keil,nbsp,nbsp,build,nbsp,nbsp,51,ucos,nbsp,nbsp keil build &nbs
问
_MBOX.obj",
"OS_MEM.obj",
"OS_Q.obj",
"OS_SEM.obj",
"OS_TASK.obj",
"OS_TIME.obj",
"OS_CPU_A.obj"
TO "Test"
RAMSIZE(256)
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 17AFH BYTE (296%) *
Program Size: data=25.0 xdata=547 code=6925
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: C:\KEIL2\C51\LIB\C51L.LIB (-----)
LIMIT: 0800H BYTES
Target not created
上面的错误 不知道怎么回事儿 求助大侠们
答 1: 你是用2K限制版本的吧? 答 2: 谢谢coke 的解答我换了一个版本 好了 再次感谢coke
_MBOX.obj",
"OS_MEM.obj",
"OS_Q.obj",
"OS_SEM.obj",
"OS_TASK.obj",
"OS_TIME.obj",
"OS_CPU_A.obj"
TO "Test"
RAMSIZE(256)
LIMIT: 0800H BYTES
Target not created
