电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » FPGA实验连载(五、LCD1602显示)
2012-10-12 23:29:52     打赏
LCD(1602)显示字符:需要两个VHD文件:
文件1代码 charlcd1:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity charlcd1 is
    Port ( clk : in std_logic;     --24MHZ
           Reset : in std_logic;
           lcd_rs : out std_logic;
           lcd_rw : out std_logic;
     lcd_e  : buffer std_logic;
     data : out std_logic_vector(7 downto 0);
   --  stateout: out std_logic_vector(10 downto 0);
     clk_out: out std_logic);
end charlcd1;
architecture Behavioral of charlcd1 is
constant IDLE :         std_logic_vector(10 downto 0) :="00000000000";
constant CLEAR :        std_logic_vector(10 downto 0) :="00000000001";
constant RETURNCURSOR : std_logic_vector(10 downto 0) :="00000000010" ;
constant SETMODE      : std_logic_vector(10 downto 0) :="00000000100";
constant SWITCHMODE   : std_logic_vector(10 downto 0) :="00000001000";
constant SHIFT        : std_logic_vector(10 downto 0) :="00000010000";
constant SETFUNCTION  : std_logic_vector(10 downto 0) :="00000100000";
constant SETCGRAM     : std_logic_vector(10 downto 0) :="00001000000";
constant SETDDRAM     : std_logic_vector(10 downto 0) :="00010000000";
constant READFLAG     : std_logic_vector(10 downto 0) :="00100000000";
constant WRITERAM     : std_logic_vector(10 downto 0) :="01000000000";
constant READRAM      : std_logic_vector(10 downto 0) :="10000000000";
constant cur_inc      : std_logic :='1';
constant cur_dec      : std_logic :='0';
constant cur_shift    : std_logic :='1';
constant cur_noshift  : std_logic :='0';
constant open_display : std_logic :='1';
constant open_cur     : std_logic :='0';
constant blank_cur    : std_logic :='0';
constant shift_display : std_logic :='1';
constant shift_cur    : std_logic :='0';
constant right_shift  : std_logic :='1';
constant left_shift   : std_logic :='0';
constant datawidth8   : std_logic :='1';
constant datawidth4   : std_logic :='0';
constant twoline      : std_logic :='1';
constant oneline      : std_logic :='0';
constant font5x10     : std_logic :='1';
constant font5x7      : std_logic :='0';
signal state : std_logic_vector(10 downto 0);
signal counter : integer range 0 to 127;
signal div_counter : integer range 0 to 15;
signal flag        : std_logic;
constant DIVSS : integer :=15;
signal char_addr : std_logic_vector(5 downto 0);
signal data_in   : std_logic_vector(7 downto 0);
component char_ram
          port( address : in std_logic_vector(5 downto 0) ;
end component;
signal clk_int: std_logic;
signal clkcnt: std_logic_vector(18 downto 0);
constant divcnt: std_logic_vector(18 downto 0):="1111001110001000000";
signal clkdiv: std_logic;
signal tc_clkcnt: std_logic;
begin
process(clk,reset)
begin
  if(reset='0')then
  clkcnt<="0000000000000000000";
  elsif(clk'event and clk='1')then
     if(clkcnt=divcnt)then
     else
     clkcnt<=clkcnt+1;
     end if;
  end if;
end process;
tc_clkcnt<='1' when clkcnt=divcnt else
           '0';
process(tc_clkcnt,reset)
begin
   if(reset='0')then
   clkdiv<='0';
   elsif(tc_clkcnt'event and tc_clkcnt='1')then
   clkdiv<=not clkdiv;
   end if;
end process;
clk_out<=clk_int;
process(clkdiv,reset)
begin
  if(reset='0')then
    clk_int<='0';
  elsif(clkdiv'event and clkdiv='1')then
    clk_int<= not clk_int;
  end if;
end process;
begin
   if(reset='0')then
     lcd_e<='0';
   elsif(clkdiv'event and clkdiv='0')then
     lcd_e<= not lcd_e;
   end if;
end process;
aa:char_ram
   port map( address=>char_addr,data=>data_in);
    lcd_rs <= '1' when state =WRITERAM or state = READRAM else '0';
 lcd_rw <= '0' when state =CLEAR or state = RETURNCURSOR or state=SETMODE or state=SWITCHMODE or state=SHIFT or state= SETFUNCTION or state=SETCGRAM or state =SETDDRAM or state =WRITERAM else
           '1';
     data <="00000001" when state =CLEAR else
          "00000010" when state =RETURNCURSOR else
    "000001"& cur_inc & cur_noshift  when state = SETMODE else
    "00001" & open_display &open_cur & blank_cur when state =SWITCHMODE else
    "0001" & shift_display &left_shift &"00" when state = SHIFT else
    "001" & datawidth8 & twoline &font5x10 & "00" when state=SETFUNCTION else
    "01000000" when state =SETCGRAM else
    "10000000" when state =SETDDRAM and counter =0 else
    "11000000" when state =SETDDRAM and counter /=0 else
     data_in when state = WRITERAM else
    "ZZZZZZZZ";
   char_addr  <=conv_std_logic_vector( counter,6) when state =WRITERAM and counter<40 else
             conv_std_logic_vector( counter-41+8,6) when state= WRITERAM and counter>40 and counter<81-8 else
       conv_std_logic_vector( counter-81+8,6) when state= WRITERAM and counter>81-8 and counter<81 else
    "000000";
  process(clk_int,Reset)
  begin
      if(Reset='0')then
     state<=IDLE;
     counter<=0;
     flag<='0';
           div_counter<=0;
      elsif(clk_int'event and clk_int='1')then
     case state is
   when IDLE =>
           if(flag='0')then
           state<=SETFUNCTION;
        flag<='1';
        counter<=0;
        div_counter<=0;
                    else
       if(div_counter<DIVSS )then
        div_counter<=div_counter +1;
                             state<=IDLE;
                         else
        div_counter<=0;
        state <=SHIFT;
                         end if;
                    end if;
         when CLEAR    =>
              state<=SETMODE;
         when SETMODE  =>
              state<=WRITERAM;
         when RETURNCURSOR =>
              state<=WRITERAM;
         when SWITCHMODE =>
              state<=CLEAR;
         when SHIFT      =>
              state<=IDLE;
         when SETFUNCTION =>
              state<=SWITCHMODE;
         when SETCGRAM   =>
              state<=IDLE;
         when SETDDRAM   =>
              state<=WRITERAM;
         when READFLAG   =>
              state<=IDLE;
         when WRITERAM   =>
              if(counter =40)then
           state<=SETDDRAM;
        counter<=counter+1;
                        elsif(counter/=40 and counter<81)then
           state<=WRITERAM;
        counter<=counter+1;
                        else
          state<=SHIFT;
                    end if;
         when READRAM =>
              state<=IDLE;
         when others  =>
              state<=IDLE;
         end case;
    end if;
  end process;
end Behavioral;
文件2代码 char_ram:
library IEEE;
entity char_ram is
end char_ram;
architecture fun of char_ram is
function char_to_integer ( indata :character) return integer is
variable result : integer range 0 to 16#7F#;
begin
 case indata is
 when ' ' =>  result := 32;
 when '!' =>  result := 33;
 when '"' =>  result := 34;
 when '#' =>  result := 35;
 when '$' =>  result := 36;
 when '%' =>  result := 37;
 when '&' =>  result := 38;
 when ''' =>  result := 39;
 when '(' =>  result := 40;
 when ')' =>  result := 41;
 when '*' =>  result := 42;
 when '+' =>  result := 43;
 when ',' =>  result := 44;
 when '-' =>  result := 45;
 when '.' =>  result := 46;
 when '/' =>  result := 47;
 when '0' =>  result := 48;
 when '1' =>  result := 49;
 when '2' =>  result := 50;
 when '3' =>  result := 51;
 when '4' =>  result := 52;
 when '5' =>  result := 53;
 when '6' =>  result := 54;
 when '7' =>  result := 55;
 when '8' =>  result := 56;
 when '9' =>  result := 57;
 when ':' =>  result := 58;
 when ';' =>  result := 59;
 when '<' =>  result := 60;
 when '=' =>  result := 61;
 when '>' =>  result := 62;
 when '?' =>  result := 63;
 when '@' =>  result := 64;
 when 'A' =>  result := 65;
 when 'B' =>  result := 66;
 when 'C' =>  result := 67;
 when 'D' =>  result := 68;
 when 'E' =>  result := 69;
 when 'F' =>  result := 70;
 when 'G' =>  result := 71;
 when 'H' =>  result := 72;
 when 'I' =>  result := 73;
 when 'J' =>  result := 74;
 when 'K' =>  result := 75;
 when 'L' =>  result := 76;
 when 'M' =>  result := 77;
 when 'N' =>  result := 78;
 when 'O' =>  result := 79;
 when 'P' =>  result := 80;
 when 'Q' =>  result := 81;
 when 'R' =>  result := 82;
 when 'S' =>  result := 83;
 when 'T' =>  result := 84;
 when 'U' =>  result := 85;
 when 'V' =>  result := 86;
 when 'W' =>  result := 87;
 when 'X' =>  result := 88;
 when 'Y' =>  result := 89;
 when 'Z' =>  result := 90;
 when '[' =>  result := 91;
 when '\' =>  result := 92;
 when ']' =>  result := 93;
 when '^' =>  result := 94;
 when '_' =>  result := 95;
 when '`' =>  result := 96;
 when 'a' =>  result := 97;
 when 'b' =>  result := 98;
 when 'c' =>  result := 99;
 when 'd' =>  result := 100;
 when 'e' =>  result := 101;
 when 'f' =>  result := 102;
 when 'g' =>  result := 103;
 when 'h' =>  result := 104;
 when 'i' =>  result := 105;
 when 'j' =>  result := 106;
 when 'k' =>  result := 107;
 when 'l' =>  result := 108;
 when 'm' =>  result := 109;
 when 'n' =>  result := 110;
 when 'o' =>  result := 111;
 when 'p' =>  result := 112;
 when 'q' =>  result := 113;
 when 'r' =>  result := 114;
 when 's' =>  result := 115;
 when 't' =>  result := 116;
 when 'u' =>  result := 117;
 when 'v' =>  result := 118;
 when 'w' =>  result := 119;
 when 'x' =>  result := 120;
 when 'y' =>  result := 121;
 when 'z' =>  result := 122;
 when '{' =>  result := 123;
 when '|' =>  result := 124;
 when '}' =>  result := 125;
 when '~' =>  result := 126;
 when others => result :=32;
 end case;
 return result;
end function;
begin
process (address)
begin
 case address is
 when "000000" =>data<=conv_std_logic_vector(char_to_integer ('W') ,8);
 when "000001" =>data<=conv_std_logic_vector(char_to_integer ('e') ,8);
 when "000010" =>data<=conv_std_logic_vector(char_to_integer ('l') ,8);
 when "000011" =>data<=conv_std_logic_vector(char_to_integer ('e') ,8);
 when "000100" =>data<=conv_std_logic_vector(char_to_integer ('c') ,8);
 when "000101" =>data<=conv_std_logic_vector(char_to_integer ('o') ,8);
 when "000110" =>data<=conv_std_logic_vector(char_to_integer ('m') ,8);
 when "000111" =>data<=conv_std_logic_vector(char_to_integer ('e') ,8);
 when "001000" =>data<=conv_std_logic_vector(char_to_integer (' ') ,8);
 when "001001" =>data<=conv_std_logic_vector(char_to_integer (' ') ,8);
 when "001010" =>data<=conv_std_logic_vector(char_to_integer ('B') ,8);
 when "001011" =>data<=conv_std_logic_vector(char_to_integer ('A') ,8);
 when "001100" =>data<=conv_std_logic_vector(char_to_integer ('I') ,8);
 when "001101" =>data<=conv_std_logic_vector(char_to_integer ('X') ,8);
 when "001110" =>data<=conv_std_logic_vector(char_to_integer ('U') ,8);
 when "001111" =>data<=conv_std_logic_vector(char_to_integer ('N') ,8);
 when "010000" =>data<=conv_std_logic_vector(char_to_integer (' ') ,8);
 when "010001" =>data<=conv_std_logic_vector(char_to_integer (' ') ,8);
 when "010010" =>data<=conv_std_logic_vector(char_to_integer ('B') ,8);
 when "010011" =>data<=conv_std_logic_vector(char_to_integer ('o') ,8);
 when "010100" =>data<=conv_std_logic_vector(char_to_integer ('a') ,8);
 when "010101" =>data<=conv_std_logic_vector(char_to_integer ('r') ,8);
 when "010110" =>data<=conv_std_logic_vector(char_to_integer ('d') ,8);
 when "010111" =>data<=conv_std_logic_vector(char_to_integer ('!') ,8);
 when others   =>data<=conv_std_logic_vector(char_to_integer (' ') ,8);
 end case;
end process;
end fun;
关键词: 实验     连载     LCD1602     显示     logic     ve
