Building configuration: menu_test - Debug
Updating build tree...
Linking
Error[e104]: Failed to fit all segments into specified ranges. Problem
discovered in segment CODE. Unable to place 39 block(s) (0x1c32 byte(s)
total) in 0x1986 byte(s) of memory. The problem occurred while processing the
segment placement command "-P(CODE)CODE=E000-FF7F", where at the moment of
placement the available memory ranges were "CODE:e5fa-ff7f"
Error while running Linker
Total number of errors: 2
Total number of warnings: 0
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
