The MST43XXA series is a high input voltage (40V), low quiescent current, High PSRR linear regulator (LDO) able to provide 150mA load current.
The LDO features very fast response against line voltage transient and load current transient, and ensures no overshoot voltage during the LDO start up and short circuit recovery.
The device features integrated short-circuit and thermal shutdown protection.
The device is available with fixed output voltages of 3.0V, 3.3V, 3.6V and 5.0V, and available in SOT23 and SOT89 packages.
Application
Ø Battery-powered equipment
Ø Smoke detector and sensor
Ø Micro controller Applications
Ø Home Appliance
Features
Ø Low Quiescent Current:2uA
Ø High Input Voltage Rating:Up to 45V
Ø Output Current:150mA
Ø High PSRR:70dB at 1kHZ
Ø Dropout Voltage:70mV@10mA700mV@100mA
Ø Fixed Output Voltages:3.0V, 3.3V, 3.6V and 5.0V
Ø High VOUT accuracy : ±1%
Ø Good Transient Response
Ø Integrated Short-Circuit Protection
Ø Integrated Thermal Protection
Available Packages:
MST43XXATE MST43XXATE-A MST43XXATE-B MST43XXATE-C SOT23-3 MST43XXATS MST43XXATS-A MST43XXATS-B MST43XXATS-C SOT89-3 MST43XXATG SOT23-5
共1条
高输入电压(40V)、低静电流、高PSRR线性稳压器(LDO)MST43XXA
只看楼主 1楼
关键词: MST43XXA 稳压器 高输入 输入 电压 低静
共1条
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
汽车+汽车电子电阻解释与分析被打赏5分 | |
分享汽车通信和多媒体总线结构被打赏20分 | |
【我踩过的那些坑】结构堵孔导致的喇叭无声问题被打赏50分 | |
NUCLEO-U083RC学习历程38+串口通过队列的方式输出两个字符串被打赏20分 | |
【我踩过的那些坑】分享一下调试一款AD芯片的遇到的“坑”被打赏50分 | |
电流检测模块MAX4080S被打赏10分 | |
分享电控悬架的结构与工作原理(一)被打赏20分 | |
多组DCTODC电源方案被打赏50分 | |
【我踩过的那些坑】STM32cubeMX软件的使用过程中的“坑”被打赏50分 |
