核心板与接口板PCB图片——————————————————————2楼
FPGA开发板焊接完成 ———————————————————————7楼
LED篇----花样彩灯--------------------------------------------------------------------8楼
按键篇-----------------------------------------------------------------------------------9楼
8个LED先闪烁几次,然后依次从左到右点亮,从右至左点亮,从左至右连续点亮,从右至左连续点亮。
需要说明的的是上传的sof,使用的是Y1的晶振。
module led_run(sys_clk,sys_rstn,led);
input sys_clk;
input sys_rstn;
output reg [7:0]led;
//计数器
reg [25:0]cnt;
always@(posedge sys_clk )
begin
if(cnt==26'd49999999)
cnt<=26'd0;
else
cnt<=cnt+1'd1;
end
//1Hz
reg clk_1s;
begin
if(cnt<=26'd25000000)
clk_1s<=1'd0;
else
clk_1s<=1'd1;
end
parameter start=8'd0;
parameter right_set=8'd1;
parameter shift_right=8'd2;
parameter run_right=8'd3;
parameter left_set=8'd4;
parameter shift_left=8'd5;
parameter run_left=8'd6;
reg [25:0]delay_cnt;
reg [7:0] state;
always@(posedge clk_1s or negedge sys_rstn)
begin
if(!sys_rstn)
begin
delay_cnt<=25'd0;
led<=8'b0000_0000;
state<=8'd0;
end
else
begin
delay_cnt<=delay_cnt+1'd1;
case(state)
start:begin
led=~led;
if(delay_cnt==25'd5)
begin
state<=right_set;
delay_cnt<=25'd0;
end
else
state<=start;
end
right_set:begin
led<=8'b1111_1110;
state<=shift_right;
delay_cnt<=25'd0;
end
shift_right:begin
led<={led[6:0],led[7]};
if(delay_cnt==25'd6)
begin
state<=shift_left;
delay_cnt<=25'd0;
end
else
state<=shift_right;
end
shift_left:begin
led<={led[0],led[7:1]};
begin
state<=run_right;
delay_cnt<=25'd0;
end
else
state<=shift_left;
end
run_right:begin
led<=led<<1;
begin
state<=left_set;
delay_cnt<=25'd0;
end
else
state<=run_right;
end
left_set:begin
led<=8'b0111_1111;
state<=run_left;
delay_cnt<=25'd0;
end
run_left:begin
led<=led>>1;
begin
state<=start;
delay_cnt<=25'd0;
end
else
state<=run_left;
end
endcase
end
end
endmodule
//功能说明
//按键消抖、有按键时8个LED灯翻转、按S1数码管显示数据减一,按S2数码管显示数据加一wire [1:0]key_an=key_rst_r&~key_rst;
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
