共1条
Re: 弱问题,四位二进制同步计数器的VHDL程序
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
ENTITY counter IS
PORT (
DATAIN :IN integer range 0 to 15;
CLK :IN std_logic;
CLR :IN std_logic;
LOAD :IN std_logic;
DATAOUT :OUT integer range 0 to 15;
CP :OUT std_logic);
END counter;
ARCHITECTURE behav OF counter IS
SIGNAL num :integer range 0 to 15;
SIGNAL CP0 :std_logic;
BEGIN
PROCESS(CLK,CLR)
BEGIN
IF ( CLR = '1' ) THEN
num <= 0;
ELSE
IF ( CLK'event AND CLK = '1') THEN
IF ( LOAD = '1') THEN
num <= DATAIN;
ELSE
num <= num + 1;
END IF;
IF ( num = 15 ) THEN
CP0 <= '1';
ELSE
CP0 <= '0';
END IF;
END IF;
END IF;
END PROCESS;
DATAOUT <= num;
CP <= CP0;
END;
--maxplus2下调试通过
关键词: 问题 四位 二进制 同步 计数器 程序
共1条
| OrangePiZero2W系统被打赏¥33元 | |
