电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » LCD 不显示问题请教
LCD 不显示问题请教
2008-09-21 22:50:08     打赏
2410板子程序为:
frameBuffer16BitTft240320=(U32 (*)[SCR_XSIZE_TFT_240320/2])LCDFRAMEBUFFER;
 rLCDCON1=(CLKVAL_TFT_240320<<8)|(MVAL_USED<<7)|(3<<5)|(12<<1)|0;
     // TFT LCD panel,12bpp TFT,ENVID=off
 rLCDCON2=(VBPD_240320<<24)|(LINEVAL_TFT_240320<<14)|(VFPD_240320<<6)|(VSPW_240320);
 rLCDCON3=(HBPD_240320<<19)|(HOZVAL_TFT_240320<<8)|(HFPD_240320);
 rLCDCON4=(MVAL<<8)|(HSPW_240320);
 rLCDCON5=(1<<11)|(1<<9)|(1<<8); //FRM5:6:5,HSYNC and VSYNC are inverted
 rLCDSADDR1=(((U32)frameBuffer16BitTft240320>>22)<<21)|M5D((U32)frameBuffer16BitTft240320>>1);
 rLCDSADDR2=M5D( ((U32)frameBuffer16BitTft240320+(SCR_XSIZE_TFT_240320*LCD_YSIZE_TFT_240320*2))>>1 );
 rLCDSADDR3=(((SCR_XSIZE_TFT_240320-LCD_XSIZE_TFT_240320)/1)<<11)|(LCD_XSIZE_TFT_240320/1);
 rLCDINTMSK|=(3); // MASK LCD Sub Interrupt
 rLPCSEL&=(~7); // Disable LPC3600
 //rLPCSEL|=(7);
 rTPAL=0; // Disable Temp Palette
void Test_Lcd_Tft_16Bit_240320(void)
     //int i,j,k;
    Lcd_Port_Init();
    Lcd_Init(MODE_TFT_16BIT_240320);
    Glib_Init(MODE_TFT_16BIT_240320);
    Lcd_Lpc3600Enable(); // Enable LPC3600
    Lcd_PowerEnable(0, 1);
    Lcd_EnvidOnOff(1);
    rCLKCON=0x7fff0;
    //Uart_Printf("[TFT 64K COLOR(16bit/1pixel) LCD TEST]\n");
    Glib_ClearScr(0, MODE_TFT_16BIT_240320);
    Glib_FilledRectangle(0,0,239,159,0xf800);
    Glib_FilledRectangle(0,160,239,320,0xf800);
这样的程序一直没有显示,开机就出现彩带请问这是什么原因啊?时钟寄存器我置LCD位,但 rCLKCON |= (1<<5),后用AXD DEBUG都用不了了,谢谢!
关键词: 显示     问题     请教     240320
