作业四:uart控制LED流水灯转速
- #include "stm32f10x.h"
- #include "stdio.h"
- GPIO_InitTypeDef GPIO_InitStructure; // 声明结构体
- NVIC_InitTypeDef NVIC_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- USART_ClockInitTypeDef USART_ClockInitStructure;
- #define buff_size 16;
- char rx_buff[],rx_buff_count=0;
- void RCC_Configuration(void) ;
- void GPIO_INIT(void) ;
- void USART_int(long BaudRate);
- void USART_SendStr(char *str);
- void delay_ms(u32 n) ;
- void delay_us(u32 n);
- /****主函数 ****/
- int main()
- RCC_Configuration();
- GPIO_INIT();
- USART_int(9600);
- GPIO_ResetBits(GPIOC,0xffff);//led全亮,提示程序开始
- delay_ms(200);
- GPIO_SetBits(GPIOC,0xffff);//led全灭
- USART_SendStr("USART Led Speed\r\n");//
- USART_SendStr("\n>");//
- while(1);
- /**** 配置RCC ****/
- ErrorStatus HSEStartUpStatus; // 设置错误标志量
- RCC_DeInit(); //*将外设寄存器RCC重设为初始值
- RCC_HSEConfig(RCC_HSE_ON);//*打开外部高速时钟晶振HSE:
- HSEStartUpStatus = RCC_WaitForHSEStartUp(); //*等待外部高速时钟晶振工作:
- if(HSEStartUpStatus==SUCCESS)
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//*AHB使用系统时钟,负责外部存储器的时钟
- RCC_PCLK1Config(RCC_HCLK_Div2);//*APB1 负责DA,USB,SPI,I2C,CAN,串口2345,普通TIM
- RCC_PCLK2Config(RCC_HCLK_Div1);//*APB2负责AD,I/O,高级TIM,串口1
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//*设置PLL输入时钟源72M
- RCC_PLLCmd(ENABLE);//*打开PLL:
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//*等待PLL工作:
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//*设置系统时钟
- while(RCC_GetSYSCLKSource() != 0x08);//* 判断PLL是否是系统时钟:
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
- /*蜂鸣器*/
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- GPIO_ResetBits(GPIOD,GPIO_Pin_2);
- /****延时 ****/
- u8 j;
- while(n--)
- for(j=0;j<10;j++);
- while(n--)
- delay_us(1000);
- /**** 初始化GPIO ****/
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- /**** USART传输的波特率 ****/
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA和 usart1
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 PA9作为US1的TX端,打开复用,负责发送数据
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //RX位于PA10
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入,PA10作为US1的RX端,负责接收数据
- //RX初始化PA10
- USART_InitStructure.USART_BaudRate = BaudRate;//波特率
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;//USART_WordLength 在一个帧中传输8位数据(字节)
- USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位为一个字节
- USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式
- USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动,开启发送接受数据功能(usart 使能)
- USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; //SCLK输出时钟低电平
- USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二个边沿开始数据捕获
- USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据不从SCLK发出
- USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
- USART_Init(USART1, &USART_InitStructure);//初始化USART1
- USART_Cmd(USART1, ENABLE);//USART1使能
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接收中断,在接受移位寄存器中有数据时产生
- //配置NVIC ,设置优先级分组,使用NVIC_Init对NVIC进行初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//选择中断分组4(先占优先级四位,从优先级0)
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择中断通道
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级1-15
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//响应优先级1-15
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断
- NVIC_Init(&NVIC_InitStructure); //初始化中断
- /**** usart发送数据 ****/
- void USART_SendStr(char *str) //USART发送数据
- while((*str)!='\0')
- USART_SendData(USART1,*str++); //通过外设 USARTx 发送单个数据
- while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); //检查指定的 USART 标志位设置与否
- /**** 取字符串中的数字 ****/
- unsigned int translate(char* pstr)
- int s = 0;
- while(*pstr != '\0') //如果没扫到字符串的最后不停止
- if(*pstr >= '0' && *pstr <= '9') //如果字符串中存在0-9的数字
- s = s * 10 + *pstr - '0';
- pstr++;
- return s;
- /**** 点亮led****/
- void LED(char *S,char LEN) //(字符串,字符串长度)
- int m,i;
- int a[8]={GPIO_Pin_0,GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3,GPIO_Pin_4,GPIO_Pin_5,GPIO_Pin_6,GPIO_Pin_7};
- m=translate(S);
- GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
- delay_ms(100);
- for(i=0;i<8;i++)
- GPIO_ResetBits(GPIOC,a[i]); // 点亮LED
- delay_ms(m);
- GPIO_SetBits(GPIOC,a[i]); //熄灭LED
- delay_ms(m);
- void input_ASK()
- char j;
- LED(rx_buff,rx_buff_count);
- rx_buff_count=0;
- for (j=0;j
- rx_buff[j]='\0';
- }//判断读入信息是否结束,如果结束则准备下一次读入
- /****接收中断****/
- void USART1_IRQHandler(void)
- while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET) { } //判断接收中断是否打开
- if(USART_ReceiveData(USART1)==0x0d)
- input_ASK();
- else
- USART_SendData(USART1,USART_ReceiveData(USART1)); //将数据传回给电脑
- rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
- rx_buff_count++;
- USART_ClearFlag(USART1, USART_FLAG_RXNE); //清除中断接受完成标志位
