class xxxx {
int cnt;
void fun();
然后我想
attachInterrupt(PIN11, fun, CHANGE);
然后在
void fun()
cnt++;
实现类似这样效果
发现只能绕路实现,直接实现不了的
程序写好了
#define LW_PWM 3 #define LW_IN1 2 #define LW_IN2 4 #define LW_ECA A1 #define LW_ECB A0 #define RW_PWM 5 #define RW_IN1 7 #define RW_IN2 6 #define RW_ECA A3 #define RW_ECB A2 #define CW 0 #define CCW 1 #include "balance_car.hpp" void setup() { Serial.begin(9600); BL_CAR.setup_motor(balance_car::LW, LW_PWM, LW_IN1, LW_IN2, LW_ECA, LW_ECB); BL_CAR.setup_motor(balance_car::RW, RW_PWM, RW_IN1, RW_IN2, RW_ECA, RW_ECB); } void loop() { delay(2000); BL_CAR.show_pos(); BL_CAR.run(80, CW, 80, CW); delay(2000); BL_CAR.show_pos(); BL_CAR.run(80, CCW, 80, CCW); delay(2000); BL_CAR.show_pos(); }
调换了一下6,7口,发现接线不对
程序功能为了测试连线和编码器
左右轮顺时针转一会,显示编码器值
再逆时针转一会,显示编码器值
经测试,连线没问题,编码器正常工作
http://playground.arduino.cc/Main/RotaryEncoders
主要理论如下图:
代码参考网站的例子:
/* read a rotary encoder with interrupts Encoder hooked up with common to GROUND, encoder0PinA to pin 2, encoder0PinB to pin 4 (or pin 3 see below) it doesn't matter which encoder pin you use for A or B uses Arduino pullups on A & B channel outputs turning on the pullups saves having to hook up resistors to the A & B channel outputs */ #define encoder0PinA 2 #define encoder0PinB 4 volatile unsigned int encoder0Pos = 0; void setup() { pinMode(encoder0PinA, INPUT); digitalWrite(encoder0PinA, HIGH); // turn on pullup resistor pinMode(encoder0PinB, INPUT); digitalWrite(encoder0PinB, HIGH); // turn on pullup resistor attachInterrupt(0, doEncoder, CHANGE); // encoder pin on interrupt 0 - pin 2 Serial.begin (9600); Serial.println("start"); // a personal quirk } void loop(){ // do some stuff here - the joy of interrupts is that they take care of themselves } void doEncoder() { /* If pinA and pinB are both high or both low, it is spinning * forward. If they're different, it's going backward. * * For more information on speeding up this process, see * [Reference/PortManipulation], specifically the PIND register. */ if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB)) { encoder0Pos++; } else { encoder0Pos--; } Serial.println (encoder0Pos, DEC); }
偷偷告诉你,例子有bug,你能发现不?
读取CurieIMU的加速度计和陀螺仪数据
参考API:
https://www.arduino.cc/en/Reference/CurieIMUreadMotionSensor
Description
Reads the raw values of the motion sensor (accelerometer + gyro).
SyntaxCurieImu.readMotionSensor(int ax, int ay, int az, int gx, int gy, int gz)
Parameters
ax: a variable in which the accelerometer's value along x will be stored.
ay: a variable in which the accelerometer's value along y will be stored.
az: a variable in which the accelerometer's value along z will be stored.
gx: a variable in which the gyro's value along x will be stored.
gy: a variable in which the gyro's value along y will be stored.
gz: a variable in which the gyro's value along z will be stored.
以上数据为原始数据。
转换方法:
To convert the raw value into mg use the following formula:
float g = (gRaw/32768.0)*getAccelerometerRange()
where gRaw is either ax, ay or az.
来自:https://www.arduino.cc/en/Reference/CurieIMUreadAccelerometer
To convert any of the raw values in angular velocity (°/s) use the following formula:
float av = ( avRaw/32768.9)*getGyroRange()
where avRaw is either gx, gy or gz.
来自:https://www.arduino.cc/en/Reference/CurieIMUreadGyro
有关自动校正:
https://www.arduino.cc/en/Reference/CurieIMUautoCalibrateAccelerometerOffset
float conv_g(int gRaw) { // 转换成标准重力加速度 return (gRaw/32768.0)*CurieIMU.getAccelerometerRange() ; } float conv_av (int avRaw) { return (avRaw/32768.0)*CurieIMU.getAccelerometerRange() ; } void balance_car::showIMU() { readIMU(); char buf[100]; sprintf(buf, "IMU data: %d, %d, %d, %d, %d, %d", _ax, _ay, _az, _gx, _gy, _gz); Serial.println(buf); sprintf(buf, "IMU data: %f, %f, %f, %f, %f, %f", conv_g(_ax), conv_g(_ay), conv_g(_az), conv_av(_gx), conv_av(_gy), conv_av(_gz)); Serial.println(buf); }
部分测试代码如上:
小车直立放置后,输出结果如下:
LW:0 RW:0
LW:0 RW:0
IMU data: 4, -25, 16301, -15, -4, -10
IMU data: 0.000244, -0.001526, 0.994934, -0.000916, -0.000244, -0.000610
LW:0 RW:0
LW:0 RW:0
LW:0 RW:0
IMU data: -4, 17, 16296, -4, -7, 7
IMU data: -0.000244, 0.001038, 0.994629, -0.000244, -0.000427, 0.000427
LW:0 RW:0
LW:0 RW:0
LW:0 RW:0
IMU data: 34, -8, 16347, -6, 0, 0
IMU data: 0.002075, -0.000488, 0.997742, -0.000366, 0.000000, 0.000000
模仿别人写了个角度计算的函数
float balance_car::Angle_Calcu(void) { readIMU(); float angleA= atan(conv_g(_ay)/ conv_g(_az))* (180)/ 3.1415926; return angleA; }
然后loop中输出角度
这个角度基本上准确
用串口绘图软件看,虽然角度基本正确,但是运动的时候,图像有锯齿
网上说要滤波,回头研究一下咋滤波呢
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
电流检测模块MAX4080S被打赏10分 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏10分 |
