ATC02作为I2C设备,其地址通常由固定部分和可配置部分组成。一般而言,I2C设备地址的高几位由制造商固定,而低几位可能通过硬件引脚(如A0、A1、A2)的电平来配置。以常见的EEPROM设备AT24C02为例,其I2C地址的高四位固定为“1010”,低三位则由A0、A1、A2三个引脚的电平决定。若这三个引脚都接地(GND),则AT24C02的I2C写地址为“0xA0”(二进制“10100000”),读地址为“0xA1”(二进制“10100001”)。
使用STM32CubeMX配置I2C外设:
选择I2C1或I2C2,设置时钟频率(如100kHz或400kHz)。
配置引脚为复用开漏输出模式(AF_OD)。
生成代码:使用HAL库初始化I2C外设。
#include "i2c.h" /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ I2C_HandleTypeDef hi2c3; /* I2C3 init function */ void MX_I2C3_Init(void) { /* USER CODE BEGIN I2C3_Init 0 */ /* USER CODE END I2C3_Init 0 */ /* USER CODE BEGIN I2C3_Init 1 */ /* USER CODE END I2C3_Init 1 */ hi2c3.Instance = I2C3; hi2c3.Init.Timing = 0x30A0A7FB; hi2c3.Init.OwnAddress1 = 0; hi2c3.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; hi2c3.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE; hi2c3.Init.OwnAddress2 = 0; hi2c3.Init.OwnAddress2Masks = I2C_OA2_NOMASK; hi2c3.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE; hi2c3.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE; if (HAL_I2C_Init(&hi2c3) != HAL_OK) { Error_Handler(); } /** Configure Analogue filter */ if (HAL_I2CEx_ConfigAnalogFilter(&hi2c3, I2C_ANALOGFILTER_ENABLE) != HAL_OK) { Error_Handler(); } /** Configure Digital filter */ if (HAL_I2CEx_ConfigDigitalFilter(&hi2c3, 0) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN I2C3_Init 2 */ /* USER CODE END I2C3_Init 2 */ } void HAL_I2C_MspInit(I2C_HandleTypeDef* i2cHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInit = {0}; if(i2cHandle->Instance==I2C3) { /* USER CODE BEGIN I2C3_MspInit 0 */ /* USER CODE END I2C3_MspInit 0 */ /** Initializes the peripherals clocks */ PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C3; PeriphClkInit.I2c3ClockSelection = RCC_I2C3CLKSOURCE_PCLK1; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) { Error_Handler(); } __HAL_RCC_GPIOC_CLK_ENABLE(); /**I2C3 GPIO Configuration PC8 ------> I2C3_SCL PC9 ------> I2C3_SDA */ GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF8_I2C3; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); /* I2C3 clock enable */ __HAL_RCC_I2C3_CLK_ENABLE(); /* USER CODE BEGIN I2C3_MspInit 1 */ /* USER CODE END I2C3_MspInit 1 */ } } void HAL_I2C_MspDeInit(I2C_HandleTypeDef* i2cHandle) { if(i2cHandle->Instance==I2C3) { /* USER CODE BEGIN I2C3_MspDeInit 0 */ /* USER CODE END I2C3_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_I2C3_CLK_DISABLE(); /**I2C3 GPIO Configuration PC8 ------> I2C3_SCL PC9 ------> I2C3_SDA */ HAL_GPIO_DeInit(GPIOC, GPIO_PIN_8); HAL_GPIO_DeInit(GPIOC, GPIO_PIN_9); /* USER CODE BEGIN I2C3_MspDeInit 1 */ /* USER CODE END I2C3_MspDeInit 1 */ } } /* USER CODE BEGIN 1 */ /* USER CODE END 1 */
main
int main(void) { HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_I2C3_Init(); MX_USART1_UART_Init(); /* USER CODE BEGIN 2 */ uint32_t i; printf(" 24C02 Test ....\r\n\r\n"); //向0x01内存地址写入数据 HAL_I2C_Mem_Write(&hi2c3,Addr_W,0x01,I2C_MEMADD_SIZE_8BIT,Data_T,DataSize,0xFF); printf(" 24C02 Write ok\r\n"); HAL_Delay(100); //从0x01内存地址读出数据 HAL_I2C_Mem_Read(&hi2c3,Addr_R,0x01,I2C_MEMADD_SIZE_8BIT,Data_R,DataSize,0xFF); printf(" 24C02 Read ok\r\n"); printf("24C02 Read Data : \r\n"); for(i = 0; i < DataSize; i++) printf("0x%02X ", Data_R[i]); printf("\r\n\r\n"); if(memcmp(Data_T, Data_R, DataSize) == 0) { printf(" 24C02 Test OK\r\n"); } else { printf(" 24C02 Test Failed\r\n"); } while (1) { } /* USER CODE END 3 */ }
STM32G4的硬件IIC在常规应用场景下具有较高的稳定性。其硬件IIC模块通过专用控制器实现时序控制,支持标准模式(100kHz)和快速模式(400kHz),并兼容SMBus协议,适合连接传感器、EEPROM等低速设备。通过STM32CubeMX配置时钟频率、引脚复用功能及上拉电阻后,硬件IIC可自动处理起始/停止条件、应答信号等时序,减少CPU干预,从而提升通信可靠性。
但在高频或复杂中断环境下,硬件IIC可能暴露稳定性问题。例如,当I2C时钟超过50kHz或系统存在频繁中断时,可能出现数据传输错误或总线卡死现象。旧版HAL库因专利规避设计,在多中断场景下易触发时序异常,而新版HAL库已优化此类问题。此外,硬件IIC对中断打断极为敏感,若在传输过程中被外部中断打断,可能导致总线状态紊乱。
为提升稳定性,建议采取以下优化措施:
1. 降低时钟频率:将I2C时钟控制在50kHz及以下,可显著降低通信错误率。
2. 减少中断干扰:避免在I2C传输期间触发其他中断,或通过DMA方式实现数据传输,减少CPU干预。
3.硬件配置优化:确保I2C引脚配置为复用开漏输出模式,并正确连接上拉电阻(通常为4.7kΩ)。
4.使用新版HAL库:新版HAL库已修复旧版存在的时序处理问题,推荐优先采用。
5.软件IIC:通过GPIO模拟I2C时序,灵活性更高,但会占用更多CPU资源
