电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 关于STM32的PWM信号输出问题
共8条 1/1 1 跳转至页
关于STM32的PWM信号输出问题
2014-11-14 15:04:14     打赏
       最近用STM32调制PWM信号输出,我用TIM1产生7路PWM输出,但是在设置PWM信号占空比时出现这样一个问题,当后面通道输出的占空比,比前面通道输出占空比大时,前面通道的信号占空比,都会和后面这个信号占空比一样大(例如 : CCR2 > CCR1,信号输出占空比PWM1 = PWM2,当CCR2<CCR1,信号输出占空比正常)
程序就是用的官方程序,只是修改过频率和占空比参数。
  * @file    TIM/7PWM_Output/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup TIM_7PWM_Output
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t TimerPeriod = 0;
uint16_t Channel1Pulse = 0, Channel2Pulse = 0, Channel3Pulse = 0, Channel4Pulse = 0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
/* Private functions ---------------------------------------------------------*/
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  RCC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* TIM1 Configuration ---------------------------------------------------
   Generate 7 PWM signals with 4 different duty cycles:
   TIM1CLK = SystemCoreClock, Prescaler = 0, TIM1 counter clock = SystemCoreClock
   SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density
   and Connectivity line devices and to 24 MHz for Low-Density Value line and
   Medium-Density Value line devices
   The objective is to generate 7 PWM signal at 50Hz:
     - TIM1_Period = 2000 - 1
   The channel 1 and channel 1N duty cycle is set to 10%
   The channel 2 and channel 2N duty cycle is set to 37.5%
   The channel 3 and channel 3N duty cycle is set to 25%
   The channel 4 duty cycle is set to 12.5%
   The Timer pulse is calculated as follows:
     - ChannelxPulse = DutyCycle * (TIM1_Period - 1) / 100
  /* Compute the value to be set in ARR regiter to generate signal frequency at 50hz */
  TimerPeriod = 2000 - 1;
  /* Compute CCR1 value to generate a duty cycle at 10% for channel 1 and 1N */
  Channel1Pulse = (uint16_t) (((uint32_t) 10 * (TimerPeriod - 1)) / 100);
  /* Compute CCR2 value to generate a duty cycle at 37.5%  for channel 2 and 2N */
  Channel2Pulse = (uint16_t) (((uint32_t) 375 * (TimerPeriod - 1)) / 1000);
  /* Compute CCR3 value to generate a duty cycle at 25%  for channel 3 and 3N */
  Channel3Pulse = (uint16_t) (((uint32_t) 25 * (TimerPeriod - 1)) / 100);
  /* Compute CCR4 value to generate a duty cycle at 12.5%  for channel 4 */
  Channel4Pulse = (uint16_t) (((uint32_t) 125 * (TimerPeriod- 1)) / 1000);
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 720;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = Channel1Pulse;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = Channel2Pulse;
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = Channel3Pulse;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = Channel4Pulse;
  TIM_OC4Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* TIM1 Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
  while (1)
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
  /* TIM1, GPIOA, GPIOB, GPIOE and AFIO clocks enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOE|
                         RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO, ENABLE);
  * @brief  Configure the TIM1 Pins.
  * @param  None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStructure;
#ifdef STM32F10X_CL
  /* GPIOE Configuration: Channel 1/1N, 2/2N, 3/3N and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_11|GPIO_Pin_13|GPIO_Pin_14|
                                GPIO_Pin_8|GPIO_Pin_10|GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* TIM1 Full remapping pins */
  GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);
#else
  /* GPIOA Configuration: Channel 1, 2 and 3 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* GPIOB Configuration: Channel 1N, 2N and 3N as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
#endif
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
    求大神给个合理解释~~还有解决方法~ 谢谢了~~
关键词: STM32 PWM
2014-11-14 16:23:43     打赏
让大神们帮你看看,我给他们链接
2014-11-14 20:07:50     打赏
     问题解决了,真是一波三折,开始因为示波器有问题信号一直测不准,所以就用软件直接仿真输出的PWM信号,在软件仿真里面一直出现刚才上面说的那个问题,但是想想觉得不科学,这样占空比就等同于不可以调节了。所以刚才弄了两个舵机在开发板上面试了一下发现程序没有问题,然后弄到自己做的板子上,问题又来了,刚才用万用板一测才知道两个脚焊接的时候连到一起了~
    谢谢老王 ~~
   看样子以后不能太相信软件仿真了~
   最后附上几张第一次打样的相片~~
CH8_SPDT
CH8_SPDT
CH8_SPDT
CH8_SPDT
2014-11-14 22:13:47     打赏
楼主的小板做得很精致啊
2014-11-15 00:04:34     打赏
嘿嘿,这样的错误很可怜的。
2014-11-15 08:29:19     打赏
晶振距离单片机的距离是不是有点远啊,单片机电源管脚的的滤波电容是不是距离管脚也有点远啊。
2015-02-05 14:15:19     打赏
7楼
pwm的输出模式选的是2,此时输出占空比不是对应的,改为pwm mode1试试。
2015-02-27 16:51:57     打赏
8楼
楼主我也想做个舵机控制板,可没有基础,有原理图可以参考吗?谢谢!
共8条 1/1 1 跳转至页
