流程满清楚的,,,先学习看下,,如果改成小船应该更加可爱
#include <CurieIMU.h> int ax, ay, az; int gx, gy, gz; #define LED_PIN 13 void setup() { CurieIMU.begin(); Serial.begin(9600); Serial.print("Starting Gyroscope calibration..."); CurieIMU.autoCalibrateGyroOffset(); Serial.println(" Done"); Serial.print("Starting Acceleration calibration..."); CurieIMU.autoCalibrateAccelerometerOffset(X_AXIS, 0); CurieIMU.autoCalibrateAccelerometerOffset(Y_AXIS, 0); CurieIMU.autoCalibrateAccelerometerOffset(Z_AXIS, 1); Serial.println(" Done"); Serial.println("Internal sensor offsets AFTER calibration..."); Serial.print(CurieIMU.getAccelerometerOffset(X_AXIS)); Serial.print("\t"); Serial.print(CurieIMU.getAccelerometerOffset(Y_AXIS)); Serial.print("\t"); Serial.print(CurieIMU.getAccelerometerOffset(Z_AXIS)); Serial.print("\t"); Serial.print(CurieIMU.getAccelerometerOffset(X_AXIS)); Serial.print("\t"); Serial.print(CurieIMU.getAccelerometerOffset(Y_AXIS)); Serial.print("\t"); Serial.print(CurieIMU.getAccelerometerOffset(Z_AXIS)); Serial.print("\t"); Serial.println(""); } double total_angle=0; /* 通过卡尔曼滤波得到的最终角度 */ float Angle=0.0; /*由角速度计算的倾斜角度 */ float Angle_gy=0.0; float Q_angle=0.9; float Q_gyro=0.001; float R_angle=0.5; float dt=0.01; /* dt为kalman滤波器采样时间; */ char C_0 = 1; float Q_bias, Angle_err; float PCt_0=0.0, PCt_1=0.0, E=0.0; float K_0=0.0, K_1=0.0, t_0=0.0, t_1=0.0; float Pdot[4] ={0,0,0,0}; float PP[2][2] = { { 1, 0 },{ 0, 1 } }; /* 卡尔曼滤波函数,具体实现可以参考网上资料,也可以使用其它滤波算法 */ void Kalman_Filter(float Accel,float Gyro) { Angle+=(Gyro - Q_bias) * dt; Pdot[0]=Q_angle - PP[0][1] - PP[1][0]; Pdot[1]=- PP[1][1]; Pdot[2]=- PP[1][1]; Pdot[3]=Q_gyro; PP[0][0] += Pdot[0] * dt; PP[0][1] += Pdot[1] * dt; PP[1][0] += Pdot[2] * dt; PP[1][1] += Pdot[3] * dt; Angle_err = Accel - Angle; PCt_0 = C_0 * PP[0][0]; PCt_1 = C_0 * PP[1][0]; E = R_angle + C_0 * PCt_0; if(E!=0) { K_0 = PCt_0 / E; K_1 = PCt_1 / E; } t_0 = PCt_0; t_1 = C_0 * PP[0][1]; PP[0][0] -= K_0 * t_0; PP[0][1] -= K_0 * t_1; PP[1][0] -= K_1 * t_0; PP[1][1] -= K_1 * t_1; Angle += K_0 * Angle_err; Q_bias += K_1 * Angle_err; } void loop() { // read raw accel/gyro measurements from device double ax_angle=0.0; double gx_angle=0.0; unsigned long time=0; unsigned long mictime=0; static unsigned long pretime=0; float gyro=0.0; if(pretime==0) { pretime=millis(); return; } mictime=millis(); CurieIMU.readMotionSensor(ay, ax, az, gy, gx, gz); /* 加速度量程范围设置2g 16384 LSB/g * 计算公式: * 前边已经推导过这里再列出来一次 * x是小车倾斜的角度,y是加速度计读出的值 * sinx = 0.92*3.14*x/180 = y/16384 * x=180*y/(0.92*3.14*16384)= */ //ax -= AX_ZERO; ax_angle=ax/262; /* 陀螺仪量程范围设置250 131 LSB//s * 陀螺仪角度计算公式: * 小车倾斜角度是gx_angle,陀螺仪读数是y,时间是dt * gx_angle +=(y/(131*1000))*dt */ //gy -= GX_ZERO; time=mictime-pretime; gyro=gy/131.0; gx_angle=gyro*time; gx_angle=gx_angle/1000.0; total_angle-=gx_angle; dt=time/1000.0; Kalman_Filter(ax_angle,gyro); Serial.print(ax_angle); Serial.print(","); Serial.print(total_angle); Serial.print(","); Serial.println(Angle); pretime=mictime; }
把MPU6050的卡尔曼滤波程序,改成了用Arduino/Genuion 101的Curie IMU
看了一下串口数据
滤波后的数据果然要好了好多
重新学习了一下角度的关系
原来我当初没有好好学习,神马几何、三角函数都还给老师了
还好,有万能的互联网,我们可以充分发挥拿来主义精神
首先,我的IMU的安装方向:(Z轴朝下,我找不到图)
很遗憾,很多人都是把X方向朝前,所以如果没搞明白方向,拿人家代码是无法使用的
(即使搞明白也没法用,我的大破车,据说太大了,555)
然后,几个角度的问题:
经常看到,pitch yaw roll,听起来挺高大上的,但是也不知道是啥,继续哭
找到一篇文章:
http://www.123kuai.com/index.php?a=show&c=index&catid=9&id=54
说的太好了, 复制到下边了。
先把坐标复制上来
根据下文的坐标系以及说明,总结如下:
roll, 绕X轴转角
pitch, 绕Y轴转角
yaw, 绕Z轴转角
以上角度遵循右手定则
结合到我的小车IMU里,roll是我们要的角度
按右手定则,前倾为负,后仰为整
要了解飞机姿态,需要首先知道什么是地面坐标系和机体坐标系。
■地面坐标系(earth-surface inertial reference frame)Sg--------Oxgygzg
①在地面上选一点Og
②使xg轴在水平面内并指向某一方向
③zg轴垂直于地面并指向地心
④yg轴在水平面内垂直于xg轴,其指向按右手定则确定
■机体坐标系(Aircraft-body coordinate frame)Sb-------oxyz
①原点O取在飞机质心处,坐标系与飞机固连
②x轴在飞机对称平面内并平行于飞机的设计轴线指向机头
③y轴垂直于飞机对称平面指向机身右方
④z轴在飞机对称平面内,与x轴垂直并指向机身下方
■欧拉角/姿态角(Euler Angle)
机体坐标系与地面坐标系的关系是三个Euler角,反应了飞机相对地面的姿态。
俯仰角θ(pitch):机体坐标系X轴与水平面的夹角。当X轴的正半轴位于过坐标原点的水平面之上(抬头)时,俯仰角为正,否则为负。
偏航角ψ(yaw):
机体坐标系xb轴在水平面上投影与地面坐标系xg轴(在水平面上,指向目标为正)之间的夹角,由xg轴逆时针转至机体xb的投影线时,偏航角为正,即机头右偏航为正,反之为负。
滚转角Φ(roll):机体坐标系zb轴与通过机体xb轴的铅垂面间的夹角,机体向右滚为正,反之为负。
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
