RT
找了好多资料也没配置错,就是出不来
#define ADC1_DR_Address ((u32)0x40012400+0x4c)
volatile u16 ADC_ConvertedValue[M];
void ADC1_Init(void)
DMA_InitTypeDef DMA_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/*------------------使能时钟---------------*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//ADC地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;//内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //内存作为数据传输的目的地
DMA_InitStructure.DMA_BufferSize = M; //DMA 通道的DMA 缓存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //数据宽度为16 位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16 位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循环缓存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA 通道 x 拥有高优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA 通道x 没有设置为内存到内存传输
DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根据DMA_InitStruct 中指定的参数初始化DMA 的通道
DMA_Cmd(DMA1_Channel1,ENABLE);
//ADC_DeInit(ADC1); //将外设 ADC1 的全部寄存器重设为缺省值
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//独立ADC模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE;//扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//连续转换模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//不使用外部触发转换
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//采集数据右对齐模式
ADC_InitStructure.ADC_NbrOfChannel = M;//ADC转换通道数目
ADC_Init(ADC1,&ADC_InitStructure);
ADC_Cmd(ADC1,ENABLE);
RCC_ADCCLKConfig(RCC_PCLK2_Div6);//PCLK2 6分频为ADC时钟,12MHz
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5);
ADC_DMACmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1); //复位指定的ADC1 的校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);//ADC校准
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd(ADC1,ENABLE);//使用软件触发方式触发ADC转换
/*获取ADC 的值,将二进制换算为十进制*/
u16 MQ4GetValue(void)
float volt,L;
u16 value;
volt = ADC_ConvertedValue[0] * 3.3 / 4096*1.51;
if(volt<1.4)
L=150/1.4;
value = (u16)(volt*L);
else if(volt>=1.4 && volt<2.0 )
L=(380-150)/(2.0-1.4);
value = (u16)((volt-1.4)*L);
else if(volt>=2.0 && volt<2.9 )
L=(1700-380)/(2.9-2.0);
value = (u16)((volt-2.0)*L);
else if(volt>=2.9 && volt<3.4 )
L=(4500-1700)/(3.4-2.9);
value = (u16)((volt-2.9)*L);
else if(volt>=3.4 && volt<3.7 )
L=(9999-4500)/(3.7-3.4);
value = (u16)((volt-3.4)*L);
else
value = 9999;
return value;
float BatteryGetVolt(void)
return (float)(ADC_ConvertedValue[1] * 3.3 / 4096)*2;
