电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【SIPEEDM1DOCKSUITEVALBRD试用】开发环境搭建
2026-02-26 17:54:41   被打赏 30 分(兑奖)     打赏
K210有很多种开发方式,选用MaixPy+MaixPy IDE
首先下载MaixPy IDE
https://dl.sipeed.com/shareURL/MAIX/MaixPy/ide/v0.2.5
我使用的WINDOWS开发,所以下载windows的其中一个就行
左下角选择串口,WIN11已默认集成CH340驱动,所以不需要额外安装驱动
连接成功后点运行就可以连上板子了
调用一下摄像头
import sensor, image, time, lcd
lcd.init(freq=15000000)
sensor.reset()                      # Reset and initialize the sensor. It will
                                    # run automatically, call sensor.run(0) to stop
sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
sensor.set_framesize(sensor.QVGA)   # Set frame size to QVGA (320x240)
sensor.skip_frames(time = 2000)     # Wait for settings take effect.
clock = time.clock()                # Create a clock object to track the FPS.
while(True):
    clock.tick()                    # Update the FPS clock.
    img = sensor.snapshot()         # Take a picture and return the image.
    lcd.display(img)                # Display on LCD
    print(clock.fps())              # Note: MaixPy's Cam runs about half as fast when connected
                                    # to the IDE. The FPS should increase once disconnected.
可以在IDE的右上角看到实时的画面,至此已完成简单的开发环境搭建。
关键词: SIPEEDM1DOCKSUITEVALBRD     环
