电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » linux移植之按键驱动
共5条 1/1 1 跳转至页
linux移植之按键驱动
2013-03-08 14:55:21     打赏
  • Linux内核下的drivers/input/keyboard/gpio_keys.c 实现了一个体系结构无关的 GPIO 按键驱动,使用此按键驱动,开发者不需要修改一行代码,只需要在BSP 的板文件(对于 MY6410为arch/arm/mach­s3c6410/mach­my6410.c)中定义相关的platform 设备和数据。在 MY6410开发板上,用 GPN0~GPN5实现了DOWN、ENTER、HOME、UP、TAB、END 六个按键,因此其对应的 platform 信息如下:
    arch/arm/mach­s3c6410/mach­my6410.c:
    static struct gpio_keys_button my6410_buttons[] = {
            .gpio        = S3C64XX_GPN(0),
            .code        = KEY_UP,
            .desc        = "Up",
            .active_low    = 1,
            .wakeup        = 0,
            .gpio        = S3C64XX_GPN(1),
            .code        = KEY_DOWN,
            .desc        = "Down",
            .active_low    = 1,
            .wakeup        = 0,
            .gpio        = S3C64XX_GPN(2),
            .code        = KEY_LEFT,
            .desc        = "Left",
            .active_low    = 1,
            .wakeup        = 0,
            .gpio        = S3C64XX_GPN(3),
            .code        = KEY_RIGHT,
            .desc        = "Right",
            .active_low    = 1,
            .wakeup        = 0,
            .gpio        = S3C64XX_GPN(4),
            .code        = KEY_ENTER,
            .desc        = "Enter",
            .active_low    = 1,
            .wakeup        = 0,
            .gpio        = S3C64XX_GPN(5),
            .code        = KEY_ESC,
            .desc        = "Esc",
            .active_low    = 1,
            .wakeup        = 0,
    static struct gpio_keys_platform_data my6410_button_data ={
        .buttons    =my6410_buttons,
        .nbuttons    =ARRAY_SIZE(my6410_buttons),
    static struct platform_device my6410_device_button    = {
        .name        ="gpio-keys",
        .id            = -1,
        .dev        = {
        .platform_data =&my6410_button_data,
  • 将& my6410_device_button添加到static struct platform_device *my6410_devices[] __initdata中
  • 配置linux内核
    Device Drivers --->
        Input device support --->
            [*] Keyboards --->
                 <*> GPIO Buttons
    在移植按键驱动时候可能出现一下错误:
    arch/arm/mach-s3c64xx/mach-my6410.c:298: error: array type has incomplete element type
    arch/arm/mach-s3c64xx/mach-my6410.c:300: error: field name not in record or union initializer
    arch/arm/mach-s3c64xx/mach-my6410.c:300: error: (near initialization for 'my6410_buttons')
    arch/arm/mach-s3c64xx/mach-my6410.c:301: error: field name not in record or union initializer
    arch/arm/mach-s3c64xx/mach-my6410.c:301: error: (near initialization for 'my6410_buttons')
    arch/arm/mach-s3c64xx/mach-my6410.c:302: error: field name not in record or union initializer
    arch/arm/mach-s3c64xx/mach-my6410.c:302: error: (near initialization for 'my6410_buttons')
    arch/arm/mach-s3c64xx/mach-my6410.c:303: error: field name not in record or union initializer
    arch/arm/mach-s3c64xx/mach-my6410.c:303: error: (near initialization for 'my6410_buttons')
    arch/arm/mach-s3c64xx/mach-my6410.c:304: error: field name not in record or union initialize
    可以看出这个错误提示的意思是没有找到定义的数组,然后其他的就引起一连串的错误,解决的办法很简单就是把
    #include <linux/gpio_keys.h>
    这个头文件添加进去就可以了。
  • 关键词: linux     驱动     按键
    2013-03-08 16:10:30     打赏
    嘿嘿,学习一下。有一个总体的认识
    再过二个月,余下来时间再来弄linux
    2013-03-10 16:23:54     打赏
    由简入繁,首先从掌握最简单的按键和led开始
    2013-03-10 18:31:42     打赏
    楼主进度神速啊,学习了
    2013-03-11 16:22:05     打赏
    内核这玩意很是麻烦
    共5条 1/1 1 跳转至页
