UART1 为什么UART1“代码”少时可以多时就有问题?
问
如下代码,请大家看看有什么不妥?调试时,加载所有程序(25K,ARM2132),
UART1执行一次后,就不再进入中断,真是郁闷
//TIME0中断设置
T0TC = 0;
T0PR = 0;
T0MCR = 0x03;
T0MR0 = Fpclk / 1;
T0TCR = 0x01;
VICIntSelect = 0x00;
VICVectCntl2 = 0x20 | 0x04; VICVectAddr2 = (uint32)IRQ_Timer0;
VICIntEnable = 1 << 0x04;
//UART0设置
U0LCR = 0x83;
Fdiv = (Fpclk / 16) / SIM100_BAUD;
U0DLM = Fdiv / 256;
U0DLL = Fdiv % 256;
U0LCR = 0x03;
U0FCR = 0x01;
U0IER = 0x01; VICVectCntl0 = 0x20 | 0x06;
VICVectAddr0 = (uint32)IRQ_UART0;
VICIntEnable = 1 << 0x06;
//uart1 中断设置
set.datab = 8;
set.stopb = 1;
set.parity = 0;
U1LCR = 0X83;
Fdiv = (Fpclk / 16) / GPS_BAUD;
U1DLM = Fdiv / 256;
U1DLL = Fdiv % 256;
U1LCR = 0x03;
U1FCR = 0x01; U1IER = 0x00; VICVectCntl1 = 0x20 | 0x07;
VICVectAddr1 = (uint32)IRQ_UART1;
VICIntEnable = 1 << 0x07;
IRQEnable(); 答 1: xx IRQEnable(); 放在U1LCR = 0X83;前试试。
//TIME0中断设置
//UART0设置
有没有使能IRQ中断?程序不全,别人不好理解,就更不好谈程序妥不妥了。
答 2: 换个方式试一下VICIntEnable = 1 << 0x04;
改为
VICIntEnable |= (1 << 0x04)|(1 << 0x06)|(1 << 0x07);
//TIME0中断设置
T0TC = 0;
T0PR = 0;
T0MCR = 0x03;
T0MR0 = Fpclk / 1;
T0TCR = 0x01;
//UART0设置
U0LCR = 0x83;
U0DLM = Fdiv / 256;
U0DLL = Fdiv % 256;
U0LCR = 0x03;
U0FCR = 0x01;
//uart1 中断设置
set.datab = 8;
set.stopb = 1;
set.parity = 0;
U1LCR = 0X83;
U1DLM = Fdiv / 256;
U1DLL = Fdiv % 256;
U1LCR = 0x03;
//TIME0中断设置
//UART0设置
改为
