搜索
复制
昨天换了一个MZ48,回去测试了一下,编码器OK了,采回来的数据比较稳定,应该能保证0.05°,主要由于自己做的车架固定的传感器安装精度不太高;
下面是采的数据:
板子上设计了四个灯,全闪是待机,点一下按键全灭进入平衡状态,单个等常亮是表示方向,两个灯亮是原地转圈
下面插一下主要代码:
主程序-测试版
s16 Gyro_x,Gyro_y,Gyro_z; u8 i; u16 Voltage = 0; Init_All(); //³õʼ»¯ËùÓÐÓ²¼þ while(1) { Voltage = 0.4032 * Get_Adc(); //µç³Øµçѹ£¨µ¥Î»0.01V£© SPI1_CS = 0; for(i=0;i<SPI_Mz48;i++) { Mz48[i] = (SPI1_ReadWriteByte(0xFFFF) & 0x3FFF); delay_us(1); } SPI1_CS = 1; printf("\n MZ48_1Êý¾Ý£º%d MZ48_2Êý¾Ý£º%d µç³Øµçѹ£º%d \n",Mz48[0],Mz48[1],Voltage); // Ïò´®¿Ú´òÓ¡ // /* // Gyro_x=getGyroX(); //XÖáÊý¾Ý // Gyro_y=getGyroY(); //YÖáÊý¾Ý // Gyro_z=getGyroZ(); //ZÖáÊý¾Ý // */ // Gyro_x=getAccX(); //XÖáÊý¾Ý // Gyro_y=getAccY(); //YÖáÊý¾Ý // Gyro_z=getAccZ(); //ZÖáÊý¾Ý //// printf("\n xÖáÊý¾Ý£º%d yÖáÊý¾Ý£º%d zÖáÊý¾Ý£º%d \n",Gyro_x,Gyro_y,Gyro_z); // Ïò´®¿Ú´òÓ¡ KEY_Scan(); if(Mini_Balance) { LED1 = 1; LED2 = 1; LED3 = 1; LED4 = 1; } else { LED1 = ~LED1; LED2 = ~LED2; LED3 = ~LED3; LED4 = ~LED4; } delay_ms(500); //ÉÔ×÷ÑÓʱ }
SPI初始化:
//SPI1¿Ú³õʼ»¯,·ÃÎÊMZ48 RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_SPI1, ENABLE ); /* Configure SPI1 pins: SCK, MISO and MOSI */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //¸´ÓÃÍÆÍìÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure I/O for MZ48 Chip select */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; //SPI1_CS GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //¸´ÓÃÍÆÍìÊä³ö GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); /* SPI1 configuration */ SPI_Cmd(SPI1, DISABLE); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //ÉèÖÃSPIµ¥Ïò»òÕßË«ÏòµÄÊý¾Ýģʽ:SPIÉèÖÃΪ˫ÏßË«Ïòȫ˫¹¤ SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //ÉèÖÃSPI¹¤×÷ģʽ:ÉèÖÃΪÖ÷SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; //ÉèÖÃSPIµÄÊý¾Ý´óС:SPI·¢ËͽÓÊÕ16λ֡½á¹¹ SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //Ñ¡ÔñÁË´®ÐÐʱÖÓµÄÎÈ̬:ʱÖÓÐü¿ÕµÍ SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //Êý¾Ý²¶»ñÓÚµÚ¶þ¸öʱÖÓÑØ£¿£¿£¿£¨SPI_CPHA_1Edge£© SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSSÐźÅÓÉÓ²¼þ£¨NSS¹Ü½Å£©»¹ÊÇÈí¼þ£¨Ê¹ÓÃSSI룩¹ÜÀí:ÄÚ²¿NSSÐźÅÓÐSSIλ¿ØÖÆ SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //¶¨Òå²¨ÌØÂÊÔ¤·ÖƵµÄÖµ:²¨ÌØÂÊÔ¤·ÖƵֵΪ2¼´@72MHzʱΪ36M SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //Ö¸¶¨Êý¾Ý´«Êä´ÓMSBλ»¹ÊÇLSBλ¿ªÊ¼:Êý¾Ý´«Êä´ÓMSBλ¿ªÊ¼ SPI_InitStructure.SPI_CRCPolynomial = 7; //CRCÖµ¼ÆËãµÄ¶àÏîʽ SPI_Init(SPI1, &SPI_InitStructure); //¸ù¾ÝSPI_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèSPIx¼Ä´æÆ÷ /* Enable SPI1 */ SPI_Cmd(SPI1, ENABLE); //ʹÄÜSPIÍâÉè
搜索
复制
晚上睡觉前简单测了一下倾角的滤波融合,加速度不好控制,测试的效果一般,没感觉出不同滤波的差别:
我的代码注视部分贴上去老是乱码呢!
//********************************************************* // 倾角计算 //********************************************************* void Angle_Calcu(void) { float Accel_x; // X轴加速度值暂存 float Accel_z; // Z轴加速度值暂存 float Angle_ax; // 由加速度计算的倾斜角度 float K,A,x1,x2,y1; float Vs[4]; //------加速度-------------------------- Accel_x = getAccX(); // 读取X轴加速度 Accel_z = getAccZ(); // 读取Z轴加速度 Angle_ax = atan((Accel_x * 1.0f) / (Accel_z * 1.0f)); // 去除零点偏移,计算得到角度(弧度)反正切 Angle_ax = (Angle_ax * 180 ) / 3.14 ; // 弧度转换为度 Vs[0] = Angle_ax; //-------角速度------------------------- //范围为2000deg/s时,换算关系:16.4 LSB/(deg/s) Gyro_y = getGyroY(); //静止时角速度Y轴输出为-1左右 Gyro_y = -(Gyro_y + 1)/16.4; //去除零点偏移,计算角速度值,负号为方向处理 //-------卡尔曼滤波融合----------------------- Kalman_Filter(Angle_ax,Gyro_y); //卡尔曼滤波计算倾角 Vs[1] = Angle; //-------一阶互补滤波----------------------- K = 0.075; //对加速度计取值的权重 A = K / (K + dt); Angle = A * (Angle + Gyro_y * dt) + (1-A) * Angle_ax; Vs[2] = Angle; //-------二阶互补滤波----------------------- K = 0.5; x1 = (Angle_ax - Angle) * K * K; y1 = y1 + x1 * dt; x2 = y1 + 2 * K *(Angle_ax - Angle) + Gyro_y; Angle = Angle + x2 * dt; Vs[3] = Angle; printf("%f \t %f \t %f \t %f \t %f \n",Gyro_y,Vs[0],Vs[1],Vs[2],Vs[3]); // 向串口打印 }
搜索
复制
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
