电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » IAR,Embedded,Workbench 关于IAR Embedded Wo
IAR,Embedded,Workbench 关于IAR Embedded Workbench 3.2的疑惑,请教
2006-09-17 18:14:16     打赏
关键词: Embedded     Workbench     关于     疑惑
2006-12-22 22:43:00     打赏
问 下面是一个用用TIMERA的CCR1,CCR2,分别产生75%,25%的PWM信号的程序,用ACLK 做时钟源,但是老是出现警告“Warning[Pe001]: last line of file ends without a newline”
,不知道为什么,快把我烦死了,各位能帮忙看看吗?是个在TI上面下载的EXAMPLE
// MSP-FET430P140 Demo - Timer_A PWM TA1-2 upmode, 32kHz ACLK
// Description; This program will generate a two PWM outputs on P1.2/1.3 using
// Timer_A in an upmode. The value in CCR0, defines the period and the
// values in CCR1 and CCR2 the duty PWM cycles. Using 32kHz ACLK as TACLK,
// the timer period is 15.6ms with a 75% duty cycle on P1.2 and 25% on P1.3.
// ACLK = TACLK = LFXT1 = 32768, MCLK = SMCLK = default DCO ~ 800kHz.
// Normal mode LPM3
// /External watch crystal installed on XIN XOUT is required for ACLK
// MSP430F149
// /|\| XIN|-
// | | | 32k
// --|RST XOUT|-
// | P1.2|--> CCR1 - 75% PWM
// | P1.3|--> CCR2 - 25% PWM
// M.Buccini
// Texas Instruments, Inc
// September 2003
// Built with IAR Embedded Workbench Version: 1.26B
// January 2004
// Updated for IAR Embedded Workbench Version: 2.21B
// modified by zy on 06/06/2004
#include <MSP430x14x.h>
void initial_ta_pwm02(void);
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
initial_ta_pwm02();
_BIS_SR(LPM3_bits); // Enter LPM3
P1DIR |= 0x0C; //p1.2,p1.3 output
P1SEL |= 0x0C; //p1.2,p1.3 for pwm mode for TA1/2
CCR0=512-1; //PWM peirod 15.6ms/32768=512
CCTL1=OUTMOD_7; //CCR1 reset/set
CCR1= 384; //CCR1 PWM for 75% high level
CCTL2=OUTMOD_7; //CCR2 reset/set
CCR2=128; //CCR2 PWM for 25% high level
TACTL=TASSEL_1+MC_1; //ACLK,up mode
} 答 1: 警告的翻译为:最后行 of 文件末尾 没有新的起始行, 那么在这个文件的最后行再打个回车,有新的起始行就ok了。
