关键词: serial bus, isolation barrier, galvanic isolation, transformer isolation, optoisolators
Abstract: An interface circuit uses the Dallas Semiconductor 1-Wire serial bus to provide isolated power and bidirectional communications between a master (MCU) and a sensing element.
