问
Protel Design System Design Rule Check
PCB File : Documents\dianlu.PCB
Date : 22-Sep-2006
Time : 09:27:18
Processing Rule : Width Constraint (Min=40mil) (Max=40mil) (Prefered=40mil) (Is on net VCC )
Violation Track (58625mil,57090mil)(58640mil,57090mil) TopLayer Actual Width = 25mil
Violation Track (57275mil,55840mil)(57286.142mil,55840mil) TopLayer Actual Width = 20mil
Violation Track (58485mil,56580mil)(58505mil,56560mil) TopLayer Actual Width = 20mil
Rule Violations :3
Processing Rule : Width Constraint (Min=40mil) (Max=40mil) (Prefered=40mil) (Is on net GND )
Violation Track (57300mil,55697.441mil)(57300mil,55700mil) TopLayer Actual Width = 20mil
Violation Track (57286.142mil,55697.441mil)(57300mil,55697.441mil) TopLayer Actual Width = 20mil
Violation Track (56900mil,55554.882mil)(56920mil,55554.882mil) TopLayer Actual Width = 20mil
Violation Track (56900mil,55550mil)(56900mil,55554.882mil) TopLayer Actual Width = 20mil
Violation Track (57300mil,55700mil)(57319mil,55700mil) TopLayer Actual Width = 20mil
Rule Violations :5
Processing Rule : Hole Size Constraint (Min=1mil) (Max=100mil) (On the board )
Violation Pad P1-1(60260mil,56500mil) MultiLayer Actual Hole Size = 102mil
Violation Pad P1-3(60363mil,56686mil) MultiLayer Actual Hole Size = 102mil
Violation Pad P1-2(60489mil,56500mil) MultiLayer Actual Hole Size = 102mil
Violation Pad J1-11(59652mil,55507mil) MultiLayer Actual Hole Size = 140mil
Violation Pad J1-10(60638mil,55507mil) MultiLayer Actual Hole Size = 140mil
Rule Violations :5
Processing Rule : Width Constraint (Min=15mil) (Max=15mil) (Prefered=15mil) (On the board )
Rule Violations :0
Processing Rule : Clearance Constraint (Gap=10mil) (On the board ),(On the board )
Rule Violations :0
Processing Rule : Broken-Net Constraint ( (On the board ) )
Rule Violations :0
Processing Rule : Short-Circuit Constraint (Allowed=Not Allowed) (On the board ),(On the board )
Rule Violations :0
Violations Detected : 13
Time Elapsed : 00:00:00 答 1: I see
Date : 22-Sep-2006
Time : 09:27:18
Rule Violations :3
Rule Violations :5
Rule Violations :5
Rule Violations :0
Rule Violations :0
Rule Violations :0
Rule Violations :0
