, 0x6600, 0x6600, 0x6C00, 0x7800, 0x7C00, 0x6600, 0x6600, 0x6300, 0x6180, 0x6180, 0x60C0, 0x0000, 0x0000, 0x0000,   // K
0x0000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x0000,   // L
0x0000, 0x71C0, 0x71C0, 0x7BC0, 0x7AC0, 0x6AC0, 0x6AC0, 0x6EC0, 0x64C0, 0x60C0, 0x60C0, 0x60C0, 0x60C0, 0x60C0, 0x60C0, 0x0000, 0x0000, 0x0000,   // M
0x0000, 0x7180, 0x7180, 0x7980, 0x7980, 0x7980, 0x6D80, 0x6D80, 0x6D80, 0x6580, 0x6780, 0x6780, 0x6780, 0x6380, 0x6380, 0x0000, 0x0000, 0x0000,   // N
0x0000, 0x1E00, 0x3F00, 0x3300, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x3300, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // O
0x0000, 0x7E00, 0x7F00, 0x6380, 0x6180, 0x6180, 0x6180, 0x6380, 0x7F00, 0x7E00, 0x6000, 0x6000, 0x6000, 0x6000, 0x6000, 0x0000, 0x0000, 0x0000,   // P
0x0000, 0x1E00, 0x3F00, 0x3300, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6580, 0x6780, 0x3300, 0x3F80, 0x1E40, 0x0000, 0x0000, 0x0000,   // Q
0x0000, 0x7E00, 0x7F00, 0x6380, 0x6180, 0x6180, 0x6380, 0x7F00, 0x7E00, 0x6600, 0x6300, 0x6300, 0x6180, 0x6180, 0x60C0, 0x0000, 0x0000, 0x0000,   // R
0x0000, 0x0E00, 0x1F00, 0x3180, 0x3180, 0x3000, 0x3800, 0x1E00, 0x0700, 0x0380, 0x6180, 0x6180, 0x3180, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // S
0x0000, 0xFFC0, 0xFFC0, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // T
0x0000, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // U
0x0000, 0x60C0, 0x60C0, 0x60C0, 0x3180, 0x3180, 0x3180, 0x1B00, 0x1B00, 0x1B00, 0x1B00, 0x0E00, 0x0E00, 0x0E00, 0x0400, 0x0000, 0x0000, 0x0000,   // V
0x0000, 0xC0C0, 0xC0C0, 0xC0C0, 0xC0C0, 0xC0C0, 0xCCC0, 0x4C80, 0x4C80, 0x5E80, 0x5280, 0x5280, 0x7380, 0x6180, 0x6180, 0x0000, 0x0000, 0x0000,   // W
0x0000, 0xC0C0, 0x6080, 0x6180, 0x3300, 0x3B00, 0x1E00, 0x0C00, 0x0C00, 0x1E00, 0x1F00, 0x3B00, 0x7180, 0x6180, 0xC0C0, 0x0000, 0x0000, 0x0000,   // X
0x0000, 0xC0C0, 0x6180, 0x6180, 0x3300, 0x3300, 0x1E00, 0x1E00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // Y
0x0000, 0x3F80, 0x3F80, 0x0180, 0x0300, 0x0300, 0x0600, 0x0C00, 0x0C00, 0x1800, 0x1800, 0x3000, 0x6000, 0x7F80, 0x7F80, 0x0000, 0x0000, 0x0000,   // Z
0x0F00, 0x0F00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0F00, 0x0F00,   // [
0x0000, 0x1800, 0x1800, 0x1800, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0300, 0x0300, 0x0300, 0x0000, 0x0000, 0x0000,   /* \ */
0x1E00, 0x1E00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x1E00, 0x1E00,   // ]
0x0000, 0x0C00, 0x0C00, 0x1E00, 0x1200, 0x3300, 0x3300, 0x6180, 0x6180, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // ^
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFE0, 0x0000,   // _
0x0000, 0x3800, 0x1800, 0x0C00, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // `
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1F00, 0x3F80, 0x6180, 0x0180, 0x1F80, 0x3F80, 0x6180, 0x6380, 0x7F80, 0x38C0, 0x0000, 0x0000, 0x0000,   // a
0x0000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6E00, 0x7F00, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x7F00, 0x6E00, 0x0000, 0x0000, 0x0000,   // b
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1E00, 0x3F00, 0x7380, 0x6180, 0x6000, 0x6000, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // c
0x0000, 0x0180, 0x0180, 0x0180, 0x0180, 0x1D80, 0x3F80, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F80, 0x1D80, 0x0000, 0x0000, 0x0000,   // d
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1E00, 0x3F00, 0x7300, 0x6180, 0x7F80, 0x7F80, 0x6000, 0x7180, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // e
0x0000, 0x07C0, 0x0FC0, 0x0C00, 0x0C00, 0x7F80, 0x7F80, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0000, 0x0000, 0x0000,   // f
0x0000, 0x0000, 0x0000, 0x0000, 0x1D80, 0x3F80, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F80, 0x1D80, 0x0180, 0x6380, 0x7F00, 0x3E00,   // g
0x0000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6F00, 0x7F80, 0x7180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x0000, 0x0000, 0x0000,   // h
0x0000, 0x0600, 0x0600, 0x0000, 0x0000, 0x3E00, 0x3E00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0000, 0x0000, 0x0000,   // i
0x0600, 0x0600, 0x0000, 0x0000, 0x3E00, 0x3E00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x4600, 0x7E00, 0x3C00,   // j
0x0000, 0x6000, 0x6000, 0x6000, 0x6000, 0x6180, 0x6300, 0x6600, 0x6C00, 0x7C00, 0x7600, 0x6300, 0x6300, 0x6180, 0x60C0, 0x0000, 0x0000, 0x0000,   // k
0x0000, 0x3E00, 0x3E00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0000, 0x0000, 0x0000,   // l
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xDD80, 0xFFC0, 0xCEC0, 0xCCC0, 0xCCC0, 0xCCC0, 0xCCC0, 0xCCC0, 0xCCC0, 0xCCC0, 0x0000, 0x0000, 0x0000,   // m
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x6F00, 0x7F80, 0x7180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x0000, 0x0000, 0x0000,   // n
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1E00, 0x3F00, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // o
0x0000, 0x0000, 0x0000, 0x0000, 0x6E00, 0x7F00, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x7F00, 0x6E00, 0x6000, 0x6000, 0x6000, 0x6000,   // p
0x0000, 0x0000, 0x0000, 0x0000, 0x1D80, 0x3F80, 0x7380, 0x6180, 0x6180, 0x6180, 0x6180, 0x7380, 0x3F80, 0x1D80, 0x0180, 0x0180, 0x0180, 0x0180,   // q
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x6700, 0x3F80, 0x3900, 0x3000, 0x3000, 0x3000, 0x3000, 0x3000, 0x3000, 0x3000, 0x0000, 0x0000, 0x0000,   // r
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1E00, 0x3F80, 0x6180, 0x6000, 0x7F00, 0x3F80, 0x0180, 0x6180, 0x7F00, 0x1E00, 0x0000, 0x0000, 0x0000,   // s
0x0000, 0x0000, 0x0800, 0x1800, 0x1800, 0x7F00, 0x7F00, 0x1800, 0x1800, 0x1800, 0x1800, 0x1800, 0x1800, 0x1F80, 0x0F80, 0x0000, 0x0000, 0x0000,   // t
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6180, 0x6380, 0x7F80, 0x3D80, 0x0000, 0x0000, 0x0000,   // u
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x60C0, 0x3180, 0x3180, 0x3180, 0x1B00, 0x1B00, 0x1B00, 0x0E00, 0x0E00, 0x0600, 0x0000, 0x0000, 0x0000,   // v
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xDD80, 0xDD80, 0xDD80, 0x5500, 0x5500, 0x5500, 0x7700, 0x7700, 0x2200, 0x2200, 0x0000, 0x0000, 0x0000,   // w
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x6180, 0x3300, 0x3300, 0x1E00, 0x0C00, 0x0C00, 0x1E00, 0x3300, 0x3300, 0x6180, 0x0000, 0x0000, 0x0000,   // x
0x0000, 0x0000, 0x0000, 0x0000, 0x6180, 0x6180, 0x3180, 0x3300, 0x3300, 0x1B00, 0x1B00, 0x1B00, 0x0E00, 0x0E00, 0x0E00, 0x1C00, 0x7C00, 0x7000,   // y
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x7FC0, 0x7FC0, 0x0180, 0x0300, 0x0600, 0x0C00, 0x1800, 0x3000, 0x7FC0, 0x7FC0, 0x0000, 0x0000, 0x0000,   // z
0x0380, 0x0780, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0E00, 0x1C00, 0x1C00, 0x0E00, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0780, 0x0380,   // {
0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600, 0x0600,   // |
0x3800, 0x3C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0E00, 0x0700, 0x0700, 0x0E00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x0C00, 0x3C00, 0x3800,   // }
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3880, 0x7F80, 0x4700, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // ~
#endif
#ifdef SSD1306_INCLUDE_FONT_16x26
static const uint16_t Font16x26 [] = {
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [ ]
0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03C0,0x03C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [!]
0x1E3C,0x1E3C,0x1E3C,0x1E3C,0x1E3C,0x1E3C,0x1E3C,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = ["]
0x01CE,0x03CE,0x03DE,0x039E,0x039C,0x079C,0x3FFF,0x7FFF,0x0738,0x0F38,0x0F78,0x0F78,0x0E78,0xFFFF,0xFFFF,0x1EF0,0x1CF0,0x1CE0,0x3CE0,0x3DE0,0x39E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [#]
0x03FC,0x0FFE,0x1FEE,0x1EE0,0x1EE0,0x1EE0,0x1EE0,0x1FE0,0x0FE0,0x07E0,0x03F0,0x01FC,0x01FE,0x01FE,0x01FE,0x01FE,0x01FE,0x01FE,0x3DFE,0x3FFC,0x0FF0,0x01E0,0x01E0,0x0000,0x0000,0x0000, // Ascii = [$]
0x3E03,0xF707,0xE78F,0xE78E,0xE39E,0xE3BC,0xE7B8,0xE7F8,0xF7F0,0x3FE0,0x01C0,0x03FF,0x07FF,0x07F3,0x0FF3,0x1EF3,0x3CF3,0x38F3,0x78F3,0xF07F,0xE03F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [%]
0x07E0,0x0FF8,0x0F78,0x1F78,0x1F78,0x1F78,0x0F78,0x0FF0,0x0FE0,0x1F80,0x7FC3,0xFBC3,0xF3E7,0xF1F7,0xF0F7,0xF0FF,0xF07F,0xF83E,0x7C7F,0x3FFF,0x1FEF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [&]
0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03C0,0x01C0,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [']
0x003F,0x007C,0x01F0,0x01E0,0x03C0,0x07C0,0x0780,0x0780,0x0F80,0x0F00,0x0F00,0x0F00,0x0F00,0x0F00,0x0F00,0x0F80,0x0780,0x0780,0x07C0,0x03C0,0x01E0,0x01F0,0x007C,0x003F,0x000F,0x0000, // Ascii = [(]
0x7E00,0x1F00,0x07C0,0x03C0,0x01E0,0x01F0,0x00F0,0x00F0,0x00F8,0x0078,0x0078,0x0078,0x0078,0x0078,0x0078,0x00F8,0x00F0,0x00F0,0x01F0,0x01E0,0x03C0,0x07C0,0x1F00,0x7E00,0x7800,0x0000, // Ascii = [)]
0x03E0,0x03C0,0x01C0,0x39CE,0x3FFF,0x3F7F,0x0320,0x0370,0x07F8,0x0F78,0x1F3C,0x0638,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [*]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0xFFFF,0xFFFF,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [+]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x01E0,0x01E0,0x01E0,0x01C0,0x0380, // Ascii = [,]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3FFE,0x3FFE,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [-]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [.]
0x000F,0x000F,0x001E,0x001E,0x003C,0x003C,0x0078,0x0078,0x00F0,0x00F0,0x01E0,0x01E0,0x03C0,0x03C0,0x0780,0x0780,0x0F00,0x0F00,0x1E00,0x1E00,0x3C00,0x3C00,0x7800,0x7800,0xF000,0x0000, // Ascii = [/]
0x07F0,0x0FF8,0x1F7C,0x3E3E,0x3C1E,0x7C1F,0x7C1F,0x780F,0x780F,0x780F,0x780F,0x780F,0x780F,0x780F,0x7C1F,0x7C1F,0x3C1E,0x3E3E,0x1F7C,0x0FF8,0x07F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [0]
0x00F0,0x07F0,0x3FF0,0x3FF0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x3FFF,0x3FFF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [1]
0x0FE0,0x3FF8,0x3C7C,0x003C,0x003E,0x003E,0x003E,0x003C,0x003C,0x007C,0x00F8,0x01F0,0x03E0,0x07C0,0x0780,0x0F00,0x1E00,0x3E00,0x3C00,0x3FFE,0x3FFE,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [2]
0x0FF0,0x1FF8,0x1C7C,0x003E,0x003E,0x003E,0x003C,0x003C,0x00F8,0x0FF0,0x0FF8,0x007C,0x003E,0x001E,0x001E,0x001E,0x001E,0x003E,0x1C7C,0x1FF8,0x1FE0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [3]
0x0078,0x00F8,0x00F8,0x01F8,0x03F8,0x07F8,0x07F8,0x0F78,0x1E78,0x1E78,0x3C78,0x7878,0x7878,0xFFFF,0xFFFF,0x0078,0x0078,0x0078,0x0078,0x0078,0x0078,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [4]
0x1FFC,0x1FFC,0x1FFC,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1FE0,0x1FF8,0x00FC,0x007C,0x003E,0x003E,0x001E,0x003E,0x003E,0x003C,0x1C7C,0x1FF8,0x1FE0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [5]
0x01FC,0x07FE,0x0F8E,0x1F00,0x1E00,0x3E00,0x3C00,0x3C00,0x3DF8,0x3FFC,0x7F3E,0x7E1F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3E0F,0x1E1F,0x1F3E,0x0FFC,0x03F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [6]
0x3FFF,0x3FFF,0x3FFF,0x000F,0x001E,0x001E,0x003C,0x0038,0x0078,0x00F0,0x00F0,0x01E0,0x01E0,0x03C0,0x03C0,0x0780,0x0F80,0x0F80,0x0F00,0x1F00,0x1F00,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [7]
0x07F8,0x0FFC,0x1F3E,0x1E1E,0x3E1E,0x3E1E,0x1E1E,0x1F3C,0x0FF8,0x07F0,0x0FF8,0x1EFC,0x3E3E,0x3C1F,0x7C1F,0x7C0F,0x7C0F,0x3C1F,0x3F3E,0x1FFC,0x07F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [8]
0x07F0,0x0FF8,0x1E7C,0x3C3E,0x3C1E,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x3C1F,0x3E3F,0x1FFF,0x07EF,0x001F,0x001E,0x001E,0x003E,0x003C,0x38F8,0x3FF0,0x1FE0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [9]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [:]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03E0,0x03E0,0x03E0,0x03E0,0x01E0,0x01E0,0x01E0,0x03C0,0x0380, // Ascii = [;]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0003,0x000F,0x003F,0x00FC,0x03F0,0x0FC0,0x3F00,0xFE00,0x3F00,0x0FC0,0x03F0,0x00FC,0x003F,0x000F,0x0003,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [<]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xFFFF,0xFFFF,0x0000,0x0000,0x0000,0xFFFF,0xFFFF,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [=]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xE000,0xF800,0x7E00,0x1F80,0x07E0,0x01F8,0x007E,0x001F,0x007E,0x01F8,0x07E0,0x1F80,0x7E00,0xF800,0xE000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [>]
0x1FF0,0x3FFC,0x383E,0x381F,0x381F,0x001E,0x001E,0x003C,0x0078,0x00F0,0x01E0,0x03C0,0x03C0,0x07C0,0x07C0,0x0000,0x0000,0x0000,0x07C0,0x07C0,0x07C0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [?]
0x03F8,0x0FFE,0x1F1E,0x3E0F,0x3C7F,0x78FF,0x79EF,0x73C7,0xF3C7,0xF38F,0xF38F,0xF38F,0xF39F,0xF39F,0x73FF,0x7BFF,0x79F7,0x3C00,0x1F1C,0x0FFC,0x03F8,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [@]
0x0000,0x0000,0x0000,0x03E0,0x03E0,0x07F0,0x07F0,0x07F0,0x0F78,0x0F78,0x0E7C,0x1E3C,0x1E3C,0x3C3E,0x3FFE,0x3FFF,0x781F,0x780F,0xF00F,0xF007,0xF007,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [A]
0x0000,0x0000,0x0000,0x3FF8,0x3FFC,0x3C3E,0x3C1E,0x3C1E,0x3C1E,0x3C3E,0x3C7C,0x3FF0,0x3FF8,0x3C7E,0x3C1F,0x3C1F,0x3C0F,0x3C0F,0x3C1F,0x3FFE,0x3FF8,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [B]
0x0000,0x0000,0x0000,0x01FF,0x07FF,0x1F87,0x3E00,0x3C00,0x7C00,0x7800,0x7800,0x7800,0x7800,0x7800,0x7C00,0x7C00,0x3E00,0x3F00,0x1F83,0x07FF,0x01FF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [C]
0x0000,0x0000,0x0000,0x7FF0,0x7FFC,0x787E,0x781F,0x781F,0x780F,0x780F,0x780F,0x780F,0x780F,0x780F,0x780F,0x780F,0x781F,0x781E,0x787E,0x7FF8,0x7FE0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [D]
0x0000,0x0000,0x0000,0x3FFF,0x3FFF,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3FFE,0x3FFE,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3FFF,0x3FFF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [E]
0x0000,0x0000,0x0000,0x1FFF,0x1FFF,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1FFF,0x1FFF,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x1E00,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [F]
0x0000,0x0000,0x0000,0x03FE,0x0FFF,0x1F87,0x3E00,0x7C00,0x7C00,0x7800,0xF800,0xF800,0xF87F,0xF87F,0x780F,0x7C0F,0x7C0F,0x3E0F,0x1F8F,0x0FFF,0x03FE,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [G]
0x0000,0x0000,0x0000,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7FFF,0x7FFF,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x7C1F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [H]
0x0000,0x0000,0x0000,0x3FFC,0x3FFC,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x3FFC,0x3FFC,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [I]
0x0000,0x0000,0x0000,0x1FFC,0x1FFC,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x007C,0x0078,0x0078,0x38F8,0x3FF0,0x3FC0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [J]
0x0000,0x0000,0x0000,0x3C1F,0x3C1E,0x3C3C,0x3C78,0x3CF0,0x3DE0,0x3FE0,0x3FC0,0x3F80,0x3FC0,0x3FE0,0x3DF0,0x3CF0,0x3C78,0x3C7C,0x3C3E,0x3C1F,0x3C0F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [K]
0x0000,0x0000,0x0000,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3FFC,0x3FFC,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [L]
0x0000,0x0000,0x0000,0xF81F,0xFC1F,0xFC1F,0xFE3F,0xFE3F,0xFE3F,0xFF7F,0xFF77,0xFF77,0xF7F7,0xF7E7,0xF3E7,0xF3E7,0xF3C7,0xF007,0xF007,0xF007,0xF007,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [M]
0x0000,0x0000,0x0000,0x7C0F,0x7C0F,0x7E0F,0x7F0F,0x7F0F,0x7F8F,0x7F8F,0x7FCF,0x7BEF,0x79EF,0x79FF,0x78FF,0x78FF,0x787F,0x783F,0x783F,0x781F,0x781F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [N]
0x0000,0x0000,0x0000,0x07F0,0x1FFC,0x3E3E,0x7C1F,0x780F,0x780F,0xF80F,0xF80F,0xF80F,0xF80F,0xF80F,0xF80F,0x780F,0x780F,0x7C1F,0x3E3E,0x1FFC,0x07F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [O]
0x0000,0x0000,0x0000,0x3FFC,0x3FFF,0x3E1F,0x3E0F,0x3E0F,0x3E0F,0x3E0F,0x3E1F,0x3E3F,0x3FFC,0x3FF0,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x3E00,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [P]
0x0000,0x0000,0x0000,0x07F0,0x1FFC,0x3E3E,0x7C1F,0x780F,0x780F,0xF80F,0xF80F,0xF80F,0xF80F,0xF80F,0xF80F,0x780F,0x780F,0x7C1F,0x3E3E,0x1FFC,0x07F8,0x007C,0x003F,0x000F,0x0003,0x0000, // Ascii = [Q]
0x0000,0x0000,0x0000,0x3FF0,0x3FFC,0x3C7E,0x3C3E,0x3C1E,0x3C1E,0x3C3E,0x3C3C,0x3CFC,0x3FF0,0x3FE0,0x3DF0,0x3CF8,0x3C7C,0x3C3E,0x3C1E,0x3C1F,0x3C0F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [R]
0x0000,0x0000,0x0000,0x07FC,0x1FFE,0x3E0E,0x3C00,0x3C00,0x3C00,0x3E00,0x1FC0,0x0FF8,0x03FE,0x007F,0x001F,0x000F,0x000F,0x201F,0x3C3E,0x3FFC,0x1FF0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [S]
0x0000,0x0000,0x0000,0xFFFF,0xFFFF,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [T]
0x0000,0x0000,0x0000,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x7C0F,0x3C1E,0x3C1E,0x3E3E,0x1FFC,0x07F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [U]
0x0000,0x0000,0x0000,0xF007,0xF007,0xF807,0x780F,0x7C0F,0x3C1E,0x3C1E,0x3E1E,0x1E3C,0x1F3C,0x1F78,0x0F78,0x0FF8,0x07F0,0x07F0,0x07F0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [V]
0x0000,0x0000,0x0000,0xE003,0xF003,0xF003,0xF007,0xF3E7,0xF3E7,0xF3E7,0x73E7,0x7BF7,0x7FF7,0x7FFF,0x7F7F,0x7F7F,0x7F7E,0x3F7E,0x3E3E,0x3E3E,0x3E3E,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [W]
0x0000,0x0000,0x0000,0xF807,0x7C0F,0x3E1E,0x3E3E,0x1F3C,0x0FF8,0x07F0,0x07E0,0x03E0,0x03E0,0x07F0,0x0FF8,0x0F7C,0x1E7C,0x3C3E,0x781F,0x780F,0xF00F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [X]
0x0000,0x0000,0x0000,0xF807,0x7807,0x7C0F,0x3C1E,0x3E1E,0x1F3C,0x0F78,0x0FF8,0x07F0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [Y]
0x0000,0x0000,0x0000,0x7FFF,0x7FFF,0x000F,0x001F,0x003E,0x007C,0x00F8,0x00F0,0x01E0,0x03E0,0x07C0,0x0F80,0x0F00,0x1E00,0x3E00,0x7C00,0x7FFF,0x7FFF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [Z]
0x07FF,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x07FF,0x07FF,0x0000, // Ascii = [[]
0x7800,0x7800,0x3C00,0x3C00,0x1E00,0x1E00,0x0F00,0x0F00,0x0780,0x0780,0x03C0,0x03C0,0x01E0,0x01E0,0x00F0,0x00F0,0x0078,0x0078,0x003C,0x003C,0x001E,0x001E,0x000F,0x000F,0x0007,0x0000, // Ascii = [\]
0x7FF0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x00F0,0x7FF0,0x7FF0,0x0000, // Ascii = []]
0x00C0,0x01C0,0x01C0,0x03E0,0x03E0,0x07F0,0x07F0,0x0778,0x0F78,0x0F38,0x1E3C,0x1E3C,0x3C1E,0x3C1E,0x380F,0x780F,0x7807,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [^]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xFFFF,0xFFFF,0x0000,0x0000,0x0000, // Ascii = [_]
0x00F0,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [`]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0FF8,0x3FFC,0x3C7C,0x003E,0x003E,0x003E,0x07FE,0x1FFE,0x3E3E,0x7C3E,0x783E,0x7C3E,0x7C7E,0x3FFF,0x1FCF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [a]
0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3DF8,0x3FFE,0x3F3E,0x3E1F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C1F,0x3C1E,0x3F3E,0x3FFC,0x3BF0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [b]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03FE,0x0FFF,0x1F87,0x3E00,0x3E00,0x3C00,0x7C00,0x7C00,0x7C00,0x3C00,0x3E00,0x3E00,0x1F87,0x0FFF,0x03FE,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [c]
0x001F,0x001F,0x001F,0x001F,0x001F,0x001F,0x07FF,0x1FFF,0x3E3F,0x3C1F,0x7C1F,0x7C1F,0x7C1F,0x781F,0x781F,0x7C1F,0x7C1F,0x3C3F,0x3E7F,0x1FFF,0x0FDF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [d]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x03F8,0x0FFC,0x1F3E,0x3E1E,0x3C1F,0x7C1F,0x7FFF,0x7FFF,0x7C00,0x7C00,0x3C00,0x3E00,0x1F07,0x0FFF,0x03FE,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [e]
0x01FF,0x03E1,0x03C0,0x07C0,0x07C0,0x07C0,0x7FFF,0x7FFF,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x07C0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [f]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x07EF,0x1FFF,0x3E7F,0x3C1F,0x7C1F,0x7C1F,0x781F,0x781F,0x781F,0x7C1F,0x7C1F,0x3C3F,0x3E7F,0x1FFF,0x0FDF,0x001E,0x001E,0x001E,0x387C,0x3FF8, // Ascii = [g]
0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3DFC,0x3FFE,0x3F9E,0x3F1F,0x3E1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [h]
0x01F0,0x01F0,0x0000,0x0000,0x0000,0x0000,0x7FE0,0x7FE0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [i]
0x00F8,0x00F8,0x0000,0x0000,0x0000,0x0000,0x3FF8,0x3FF8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F8,0x00F0,0x71F0,0x7FE0, // Ascii = [j]
0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3C00,0x3C1F,0x3C3E,0x3C7C,0x3CF8,0x3DF0,0x3DE0,0x3FC0,0x3FC0,0x3FE0,0x3DF0,0x3CF8,0x3C7C,0x3C3E,0x3C1F,0x3C1F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [k]
0x7FF0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x01F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [l]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xF79E,0xFFFF,0xFFFF,0xFFFF,0xFBE7,0xF9E7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0xF1C7,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [m]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3DFC,0x3FFE,0x3F9E,0x3F1F,0x3E1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x3C1F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [n]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x07F0,0x1FFC,0x3E3E,0x3C1F,0x7C1F,0x780F,0x780F,0x780F,0x780F,0x780F,0x7C1F,0x3C1F,0x3E3E,0x1FFC,0x07F0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [o]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3DF8,0x3FFE,0x3F3E,0x3E1F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C0F,0x3C1F,0x3E1E,0x3F3E,0x3FFC,0x3FF8,0x3C00,0x3C00,0x3C00,0x3C00,0x3C00, // Ascii = [p]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x07EE,0x1FFE,0x3E7E,0x3C1E,0x7C1E,0x781E,0x781E,0x781E,0x781E,0x781E,0x7C1E,0x7C3E,0x3E7E,0x1FFE,0x0FDE,0x001E,0x001E,0x001E,0x001E,0x001E, // Ascii = [q]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x1F7F,0x1FFF,0x1FE7,0x1FC7,0x1F87,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x1F00,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [r]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x07FC,0x1FFE,0x1E0E,0x3E00,0x3E00,0x3F00,0x1FE0,0x07FC,0x00FE,0x003E,0x001E,0x001E,0x3C3E,0x3FFC,0x1FF0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [s]
0x0000,0x0000,0x0000,0x0780,0x0780,0x0780,0x7FFF,0x7FFF,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x0780,0x07C0,0x03FF,0x01FF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [t]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C1E,0x3C3E,0x3C7E,0x3EFE,0x1FFE,0x0FDE,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [u]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xF007,0x780F,0x780F,0x3C1E,0x3C1E,0x3E1E,0x1E3C,0x1E3C,0x0F78,0x0F78,0x0FF0,0x07F0,0x07F0,0x03E0,0x03E0,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [v]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xF003,0xF1E3,0xF3E3,0xF3E7,0xF3F7,0xF3F7,0x7FF7,0x7F77,0x7F7F,0x7F7F,0x7F7F,0x3E3E,0x3E3E,0x3E3E,0x3E3E,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [w]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x7C0F,0x3E1E,0x3E3C,0x1F3C,0x0FF8,0x07F0,0x07F0,0x03E0,0x07F0,0x07F8,0x0FF8,0x1E7C,0x3E3E,0x3C1F,0x781F,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [x]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0xF807,0x780F,0x7C0F,0x3C1E,0x3C1E,0x1E3C,0x1E3C,0x1F3C,0x0F78,0x0FF8,0x07F0,0x07F0,0x03E0,0x03E0,0x03C0,0x03C0,0x03C0,0x0780,0x0F80,0x7F00, // Ascii = [y]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3FFF,0x3FFF,0x001F,0x003E,0x007C,0x00F8,0x01F0,0x03E0,0x07C0,0x0F80,0x1F00,0x1E00,0x3C00,0x7FFF,0x7FFF,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [z]
0x01FE,0x03E0,0x03C0,0x03C0,0x03C0,0x03C0,0x01E0,0x01E0,0x01E0,0x01C0,0x03C0,0x3F80,0x3F80,0x03C0,0x01C0,0x01E0,0x01E0,0x01E0,0x03C0,0x03C0,0x03C0,0x03C0,0x03E0,0x01FE,0x007E,0x0000, // Ascii = [{]
0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x01C0,0x0000, // Ascii = [|]
0x3FC0,0x03E0,0x01E0,0x01E0,0x01E0,0x01E0,0x01C0,0x03C0,0x03C0,0x01C0,0x01E0,0x00FE,0x00FE,0x01E0,0x01C0,0x03C0,0x03C0,0x01C0,0x01E0,0x01E0,0x01E0,0x01E0,0x03E0,0x3FC0,0x3F00,0x0000, // Ascii = [}]
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3F07,0x7FC7,0x73E7,0xF1FF,0xF07E,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, // Ascii = [~]
#endif
#ifdef SSD1306_INCLUDE_FONT_6x8
static const uint16_t Font6x8 [] = {
0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x0000, 0x2000, 0x0000,  // !
0x5000, 0x5000, 0x5000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // "
0x5000, 0x5000, 0xf800, 0x5000, 0xf800, 0x5000, 0x5000, 0x0000,  // #
0x2000, 0x7800, 0xa000, 0x7000, 0x2800, 0xf000, 0x2000, 0x0000,  // $
0xc000, 0xc800, 0x1000, 0x2000, 0x4000, 0x9800, 0x1800, 0x0000,  // %
0x4000, 0xa000, 0xa000, 0x4000, 0xa800, 0x9000, 0x6800, 0x0000,  // &
0x3000, 0x3000, 0x2000, 0x4000, 0x0000, 0x0000, 0x0000, 0x0000,  // '
0x1000, 0x2000, 0x4000, 0x4000, 0x4000, 0x2000, 0x1000, 0x0000,  // (
0x4000, 0x2000, 0x1000, 0x1000, 0x1000, 0x2000, 0x4000, 0x0000,  // )
0x2000, 0xa800, 0x7000, 0xf800, 0x7000, 0xa800, 0x2000, 0x0000,  // *
0x0000, 0x2000, 0x2000, 0xf800, 0x2000, 0x2000, 0x0000, 0x0000,  // +
0x0000, 0x0000, 0x0000, 0x0000, 0x3000, 0x3000, 0x2000, 0x0000,  // ,
0x0000, 0x0000, 0x0000, 0xf800, 0x0000, 0x0000, 0x0000, 0x0000,  // -
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x3000, 0x3000, 0x0000,  // .
0x0000, 0x0800, 0x1000, 0x2000, 0x4000, 0x8000, 0x0000, 0x0000,  // /
0x7000, 0x8800, 0x9800, 0xa800, 0xc800, 0x8800, 0x7000, 0x0000,  // 0
0x2000, 0x6000, 0x2000, 0x2000, 0x2000, 0x2000, 0x7000, 0x0000,  // 1
0x7000, 0x8800, 0x0800, 0x7000, 0x8000, 0x8000, 0xf800, 0x0000,  // 2
0xf800, 0x0800, 0x1000, 0x3000, 0x0800, 0x8800, 0x7000, 0x0000,  // 3
0x1000, 0x3000, 0x5000, 0x9000, 0xf800, 0x1000, 0x1000, 0x0000,  // 4
0xf800, 0x8000, 0xf000, 0x0800, 0x0800, 0x8800, 0x7000, 0x0000,  // 5
0x3800, 0x4000, 0x8000, 0xf000, 0x8800, 0x8800, 0x7000, 0x0000,  // 6
0xf800, 0x0800, 0x0800, 0x1000, 0x2000, 0x4000, 0x8000, 0x0000,  // 7
0x7000, 0x8800, 0x8800, 0x7000, 0x8800, 0x8800, 0x7000, 0x0000,  // 8
0x7000, 0x8800, 0x8800, 0x7800, 0x0800, 0x1000, 0xe000, 0x0000,  // 9
0x0000, 0x0000, 0x2000, 0x0000, 0x2000, 0x0000, 0x0000, 0x0000,  // :
0x0000, 0x0000, 0x2000, 0x0000, 0x2000, 0x2000, 0x4000, 0x0000,  // ;
0x0800, 0x1000, 0x2000, 0x4000, 0x2000, 0x1000, 0x0800, 0x0000,  // <
0x0000, 0x0000, 0xf800, 0x0000, 0xf800, 0x0000, 0x0000, 0x0000,  // =
0x4000, 0x2000, 0x1000, 0x0800, 0x1000, 0x2000, 0x4000, 0x0000,  // >
0x7000, 0x8800, 0x0800, 0x3000, 0x2000, 0x0000, 0x2000, 0x0000,  // ?
0x7000, 0x8800, 0xa800, 0xb800, 0xb000, 0x8000, 0x7800, 0x0000,  // @
0x2000, 0x5000, 0x8800, 0x8800, 0xf800, 0x8800, 0x8800, 0x0000,  // A
0xf000, 0x8800, 0x8800, 0xf000, 0x8800, 0x8800, 0xf000, 0x0000,  // B
0x7000, 0x8800, 0x8000, 0x8000, 0x8000, 0x8800, 0x7000, 0x0000,  // C
0xf000, 0x8800, 0x8800, 0x8800, 0x8800, 0x8800, 0xf000, 0x0000,  // D
0xf800, 0x8000, 0x8000, 0xf000, 0x8000, 0x8000, 0xf800, 0x0000,  // E
0xf800, 0x8000, 0x8000, 0xf000, 0x8000, 0x8000, 0x8000, 0x0000,  // F
0x7800, 0x8800, 0x8000, 0x8000, 0x9800, 0x8800, 0x7800, 0x0000,  // G
0x8800, 0x8800, 0x8800, 0xf800, 0x8800, 0x8800, 0x8800, 0x0000,  // H
0x7000, 0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x7000, 0x0000,  // I
0x3800, 0x1000, 0x1000, 0x1000, 0x1000, 0x9000, 0x6000, 0x0000,  // J
0x8800, 0x9000, 0xa000, 0xc000, 0xa000, 0x9000, 0x8800, 0x0000,  // K
0x8000, 0x8000, 0x8000, 0x8000, 0x8000, 0x8000, 0xf800, 0x0000,  // L
0x8800, 0xd800, 0xa800, 0xa800, 0xa800, 0x8800, 0x8800, 0x0000,  // M
0x8800, 0x8800, 0xc800, 0xa800, 0x9800, 0x8800, 0x8800, 0x0000,  // N
0x7000, 0x8800, 0x8800, 0x8800, 0x8800, 0x8800, 0x7000, 0x0000,  // O
0xf000, 0x8800, 0x8800, 0xf000, 0x8000, 0x8000, 0x8000, 0x0000,  // P
0x7000, 0x8800, 0x8800, 0x8800, 0xa800, 0x9000, 0x6800, 0x0000,  // Q
0xf000, 0x8800, 0x8800, 0xf000, 0xa000, 0x9000, 0x8800, 0x0000,  // R
0x7000, 0x8800, 0x8000, 0x7000, 0x0800, 0x8800, 0x7000, 0x0000,  // S
0xf800, 0xa800, 0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x0000,  // T
0x8800, 0x8800, 0x8800, 0x8800, 0x8800, 0x8800, 0x7000, 0x0000,  // U
0x8800, 0x8800, 0x8800, 0x8800, 0x8800, 0x5000, 0x2000, 0x0000,  // V
0x8800, 0x8800, 0x8800, 0xa800, 0xa800, 0xa800, 0x5000, 0x0000,  // W
0x8800, 0x8800, 0x5000, 0x2000, 0x5000, 0x8800, 0x8800, 0x0000,  // X
0x8800, 0x8800, 0x5000, 0x2000, 0x2000, 0x2000, 0x2000, 0x0000,  // Y
0xf800, 0x0800, 0x1000, 0x7000, 0x4000, 0x8000, 0xf800, 0x0000,  // Z
0x7800, 0x4000, 0x4000, 0x4000, 0x4000, 0x4000, 0x7800, 0x0000,  // [
0x0000, 0x8000, 0x4000, 0x2000, 0x1000, 0x0800, 0x0000, 0x0000,  /* \ */
0x7800, 0x0800, 0x0800, 0x0800, 0x0800, 0x0800, 0x7800, 0x0000,  // ]
0x2000, 0x5000, 0x8800, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // ^
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xf800, 0x0000,  // _
0x6000, 0x6000, 0x2000, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000,  // `
0x0000, 0x0000, 0x6000, 0x1000, 0x7000, 0x9000, 0x7800, 0x0000,  // a
0x8000, 0x8000, 0xb000, 0xc800, 0x8800, 0xc800, 0xb000, 0x0000,  // b
0x0000, 0x0000, 0x7000, 0x8800, 0x8000, 0x8800, 0x7000, 0x0000,  // c
0x0800, 0x0800, 0x6800, 0x9800, 0x8800, 0x9800, 0x6800, 0x0000,  // d
0x0000, 0x0000, 0x7000, 0x8800, 0xf800, 0x8000, 0x7000, 0x0000,  // e
0x1000, 0x2800, 0x2000, 0x7000, 0x2000, 0x2000, 0x2000, 0x0000,  // f
0x0000, 0x0000, 0x7000, 0x9800, 0x9800, 0x6800, 0x0800, 0x0000,  // g
0x8000, 0x8000, 0xb000, 0xc800, 0x8800, 0x8800, 0x8800, 0x0000,  // h
0x2000, 0x0000, 0x6000, 0x2000, 0x2000, 0x2000, 0x7000, 0x0000,  // i
0x1000, 0x0000, 0x1000, 0x1000, 0x1000, 0x9000, 0x6000, 0x0000,  // j
0x8000, 0x8000, 0x9000, 0xa000, 0xc000, 0xa000, 0x9000, 0x0000,  // k
0x6000, 0x2000, 0x2000, 0x2000, 0x2000, 0x2000, 0x7000, 0x0000,  // l
0x0000, 0x0000, 0xd000, 0xa800, 0xa800, 0xa800, 0xa800, 0x0000,  // m
0x0000, 0x0000, 0xb000, 0xc800, 0x8800, 0x8800, 0x8800, 0x0000,  // n
0x0000, 0x0000, 0x7000, 0x8800, 0x8800, 0x8800, 0x7000, 0x0000,  // o
0x0000, 0x0000, 0xb000, 0xc800, 0xc800, 0xb000, 0x8000, 0x0000,  // p
0x0000, 0x0000, 0x6800, 0x9800, 0x9800, 0x6800, 0x0800, 0x0000,  // q
0x0000, 0x0000, 0xb000, 0xc800, 0x8000, 0x8000, 0x8000, 0x0000,  // r
0x0000, 0x0000, 0x7800, 0x8000, 0x7000, 0x0800, 0xf000, 0x0000,  // s
0x2000, 0x2000, 0xf800, 0x2000, 0x2000, 0x2800, 0x1000, 0x0000,  // t
0x0000, 0x0000, 0x8800, 0x8800, 0x8800, 0x9800, 0x6800, 0x0000,  // u
0x0000, 0x0000, 0x8800, 0x8800, 0x8800, 0x5000, 0x2000, 0x0000,  // v
0x0000, 0x0000, 0x8800, 0x8800, 0xa800, 0xa800, 0x5000, 0x0000,  // w
0x0000, 0x0000, 0x8800, 0x5000, 0x2000, 0x5000, 0x8800, 0x0000,  // x
0x0000, 0x0000, 0x8800, 0x8800, 0x7800, 0x0800, 0x8800, 0x0000,  // y
0x0000, 0x0000, 0xf800, 0x1000, 0x2000, 0x4000, 0xf800, 0x0000,  // z
0x1000, 0x2000, 0x2000, 0x4000, 0x2000, 0x2000, 0x1000, 0x0000,  // {
0x2000, 0x2000, 0x2000, 0x0000, 0x2000, 0x2000, 0x2000, 0x0000,  // |
0x4000, 0x2000, 0x2000, 0x1000, 0x2000, 0x2000, 0x4000, 0x0000,  // }
0x4000, 0xa800, 0x1000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,  // ~
#endif
/* see ./examples/custom-fonts/ */
#ifdef SSD1306_INCLUDE_FONT_16x24
static const uint16_t Font16x24 [] = {
/* -- <- these are comments and symbol separators */
/* -- This file was created manually by looking at: */
/* -- https://fontstruct.com/fontstructions/show/1724841/hd44780-5x8 */
/* -- space -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0xFFFE, 0xFFFE, 0xFFFE, 0x1C70, 0x1C70, 0x1C70, 0xFFFE, 0xFFFE, 0xFFFE, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x1C70, 0x0000, 0x0000, 0x0000,
0x0380, 0x0380, 0x0380, 0x1FFE, 0x1FFE, 0x1FFE, 0xE380, 0xE380, 0xE380, 0x1FF0, 0x1FF0, 0x1FF0, 0x038E, 0x038E, 0x038E, 0xFFF0, 0xFFF0, 0xFFF0, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
0xFC00, 0xFC00, 0xFC00, 0xFC0E, 0xFC0E, 0xFC0E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xE07E, 0xE07E, 0xE07E, 0x007E, 0x007E, 0x007E, 0x0000, 0x0000, 0x0000,
0x1F80, 0x1F80, 0x1F80, 0xE070, 0xE070, 0xE070, 0xE380, 0xE380, 0xE380, 0x1C00, 0x1C00, 0x1C00, 0xE38E, 0xE38E, 0xE38E, 0xE070, 0xE070, 0xE070, 0x1F8E, 0x1F8E, 0x1F8E, 0x0000, 0x0000, 0x0000,
0x03F0, 0x03F0, 0x03F0, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0000, 0x0000, 0x0000,
0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0380, 0x0380, 0x0380, 0xE38E, 0xE38E, 0xE38E, 0x1FF0, 0x1FF0, 0x1FF0, 0xE38E, 0xE38E, 0xE38E, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0xFFFE, 0xFFFE, 0xFFFE, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x03F0, 0x03F0, 0x03F0, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x03F0, 0x03F0, 0x03F0, 0x03F0, 0x03F0, 0x03F0, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
/* -- 0 -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE07E, 0xE07E, 0xE07E, 0xE38E, 0xE38E, 0xE38E, 0xFC0E, 0xFC0E, 0xFC0E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 1 -- */
0x0380, 0x0380, 0x0380, 0x1F80, 0x1F80, 0x1F80, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 2 -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
/* -- 3 -- */
0xFFFE, 0xFFFE, 0xFFFE, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x000E, 0x000E, 0x000E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 4 -- */
0x0070, 0x0070, 0x0070, 0x03F0, 0x03F0, 0x03F0, 0x1C70, 0x1C70, 0x1C70, 0xE070, 0xE070, 0xE070, 0xFFFE, 0xFFFE, 0xFFFE, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0000, 0x0000, 0x0000,
/* -- 5 -- */
0xFFFE, 0xFFFE, 0xFFFE, 0xE000, 0xE000, 0xE000, 0xFFF0, 0xFFF0, 0xFFF0, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 6 -- */
0x03F0, 0x03F0, 0x03F0, 0x1C00, 0x1C00, 0x1C00, 0xE000, 0xE000, 0xE000, 0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 7 -- */
0xFFFE, 0xFFFE, 0xFFFE, 0xE00E, 0xE00E, 0xE00E, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
/* -- 8 -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- 9 -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x1F80, 0x1F80, 0x1F80, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x0000, 0x0000, 0x0000, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x1F80, 0x0000, 0x0000, 0x0000, 0x1F80, 0x1F80, 0x1F80, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0x0000, 0x0000, 0x0000,
0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xE000, 0xE000, 0xE000, 0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0xE000, 0xE000, 0xE000, 0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000,
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0x000E, 0x000E, 0x000E, 0x1F8E, 0x1F8E, 0x1F8E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- A -- */
0x0380, 0x0380, 0x0380, 0x1C70, 0x1C70, 0x1C70, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFFE, 0xFFFE, 0xFFFE, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- B -- */
0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0x0000, 0x0000, 0x0000,
/* -- C -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- D -- */
0xFF80, 0xFF80, 0xFF80, 0xE070, 0xE070, 0xE070, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE070, 0xE070, 0xE070, 0xFF80, 0xFF80, 0xFF80, 0x0000, 0x0000, 0x0000,
/* -- E -- */
0xFFFE, 0xFFFE, 0xFFFE, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xFFF0, 0xFFF0, 0xFFF0, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
/* -- F -- */
0xFFFE, 0xFFFE, 0xFFFE, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xFFF0, 0xFFF0, 0xFFF0, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000,
/* -- G -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE000, 0xE000, 0xE000, 0xE3FE, 0xE3FE, 0xE3FE, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x0000, 0x0000, 0x0000,
/* -- H -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFFE, 0xFFFE, 0xFFFE, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- I -- */
0x1FF0, 0x1FF0, 0x1FF0, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- J -- */
0x03FE, 0x03FE, 0x03FE, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0xE070, 0xE070, 0xE070, 0x1F80, 0x1F80, 0x1F80, 0x0000, 0x0000, 0x0000,
/* -- K -- */
0xE00E, 0xE00E, 0xE00E, 0xE070, 0xE070, 0xE070, 0xE380, 0xE380, 0xE380, 0xFC00, 0xFC00, 0xFC00, 0xE380, 0xE380, 0xE380, 0xE070, 0xE070, 0xE070, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- L -- */
0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
/* -- M -- */
0xE00E, 0xE00E, 0xE00E, 0xFC7E, 0xFC7E, 0xFC7E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- N -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFC0E, 0xFC0E, 0xFC0E, 0xE38E, 0xE38E, 0xE38E, 0xE07E, 0xE07E, 0xE07E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- O -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- P -- */
0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000,
/* -- Q -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE38E, 0xE38E, 0xE38E, 0xE070, 0xE070, 0xE070, 0x1F8E, 0x1F8E, 0x1F8E, 0x0000, 0x0000, 0x0000,
/* -- R -- */
0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0xE380, 0xE380, 0xE380, 0xE070, 0xE070, 0xE070, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- S -- */
0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE000, 0xE000, 0xE000, 0x1FF0, 0x1FF0, 0x1FF0, 0x000E, 0x000E, 0x000E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- T -- */
0xFFFE, 0xFFFE, 0xFFFE, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
/* -- U -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- V -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1C70, 0x1C70, 0x1C70, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
/* -- W -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0x1C70, 0x1C70, 0x1C70, 0x0000, 0x0000, 0x0000,
/* -- X -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1C70, 0x1C70, 0x1C70, 0x0380, 0x0380, 0x0380, 0x1C70, 0x1C70, 0x1C70, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- Y -- */
0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1C70, 0x1C70, 0x1C70, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
/* -- Z -- */
0xFFFE, 0xFFFE, 0xFFFE, 0x000E, 0x000E, 0x000E, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xE000, 0xE000, 0xE000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
0x1FF0, 0x1FF0, 0x1FF0, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0xE000, 0xE000, 0xE000, 0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x000E, 0x000E, 0x000E, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
0x1FF0, 0x1FF0, 0x1FF0, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
0x0380, 0x0380, 0x0380, 0x1C70, 0x1C70, 0x1C70, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
/* -- _ -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
/* -- a -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FF0, 0x1FF0, 0x1FF0, 0x000E, 0x000E, 0x000E, 0x1FFE, 0x1FFE, 0x1FFE, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x0000, 0x0000, 0x0000,
/* -- b -- */
0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE3F0, 0xE3F0, 0xE3F0, 0xFC0E, 0xFC0E, 0xFC0E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0x0000, 0x0000, 0x0000,
/* -- c -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FF0, 0x1FF0, 0x1FF0, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- d -- */
0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x1F8E, 0x1F8E, 0x1F8E, 0xE07E, 0xE07E, 0xE07E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x0000, 0x0000, 0x0000,
/* -- e -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xFFFE, 0xFFFE, 0xFFFE, 0xE000, 0xE000, 0xE000, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- f -- */
0x03F0, 0x03F0, 0x03F0, 0x1C0E, 0x1C0E, 0x1C0E, 0x1C00, 0x1C00, 0x1C00, 0xFF80, 0xFF80, 0xFF80, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x0000, 0x0000, 0x0000,
/* -- g -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FFE, 0x1FFE, 0x1FFE, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x000E, 0x000E, 0x000E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- h -- */
0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE3F0, 0xE3F0, 0xE3F0, 0xFC0E, 0xFC0E, 0xFC0E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- i -- */
0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000, 0x0380, 0x0380, 0x0380, 0x1F80, 0x1F80, 0x1F80, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- j -- */
0x000E, 0x000E, 0x000E, 0x0000, 0x0000, 0x0000, 0x007E, 0x007E, 0x007E, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x1C0E, 0x1C0E, 0x1C0E, 0x03F0, 0x03F0, 0x03F0, 0x0000, 0x0000, 0x0000,
/* -- k -- */
0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE070, 0xE070, 0xE070, 0xE380, 0xE380, 0xE380, 0xFC00, 0xFC00, 0xFC00, 0xE380, 0xE380, 0xE380, 0xE070, 0xE070, 0xE070, 0x0000, 0x0000, 0x0000,
/* -- l -- */
0x03F0, 0x03F0, 0x03F0, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x0070, 0x03FE, 0x03FE, 0x03FE, 0x0000, 0x0000, 0x0000,
/* -- m -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFC70, 0xFC70, 0xFC70, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0x0000, 0x0000, 0x0000,
/* -- n -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE3F0, 0xE3F0, 0xE3F0, 0xFC0E, 0xFC0E, 0xFC0E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- o -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FF0, 0x1FF0, 0x1FF0, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- p -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFF0, 0xFFF0, 0xFFF0, 0xE00E, 0xE00E, 0xE00E, 0xFFF0, 0xFFF0, 0xFFF0, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000,
/* -- q -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1F8E, 0x1F8E, 0x1F8E, 0xE07E, 0xE07E, 0xE07E, 0x1FFE, 0x1FFE, 0x1FFE, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x000E, 0x0000, 0x0000, 0x0000,
/* -- r -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE3F0, 0xE3F0, 0xE3F0, 0xFC0E, 0xFC0E, 0xFC0E, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0xE000, 0x0000, 0x0000, 0x0000,
/* -- s -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1FF0, 0x1FF0, 0x1FF0, 0xE000, 0xE000, 0xE000, 0x1FF0, 0x1FF0, 0x1FF0, 0x000E, 0x000E, 0x000E, 0xFFF0, 0xFFF0, 0xFFF0, 0x0000, 0x0000, 0x0000,
/* -- t -- */
0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0xFF80, 0xFF80, 0xFF80, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C00, 0x1C0E, 0x1C0E, 0x1C0E, 0x03F0, 0x03F0, 0x03F0, 0x0000, 0x0000, 0x0000,
/* -- u -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE07E, 0xE07E, 0xE07E, 0x1F8E, 0x1F8E, 0x1F8E, 0x0000, 0x0000, 0x0000,
/* -- v -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1C70, 0x1C70, 0x1C70, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
/* -- w -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0xE38E, 0x1C70, 0x1C70, 0x1C70, 0x0000, 0x0000, 0x0000,
/* -- x -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE00E, 0xE00E, 0xE00E, 0x1C70, 0x1C70, 0x1C70, 0x0380, 0x0380, 0x0380, 0x1C70, 0x1C70, 0x1C70, 0xE00E, 0xE00E, 0xE00E, 0x0000, 0x0000, 0x0000,
/* -- y -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0xE00E, 0x1FFE, 0x1FFE, 0x1FFE, 0x000E, 0x000E, 0x000E, 0x1FF0, 0x1FF0, 0x1FF0, 0x0000, 0x0000, 0x0000,
/* -- z -- */
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFFFE, 0xFFFE, 0xFFFE, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0xFFFE, 0xFFFE, 0xFFFE, 0x0000, 0x0000, 0x0000,
0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0000, 0x0000, 0x0000,
0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0000, 0x0000, 0x0000,
0x1C00, 0x1C00, 0x1C00, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0070, 0x0070, 0x0070, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x0380, 0x1C00, 0x1C00, 0x1C00, 0x0000, 0x0000, 0x0000,
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x1F8E, 0x1F8E, 0x1F8E, 0xE070, 0xE070, 0xE070, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,
/* -- EOF -- */
#endif
#ifdef SSD1306_INCLUDE_FONT_16x15
static const uint16_t Font16x15 [] = {
0x0000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x1000,0x0000,0x0000,0x0000,
0x0000,0x1800,0x1800,0x1800,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0480,0x0480,0x0480,0x1FC0,0x0900,0x0900,0x0900,0x3FC0,0x0900,0x1200,0x1200,0x0000,0x0000,0x0000,
0x0400,0x0F00,0x1080,0x1080,0x1000,0x0800,0x0700,0x0080,0x0080,0x1080,0x1080,0x0F00,0x0400,0x0000,0x0000,
0x0000,0x1C00,0x1240,0x1280,0x1280,0x1D00,0x0100,0x0270,0x0490,0x0490,0x0890,0x0070,0x0000,0x0000,0x0000,
0x0000,0x0600,0x0900,0x1100,0x1200,0x0C00,0x0C00,0x1240,0x1140,0x10C0,0x1080,0x0F60,0x0000,0x0000,0x0000,
0x0000,0x2000,0x2000,0x2000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0400,0x0800,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0800,0x0400,
0x2000,0x1000,0x0800,0x0800,0x0800,0x0800,0x0400,0x0400,0x0400,0x0800,0x0800,0x0800,0x0800,0x1000,0x2000,
0x0000,0x0800,0x0800,0x2900,0x1E00,0x1400,0x1200,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0400,0x0400,0x0400,0x0400,0x3FC0,0x0400,0x0400,0x0400,0x0400,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x1000,0x1000,0x1000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x3C00,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x1000,0x0000,0x0000,0x0000,
0x0000,0x0200,0x0200,0x0400,0x0400,0x0400,0x0800,0x0800,0x0800,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,
/** 0 **/
0x0000,0x0F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** 1 **/
0x0000,0x0600,0x1A00,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0000,0x0000,0x0000,
/** 2 **/
0x0000,0x0F00,0x1080,0x1080,0x0080,0x0100,0x0100,0x0200,0x0400,0x0800,0x1000,0x1F80,0x0000,0x0000,0x0000,
/** 3 **/
0x0000,0x0F00,0x1080,0x1080,0x0080,0x0080,0x0700,0x0180,0x0080,0x1080,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** 4 **/
0x0000,0x0100,0x0300,0x0500,0x0500,0x0900,0x0900,0x1100,0x2100,0x3FC0,0x0100,0x0100,0x0000,0x0000,0x0000,
/** 5 **/
0x0000,0x0F80,0x1000,0x1000,0x1000,0x0F00,0x1080,0x0080,0x0080,0x1080,0x0880,0x0700,0x0000,0x0000,0x0000,
/** 6 **/
0x0000,0x0300,0x0C00,0x1000,0x1000,0x1F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** 7 **/
0x0000,0x3F80,0x0080,0x0100,0x0100,0x0100,0x0200,0x0200,0x0400,0x0400,0x0800,0x0800,0x0000,0x0000,0x0000,
/** 8 **/
0x0000,0x0F00,0x1080,0x1080,0x1080,0x1080,0x0F00,0x1980,0x1080,0x1080,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** 9 **/
0x0000,0x0F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F80,0x0080,0x0080,0x0100,0x0E00,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x1000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x1000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x1000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x1000,0x1000,0x1000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0080,0x0300,0x0C00,0x1000,0x0C00,0x0300,0x0080,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x1F80,0x0000,0x0000,0x1F80,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x1000,0x0C00,0x0300,0x0080,0x0300,0x0C00,0x1000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0E00,0x1100,0x1100,0x0100,0x0100,0x0200,0x0400,0x0400,0x0000,0x0000,0x0400,0x0000,0x0000,0x0000,
0x0000,0x0000,0x01F0,0x060C,0x0804,0x10E2,0x1122,0x1222,0x1222,0x1222,0x1224,0x11DC,0x0800,0x0420,0x03C0,
/** A **/
0x0000,0x0600,0x0600,0x0500,0x0900,0x0900,0x0880,0x1080,0x0F80,0x1040,0x2040,0x2020,0x0000,0x0000,0x0000,
/** B **/
0x0000,0x1F80,0x1080,0x1040,0x1040,0x1080,0x1F00,0x10C0,0x1040,0x1040,0x1040,0x1F80,0x0000,0x0000,0x0000,
/** C **/
0x0000,0x0780,0x0840,0x1020,0x1000,0x1000,0x1000,0x1000,0x1000,0x1020,0x0840,0x0780,0x0000,0x0000,0x0000,
/** D **/
0x0000,0x0F80,0x0840,0x0840,0x0820,0x0820,0x0820,0x0820,0x0820,0x0840,0x0840,0x0F80,0x0000,0x0000,0x0000,
/** E **/
0x0000,0x0FC0,0x0800,0x0800,0x0800,0x0800,0x0F80,0x0800,0x0800,0x0800,0x0800,0x0FC0,0x0000,0x0000,0x0000,
/** F **/
0x0000,0x0FC0,0x0800,0x0800,0x0800,0x0800,0x0F80,0x0800,0x0800,0x0800,0x0800,0x0800,0x0000,0x0000,0x0000,
/** G **/
0x0000,0x0780,0x0840,0x1020,0x1000,0x1000,0x1000,0x11E0,0x1020,0x1020,0x0820,0x07C0,0x0000,0x0000,0x0000,
/** H **/
0x0000,0x0820,0x0820,0x0820,0x0820,0x0820,0x0FE0,0x0820,0x0820,0x0820,0x0820,0x0820,0x0000,0x0000,0x0000,
/** I **/
0x0000,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0000,0x0000,0x0000,
/** J **/
0x0000,0x0080,0x0080,0x0080,0x0080,0x0080,0x0080,0x0080,0x1080,0x1080,0x1100,0x0E00,0x0000,0x0000,0x0000,
/** K **/
0x0000,0x0860,0x0880,0x0900,0x0A00,0x0C00,0x0A00,0x0A00,0x0900,0x0880,0x0840,0x0820,0x0000,0x0000,0x0000,
/** L **/
0x0000,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0F80,0x0000,0x0000,0x0000,
/** M **/
0x0000,0x0808,0x0808,0x0818,0x0C18,0x0C28,0x0C28,0x0A28,0x0A48,0x0948,0x0988,0x0888,0x0000,0x0000,0x0000,
/** N **/
0x0000,0x0820,0x0820,0x0C20,0x0C20,0x0A20,0x0920,0x0920,0x08A0,0x0860,0x0860,0x0820,0x0000,0x0000,0x0000,
/** O **/
0x0000,0x0780,0x0840,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x0840,0x0780,0x0000,0x0000,0x0000,
/** P **/
0x0000,0x1F80,0x1040,0x1040,0x1040,0x1040,0x1040,0x1F80,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x0000,
/** Q **/
0x0000,0x0780,0x0840,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x0840,0x0780,0x0040,0x0020,0x0000,
/** R **/
0x0000,0x0F80,0x0840,0x0840,0x0840,0x0840,0x0880,0x0F00,0x0880,0x0880,0x0840,0x0820,0x0000,0x0000,0x0000,
/** S **/
0x0000,0x0F80,0x1040,0x1040,0x1000,0x0E00,0x0380,0x0040,0x0040,0x1040,0x1040,0x0F80,0x0000,0x0000,0x0000,
/** T **/
0x0000,0x3FE0,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0200,0x0000,0x0000,0x0000,
/** U **/
0x0000,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x1020,0x0840,0x0780,0x0000,0x0000,0x0000,
/** V **/
0x0000,0x2020,0x2040,0x1040,0x1080,0x1080,0x0880,0x0900,0x0900,0x0500,0x0600,0x0600,0x0000,0x0000,0x0000,
/** W **/
0x0000,0x1082,0x10C2,0x1142,0x1144,0x1124,0x0924,0x0A24,0x0A28,0x0A18,0x0408,0x0408,0x0000,0x0000,0x0000,
/** X **/
0x0000,0x2040,0x1080,0x0880,0x0900,0x0600,0x0200,0x0500,0x0900,0x0880,0x1040,0x2060,0x0000,0x0000,0x0000,
/** Y **/
0x0000,0x2060,0x1040,0x1080,0x0880,0x0900,0x0600,0x0200,0x0200,0x0200,0x0200,0x0200,0x0000,0x0000,0x0000,
/** Z **/
0x0000,0x1FC0,0x0080,0x0080,0x0100,0x0200,0x0200,0x0400,0x0800,0x1000,0x1000,0x1FC0,0x0000,0x0000,0x0000,
0x1800,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1800,0x0000,
0x0000,0x2000,0x2000,0x1000,0x1000,0x0800,0x0800,0x0800,0x0400,0x0400,0x0400,0x0200,0x0200,0x0000,0x0000,
0x6000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x6000,0x0000,
0x0000,0x0800,0x0C00,0x1400,0x1200,0x1200,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
/** _ **/
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x7E00,0x0000,0x0000,
0x0000,0x1000,0x0800,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
/** a **/
0x0000,0x0000,0x0000,0x0000,0x0F00,0x1080,0x0080,0x0F80,0x1080,0x1080,0x1180,0x0E80,0x0000,0x0000,0x0000,
/** b **/
0x0000,0x1000,0x1000,0x1000,0x1F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1F00,0x0000,0x0000,0x0000,
/** c **/
0x0000,0x0000,0x0000,0x0000,0x0F00,0x1080,0x1080,0x1000,0x1000,0x1000,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** d **/
0x0000,0x0080,0x0080,0x0080,0x0F80,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F80,0x0000,0x0000,0x0000,
/** e **/
0x0000,0x0000,0x0000,0x0000,0x0F00,0x1080,0x1080,0x1F80,0x1000,0x1000,0x0800,0x0780,0x0000,0x0000,0x0000,
/** f **/
0x0600,0x0800,0x1000,0x1000,0x1C00,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x0000,
/** g **/
0x0000,0x0000,0x0000,0x0000,0x0F80,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F80,0x0080,0x1100,0x0F00,
/** h **/
0x0000,0x1000,0x1000,0x1000,0x1700,0x1880,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0000,0x0000,0x0000,
/** i **/
0x0000,0x1000,0x0000,0x0000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x0000,
/** j **/
0x0000,0x2000,0x0000,0x0000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0x2000,0xC000,
/** k **/
0x0000,0x1000,0x1000,0x1000,0x1180,0x1200,0x1400,0x1800,0x1400,0x1200,0x1100,0x1080,0x0000,0x0000,0x0000,
/** l **/
0x0000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x0000,
/** m **/
0x0000,0x0000,0x0000,0x0000,0x1738,0x18C4,0x1084,0x1084,0x1084,0x1084,0x1084,0x1084,0x0000,0x0000,0x0000,
/** n **/
0x0000,0x0000,0x0000,0x0000,0x1700,0x1880,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0000,0x0000,0x0000,
/** o **/
0x0000,0x0000,0x0000,0x0000,0x0F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F00,0x0000,0x0000,0x0000,
/** p **/
0x0000,0x0000,0x0000,0x0000,0x1F00,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1F00,0x1000,0x1000,0x1000,
/** q **/
0x0000,0x0000,0x0000,0x0000,0x0F80,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F80,0x0080,0x0080,0x0080,
/** r **/
0x0000,0x0000,0x0000,0x0000,0x1600,0x1800,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,0x0000,0x0000,
/** s **/
0x0000,0x0000,0x0000,0x0000,0x0E00,0x1100,0x1000,0x0C00,0x0300,0x0100,0x1100,0x0E00,0x0000,0x0000,0x0000,
/** t **/
0x0000,0x0000,0x1000,0x1000,0x3C00,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0C00,0x0000,0x0000,0x0000,
/** u **/
0x0000,0x0000,0x0000,0x0000,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x1080,0x0F80,0x0000,0x0000,0x0000,
/** v **/
0x0000,0x0000,0x0000,0x0000,0x2080,0x2100,0x1100,0x1200,0x1200,0x0A00,0x0C00,0x0400,0x0000,0x0000,0x0000,
/** w **/
0x0000,0x0000,0x0000,0x0000,0x2118,0x2310,0x1310,0x12A0,0x14A0,0x14A0,0x0C60,0x0840,0x0000,0x0000,0x0000,
/** x **/
0x0000,0x0000,0x0000,0x0000,0x2180,0x1200,0x0A00,0x0C00,0x0C00,0x0A00,0x1100,0x2180,0x0000,0x0000,0x0000,
/** y **/
0x0000,0x0000,0x0000,0x0000,0x2080,0x2100,0x1100,0x1200,0x1200,0x0A00,0x0C00,0x0400,0x0400,0x0800,0x1800,
/** z **/
0x0000,0x0000,0x0000,0x0000,0x1F00,0x0100,0x0200,0x0400,0x0800,0x1000,0x1000,0x1F80,0x0000,0x0000,0x0000,
0x0600,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x1000,0x0800,0x0800,0x0800,0x0800,0x0800,0x0800,0x0600,
0x0000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x1000,0x0000,
0x2000,0x1000,0x1000,0x0800,0x0800,0x0800,0x0800,0x0400,0x0800,0x0800,0x0800,0x0800,0x1000,0x1000,0x2000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0C20,0x1320,0x11C0,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
static const uint8_t char_width[] = {
  6,  /**   **/
  5,  /** ! **/
  6,  /** " **/
  11,  /** # **/
  10,  /** $ **/
  13,  /** % **/
  11,  /** & **/
  4,  /** ' **/
  7,  /** ( **/
  7,  /** ) **/
  8,  /** * **/
  10,  /** + **/
  5,  /** , **/
  6,  /** - **/
  5,  /** . **/
  8,  /** / **/
  10,  /** 0 **/
  10,  /** 1 **/
  10,  /** 2 **/
  10,  /** 3 **/
  10,  /** 4 **/
  10,  /** 5 **/
  10,  /** 6 **/
  10,  /** 7 **/
  10,  /** 8 **/
  10,  /** 9 **/
  5,  /** : **/
  5,  /** ; **/
  10,  /** < **/
  10,  /** = **/
  10,  /** > **/
  9,  /** ? **/
  16,  /** @ **/
  11,  /** A **/
  11,  /** B **/
  12,  /** C **/
  12,  /** D **/
  11,  /** E **/
  11,  /** F **/
  12,  /** G **/
  13,  /** H **/
  6,  /** I **/
  10,  /** J **/
  12,  /** K **/
  10,  /** L **/
  15,  /** M **/
  13,  /** N **/
  12,  /** O **/
  11,  /** P **/
  12,  /** Q **/
  12,  /** R **/
  11,  /** S **/
  11,  /** T **/
  12,  /** U **/
  11,  /** V **/
  16,  /** W **/
  11,  /** X **/
  11,  /** Y **/
  11,  /** Z **/
  6,  /** [ **/
  8,  /** \ **/
  5,  /** ] **/
  8,  /** ^ **/
  8,  /** _ **/
  6,  /** ` **/
  10,  /** a **/
  10,  /** b **/
  10,  /** c **/
  10,  /** d **/
  10,  /** e **/
  8,  /** f **/
  10,  /** g **/
  10,  /** h **/
  5,  /** i **/
  5,  /** j **/
  9,  /** k **/
  5,  /** l **/
  15,  /** m **/
  10,  /** n **/
  10,  /** o **/
  10,  /** p **/
  10,  /** q **/
  7,  /** r **/
  9,  /** s **/
  7,  /** t **/
  10,  /** u **/
  9,  /** v **/
  13,  /** w **/
  9,  /** x **/
  9,  /** y **/
  9,  /** z **/
  7,  /** { **/
  5,  /** | **/
  7,  /** } **/
  12,  /** ~ **/
#endif
const SSD1306_Font_t Font_6x8 = {6, 8, Font6x8, NULL};
#endif
#ifdef SSD1306_INCLUDE_FONT_7x10
const SSD1306_Font_t Font_7x10 = {7, 10, Font7x10, NULL};
#endif
#ifdef SSD1306_INCLUDE_FONT_11x18
const SSD1306_Font_t Font_11x18 = {11, 18, Font11x18, NULL};
#endif
const SSD1306_Font_t Font_16x26 = {16, 26, Font16x26, NULL};
#endif
const SSD1306_Font_t Font_16x24 = {16, 24, Font16x24, NULL};
#endif
/** Generated Roboto Thin 15
 * @copyright Google https://github.com/googlefonts/roboto
 * @license This font is licensed under the Apache License, Version 2.0.
const SSD1306_Font_t Font_16x15 = {16, 15, Font16x15, char_width};
#endif
字符显示,为功率监测提前部署好内容显示
void SimpleInfoShow(){
    ssd1306_Fill(Black);
    OLED_ShowChinese(0,0,0,16);
    OLED_ShowChinese(15,0,1,16);
    OLED_ShowChinese(30,0,2,16);
    OLED_ShowChinese(45,0,3,16);
    OLED_ShowChinese(60,0,4,16);
    OLED_ShowChinese(75,0,5,16);
    OLED_ShowChinese(90,0,6,16);
   OLED_ShowChinese(0,16,7,16); // 电
   OLED_ShowChinese(15,16,8,16); // 流
   OLED_ShowChar(30,16,':',16);
   OLED_ShowString(90,16,(uint8_t*)"mA",16);
   OLED_ShowChinese(0,16*2,9,16); // 电
   OLED_ShowChinese(15,16*2,10,16); // 压
   OLED_ShowChar(30,16*2,':',16);
   OLED_ShowString(90,16*2,(uint8_t*)"mV",16);
   OLED_ShowChinese(0,16*3,0,16); // 功
   OLED_ShowChinese(15,16*3,1,16); // 率
   OLED_ShowChar(30,16*3,':',16);
   OLED_ShowString(90,16*3,(uint8_t*)"mW",16);
驱动屏幕显示
/* USER CODE BEGIN 2 */
    ssd1306_Init();
    SimpleInfoShow();
/* USER CODE END 2 */
4、实验效果
关键词: OLED屏幕驱动
