The Reduced Gigabit Media Independent Interface (RGMII) is an alternative to the Gigabit Media Independent Interface (GMII). In this application note, an RGMII adaptation module is used to reduce the number of pins required to connect the Gigabit Ethernet MAC to a Gigabit PHY from 24 to 12. This product is not recommended for new designs.
xapp692.pdf
共1条
Using the RGMII to Interface with the Gigabit Ethernet MAC - Not Recommended for
关键词: Using RGMII Interface Gig
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
