电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 【MAX7800】查找I2C总线上的器件
2025-06-18 13:10:08     打赏
【前言】
I2C是最常见的MCU外设,在I2C下面最多可以挂载0xFF个从机,主机通过I2C地址来选择与从机的通信,这一篇将分享如何查找挂载在MAX7800下面的外设。
【开发板原理图】
在MAX7800FTR有一组I2C可以供用户外接使用,编号为I2C1,接口为P0_16(SCL),P0_17(SDA)用手说明书中标注如下:
【测试代码】
在MAX7800的示例工程中有I2CCAN的示例,根据他的示例,我编写代码如下:
/***** Includes *****/
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "board.h"
#include "mxc_device.h"
#include "mxc_delay.h"
#include "nvic_table.h"
#include "i2c.h"
/***** Definitions *****/
#ifdef BOARD_EVKIT_V1
#define I2C_MASTER MXC_I2C2 // SCL P0_30; SDA P0_31
#define I2C_SCL_PIN 30
#define I2C_SDA_PIN 31
#else
#define I2C_MASTER MXC_I2C1 // SCL P0_16; SDA P0_17
#define I2C_SCL_PIN 16
#define I2C_SDA_PIN 17
#endif
#define I2C_FREQ 100000 // 100kHZ
/***** Globals *****/
uint8_t counter = 0;
int main(void)
    printf("\n\n******** I2C SLAVE ADDRESS SCANNER *********\n");
    printf("\nThis example finds the addresses of any I2C Slave devices connected to the");
    printf("\nsame bus as I2C%d (SCL - P0.%d, SDA - P0.%d).\n", MXC_I2C_GET_IDX(I2C_MASTER),
           I2C_SCL_PIN, I2C_SDA_PIN);
    int error;
    //Setup the I2CM
    error = MXC_I2C_Init(I2C_MASTER, 1, 0);
    if (error != E_NO_ERROR) {
        printf("-->I2C Master Initialization failed, error:%d\n", error);
        return -1;
    } else {
        printf("\n-->I2C Master Initialization Complete\n");
    printf("-->Scanning started\n");
    MXC_I2C_SetFrequency(I2C_MASTER, I2C_FREQ);
    mxc_i2c_req_t reqMaster;
    reqMaster.i2c = I2C_MASTER;
    reqMaster.addr = 0;
    reqMaster.tx_buf = NULL;
    reqMaster.tx_len = 0;
    reqMaster.rx_buf = NULL;
    reqMaster.rx_len = 0;
    reqMaster.restart = 0;
    reqMaster.callback = NULL;
    for (uint8_t address = 8; address < 120; address++) {
        printf(".");
        fflush(0);
        reqMaster.addr = address;
        if ((MXC_I2C_MasterTransaction(&reqMaster)) == 0) {
            printf("\nFound slave ID %03d; 0x%02X\n", address, address);
            counter++;
        MXC_Delay(MXC_DELAY_MSEC(200));
    printf("\n-->Scan finished. %d devices found\n", counter);
    return 0;
【测试】
我通过面包板将SSD1306与面板上面的MAX7800FTHR连接,下载程序后,打开串口助手,打印出如下日志:
找到了从机地址为0x3C,因此SSD1306与开发板连接正常。
【总结】
这一篇分享了如何使用I2C的从机地址查找功能。下一篇将分享如何驱动OLED屏。
关键词: MAX7800     I2C
